    Padrão dns no slackware 10.2
    Ola pessoal to tentado instalar um servidor de dns mas to com problemas, as conf são:
    no named.conf:
    options {
    directory "/var/named";
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    // query-source address * port 53;
    transfer-format many-answers;
    controls {
    inet * port 953 allow { 127.0.0.1; }; // Para usar o rndc apenas em localhost
    // a caching only nameserver config
    zone "." IN {
    type hint;
    file "caching-example/named.ca";
    zone "localhost" IN {
    type master;
    file "caching-example/localhost.zone";
    allow-update { none; };
    zone "predador.eb.mil.br" IN {
    type master;
    file "predador";
    allow-update {none; };
    localhost.zone:
    $TTL 86400
    $ORIGIN localhost.
    @ 1D IN SOA @ root (
    42 ; serial (d. adams)
    3H ; refresh
    15M ; retry
    1W ; expiry
    1D ) ; minimum
    1D IN NS @
    1D IN A 127.0.0.1
    named.local:
    $TTL 86400
    @ IN SOA localhost. root.localhost. (
    1997022700 ; Serial
    28800 ; Refresh
    14400 ; Retry
    3600000 ; Expire
    86400 ) ; Minimum
    IN NS localhost.
    1 IN PTR localhost.
    arquivo do meudominio:
    $TTL 86400
    Authoritative data for intranet.server.br.
    @ IN SOA predador.eb.mil.br. root. predador.eb.mil.br. (
    2004102897 ; Serial (yymmddxx)
    10800 ; Refresh (1 hour)
    3600 ; Retry (2minutes)
    36000 ; Expire (5 weeks 6 days 16 hours)
    86400 ) ; Minimum (1 hour)
    IN NS ns1.predador.eb.mil.br.
    IN NS ns2.predador.eb.mil.br.
    ;Recebimento de mensagens de mail
    predador.eb.mil.br. IN MX 0 mx
    predador.eb.mil.br. IN MX 10 mx
    ; Hosts
    localhost IN A 127.0.0.1
    IN HINFO INTEL/110 LINUX
    www IN A 192.168.0.2 ; o ip da sua maquina
    ns1 IN A 192.168.0.2 ; o ip da sua maquina
    ns2 IN A 192.168.0.2 ; o ip da sua maquina
    maquina-1 IN A 172.168.0.3 ; ip qualquer da rede
    maquina-2 IN A 172.168.0.5 ; ip qualquer da rede
    são essas as confgurações alguem pode me dizer o q tem de errado pois qdo pingo recebo a seguinde mensagem:
    [email protected]:/etc# ping www.predador.eb.mil.br
    ping: unknown host www.predador.eb.mil.br
    não tenho ip valido estou tentado para usar numa rede domestica para compartilhar aqvo e internet
    uso slackware 10.2
    Padrão Re: dns no slackware 10.2
    Voce pos no seu resolv.conf o ip que roda seu dns??
    falows
    coloquei no resolv.conf e no resolv.conf.sv so q qdo reinicio a
    maquina o do resouv.conf some e fica o do meu modem adsl.
    Entao tem de por por adsl nao atualizar o resolv.conf, no slack nao sei como faz isso, pois so se o resolv.conf tiver pro seu bind que vai funcionar a rede interna, pingar e tals.
    falows
