    Padrão Alguém pode anlisar minha config. do dns????
    Ai pessoal estou com problemas para enviar email para o ig fiz um teste www.DNSstuff.com e parece que o dns reverso está dando um erro!!!
    Porém para outros dominios envia normal o email's
    Aqui está o erro!!!
    Preparation:
    The reverse DNS entry for an IP is found by reversing the IP, adding it to "in-addr.arpa", and looking up the PTR record.
    So, the reverse DNS entry for 200.171.xxx.xx is found by looking up the PTR record for
    xx.xxx.171.200.in-addr.arpa.
    All DNS requests start by asking the root servers, and they let us know what to do next.
    See How Reverse DNS Lookups Work for more information.
    How I am searching:
    Asking a.root-servers.net for xx.xxx.171.200.in-addr.arpa PTR record:
    a.root-servers.net says to go to ns2.dns.br. (zone: 200.in-addr.arpa.)
    Asking ns2.dns.br. for xx.xxx.171.200.in-addr.arpa PTR record:
    ns2.dns.br [200.19.119.99] says to go to B.DNS.BR. (zone: 171.200.in-addr.arpa.)
    Asking B.DNS.BR. for xx.xxx.171.200.in-addr.arpa PTR record:
    b.dns.br [200.209.30.5] says to go to dnsqipbr2.telesp.net.BR. (zone: xxx.171.200.in-addr.arpa.)
    Asking dnsqipbr2.telesp.net.BR. for xx.xxx.171.200.in-addr.arpa PTR record: Reports 200-171-xxx-xx.speedyterra.com.br. [from 200.204.0.139]
    Answer:
    200.171.xxx.xx PTR record: 200-171-xxx-xx.speedyterra.com.br. [TTL 86400s] [A=None] *ERROR* There is no A record (may be cached).
    To see the reverse DNS traversal, to make sure that all DNS servers are reporting the correct results, you can Click Here.
    aqui está a configuraçao do dns
    $TTL 86400
    @ IN SOA dominio.com.br. root.dominio.com.br. (
    2006021001 ; serial;
    3600 ; refresh
    900 ; retry
    1209600 ; expire
    43200 ) ; default_ttl
    @ IN NS dominio.com.br.
    @ IN NS server.dominio.com.br.
    @ IN MX 10 server.dominio.com.br.
    server.dominio.com.br. IN A 200.xxx.xxx.xx
    www IN CNAME server.dominio.com.br.
    pop IN CNAME server.dominio.com.br.
    smtp IN CNAME server.dominio.com.br.
    ftp IN CNAME server.dominio.com.br.
    Aqui a do reverso
    $TTL 86400
    2006021001
    3600
    900
    1209600
    43200 )
    87 IN PTR server.dominio.com.br.
    alguém pode me dizer onde está o erro????
    Padrão Re: Alguém pode anlisar minha config. do dns????
    Pergunta cara voce ja ligou pra telefonica e pediu pra eles liberarem ou pra voce responder o DNS, ou para eles atualizarem o reverso deles?? pois o nome que ta respondendo o reverso é o padrão da telefonica, liga pra eles.
    falows
    Citação Postado originalmente por ruyneto
    falows
    Entao ruyneto ainda não liguei pra telefonica pois acho que tem alguma coisa errada na minha configuração do dns e dns reverso pois até uns dias atras funcionava normalmente, mas deu um problema no HD aqui e tive que reinstalar tudo novamente e como sou iniciante com o Bind to achando que o problema está na minha configuração!!!
    Obs: já consultei o registro.br e lá mostra tudo OK!!!
    Vc pode me dizer se tem alguma coisa errada na minha configuração de dns e dns reverso???
    Cara se fosse erro no seu provavelmente nao ia ter resposta nenhuma e nao responder como nome .speedyterra.com.br entende?? Mas posta o namede.conf do reverso ae tb
    falows
    falows
    Aqui está o named.conf
    // generated by named-bootconf.pl
    options {
    directory "/var/named";
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    // query-source address * port 53;
    dump-file "/var/named/dump/named_dump.db";
    statistics-file "/var/named/dump/named.stats";
    memstatistics-file "/var/named/dump/named.memstats";
    // remove this next line if you want named to listen on
    // all available interfaces, or adjust add new ones as
    // you see fit
    // listen-on { 127.0.0.1/32; };
    // a caching only nameserver config
    zone "." {
    type hint;
    file "named.ca";
    zone "0.0.127.in-addr.arpa" {
    type master;
    file "named.local";
    zone "dominio.com.br" {
    type master;
    file "dominio.com.brr";
    zone "xx.171.200.in-addr.arpa" {
    type master;
    file "200.171.xx.xx";
    $TTL 86400
    3600 ; refresh
    900 ; retry
    1209600 ; expire
    Aqui a do reverso
    $TTL 86400
    2006021001
    3600
    900
    1209600
    43200 )
    ruyneto obrigado pela atenção
    cara na zona do reverso poe o ip inteiro ao contrario, se vc tiver mais de 1 ip vc poe a faixa de ips que vc responde ex: 1-127.31.5.200.in-addr.arpa
    ou so o ip ao contrario completo que vc responde.
    falows
    Agora está assim a zona do reverso
    zone "xx.xx.171.200.in-addr.arpa" {
    type master;
    Fiz a alteraçao mas continua dando erro no site www.DNSstuff.com
    Tentei mandar um email para @ig.com.br e retornou o seguinte erro!!! Será q tenho q ligar para telefonica??/
    Feb 17 10:16:22 servidor postfix/qmgr[1656]: 7040624C21: from=<[email protected] br>, size=1365, nrcpt=1 (queue active)
    Feb 17 10:16:22 servidor postfix/smtpd[3918]: disconnect from unknown[192.168.5. 250]
    Feb 17 10:16:24 servidor postfix/smtp[3922]: connect to mx.ig.com.br[200.226.132 .20]: server refused mail service (port 25)
    Feb 17 10:16:24 servidor postfix/smtp[3922]: 7040624C21: to=<[email protected] .br>, relay=none, delay=2, status=deferred (connect to mx.ig.com.br[200.226.132. 20]: server refused mail service)
    cara da uma ligada la sim.
    falows
    Valeu pela força ruyneto!!!
    Vou ligar lá depois posto aqui o resultado!!!
    Ai pessoal ainda nao consegui falar com a telefonica estou sem os dados do assinante do speedy!!!
    Seria por este erro no reverso que o ip da empresa foi parar na black list rbls.org???Pois o relay do postfix está habilitado apenas para a rede interna!!!
    marcelo.wcs
    Tente modificar o reverso no named.conf para:
    zone "200.171xx.xx.in-addr.arpa" IN {
    type master;
    file "xx.171.200.zone";
    allow-update { none; };
    Qualquer coisa posta ai...
    Este visitante sou eu.
    Citação Postado originalmente por marcelo.wcs
    type master;
    lelinho
    bom, estou aki pra dizer q estamos com o mesmo problema...
    sem conseguir enviar emails para o ig.com.br.... e dando erro no dns...
    gostaria saber thelast se vc ja conseguiu resolver seu problema e como...
    estamos ligado no terra q é o provedor obtendu algumas informaões a respeito, mais gostaria de saber se o problema ja fo resolvido e como...
    desde ja agradeço...
    lelinho
    ainda nao consegui resolver...
    e posso dizer q ja tentei alterar reverso e desreverso...
    como fazer pra q o ig.com.br volte a receber emails???
    arrumei meus reversos como terra q é o provedor do cliente, ja falei com o terra e com o ig, um joga pro outro....
    será q ligandu e falandu com o speedy teria algum resultado???
    please, alguem me ajude...
    tks
    NAMED.CONF
    Se seu bloco por exemplo /26 faz seguinte
    zone "xxx-xxx.xx.71.200.in-addr.arpa" {
    type master;
    file "dominioreverso";
    allow-transfer { ip de quem replica ; };
    Na zona reversa voce deve especificar todo o teu bloco, no meu caso que é embratel eu tenho 64 ips validos na internet e é necessario eu especificar o meu bloco inteiro como aqui zone "xxx-xxx.23.251.200.in-addr.arpa"
    exemplo: 100-164.35.112.200.in-addr.arpa
    ja no teu arquivo reverso abaixo faz assim, eu tirei o @ e adicionei o NS do teu provedor ( embratel, telefoni etc..) verifica com eles qual é
    $TTL 86400
    2006021001
    3600
    900
    1209600
    43200 )
    IN NS serverprovedor.dominio.com.br.
    É necesserio voce pedir para teu provedor as informações para isso e manter contato com eles.
    Hoje mesmo eu refiz meu bind desta forma e ta rodando certinho!
    Padrão Dns reverso! Já faz um mes e nada!
    então galera alguem sabe como posso resolver esse problema, pois ligo pra telefonica e nao consigo que eles façam a configuração do reverso!!!
    já se passou um mes e nada
    Será que nao tem outra forma de configurar isto sem precisar da telefonica????
    Cara se eles tiverem respondendo pelo seu reverso so eles arrumando mesmo, a unica coisa que pode fazer eh ve se eles repassam a resposta pra voce ae vc fica responsavel mas eh bem dificil eles fazrem isso
    falows
    O problema é que quando ligo para o suporte do speedy os atendentes nem sabem o que é dns reverso e pedem que eu entre em contato com o meu provedor!!! Quando lhes informo que eu sou o provedor eles dizem que não existe nada lhes informando sobre o problema!!!
    Vc's sabem de algum telefone ou email do suporte da telefonica que pode resolver meu problema?????
    Cara voce tem adsl empresarial?? Tenta mandar um e-mail pro suporte e diz que se eles não resolverem voce vai ao procom.
    Falows
    Falows
    Sim é empresarial!!!
    Ai Ruyneto desculpa a insistencia, mas só pra ver se não estou falando besteira vou mandar novamente as configuracoes do meu server pra vc's darem uma olhada pois formatei o servidor e instalei outra distro FC4, e estou com os seguintes problemas agora!!!rsrsrs
    Não consigo enviar email para o @ig.com.br e @terra.com.br
    [[email protected] ~]# telnet mx.ig.com.br 25
    Trying 200.226.132.20...
    Connected to mx.ig.com.br (200.226.132.20).
    Escape character is '^]'.
    553- Reverso invalido ou nao configurado.
    553 Bad reverse. (#5.7.1)Connection closed by foreign host.
    [[email protected] ~]# telnet mx.terra.com.br 25
    Trying 200.154.55.2...
    Connected to mx.terra.com.br (200.154.55.2).
    450 Client host rejected: cannot find your hostname, [200.171.26.xx]
    o terra responde com um erro sobre o hostname, o que será pois mandar email para o ig até que nao me faz muita falta mas pro terra e essencial!!!
    /etc/hosts
    # Do not remove the following line, or various programs
    # that require network functionality will fail.
    127.0.0.1 servidor.dominio.com.br servidor localhost.localdomain localhost
    200.171.26.87 servidor.dominio.com.br servidor
    /etc/named.conf
    // named.conf for Red Hat caching-nameserver
    options {
    dump-file "/var/named/data/cache_dump.db";
    statistics-file "/var/named/data/named_stats.txt";
    * port by default.
    controls {
    inet 127.0.0.1 allow { localhost; } keys { rndckey; };
    zone "." IN {
    type hint;
    file "named.ca";
    zone "localdomain" IN {
    type master;
    file "localdomain.zone";
    zone "localhost" IN {
    type master;
    file "localhost.zone";
    zone "0.0.127.in-addr.arpa" IN {
    type master;
    file "named.local";
    zone "dominio.com.br" IN {
    type master;
    file "dominio.com.br";
    zone "26.171.200.in-addr.arpa" IN {
    type master;
    file "200.171.26.rev";
    include "/etc/rndc.key";
    /var/named/chroot/var/named/dominio.com.br
    $TTL 86400
    @ IN SOA servidor.dominio.com.br. root.dominio.com.br. (
    2006031501 ; serial;
    3600 ; refresh
    900 ; retry
    1209600 ; expire
    @ IN NS servidor.dominio.com.br.
    @ IN MX 10 servidor.dominio.com.br.
    servidor IN A 200.171.26.xx
    www IN A 200.171.26.xx
    pop IN A 200.171.26.xx
    smtp IN A 200.171.26.xx
    ftp IN A 200.171.26.xx
    /var/named/chroot/var/named/200.171.26.rev
    $TTL 86400
    2006031501 ;
    3600 ;
    900 ;
    1209600 ;
    43200 ;
    xx IN PTR servidor.dominio.com.br.
    Por que será que agora está dando este erro com o terra????Tá muito dificil!!!rsrsrs
