    juniox
    seguinte, instalei o driver da nvidia numa boa... mas se no xorg.conf eu alterar onde tá "nv" pra "nvidia" (como fazia antes) ele não roda... =/
    aparece a seguinte mensagem de Erro:
    _XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6
    _XSERVTransOpen: transport open failed for inet6/localhost:0
    _XSERVTransMakeAllCOTSServerListeners: failed to open listener for inet6
    X Window System Version 6.8.2
    Release Date: 9 February 2005
    X Protocol Version 11, Revision 0, Release 6.8.2
    Build Operating System: Linux 2.6.13 i686 [ELF]
    Current Operating System: Linux localhost 2.4.31 #6 Sun Jun 5 19:04:47 PDT 2005 i686
    Build Date: 11 September 2005
    Before reporting problems, check http://wiki.X.Org
    to make sure that you have the latest version.
    Module Loader present
    Markers: (--) probed, (**) from config file, (==) default setting,
    (++) from command line, (!!) notice, (II) informational,
    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
    (==) Log file: "/var/log/Xorg.0.log", Time: Tue Feb 21 21:50:26 2006
    (==) Using config file: "/etc/X11/xorg.conf"
    *** If unresolved symbols were reported above, they might not
    *** be the reason for the server aborting.
    Fatal server error:
    Caught signal 11. Server aborting
    Please consult the The X.Org Foundation support
    at http://wiki.X.Org
    for help.
    Please also check the log file at "/var/log/Xorg.0.log" for additional information.
    XIO: fatal IO error 104 (Connection reset by peer) on X server ":0.0"
    after 0 requests (0 known processed) with 0 events remaining.
    tá faltando carregar algum módulo?
  2. cara no arquivo de log que ele mandou ver tem alguma coisa diferente??
    falows
  1. Problemas no Boot do RH8
    Respostas: 6
    Último Post: 20-12-2002, 16:17
  2. Problemas no IMP
    Por PandaAzul no fórum Servidores de Rede
    Respostas: 5
    Último Post: 11-12-2002, 09:53
  3. Respostas: 3
    Último Post: 27-11-2002, 08:56
  4. Problemas no UEBMIAU
    Por ediguedes no fórum Servidores de Rede
    Respostas: 8
    Último Post: 16-10-2002, 14:15
  5. problemas no squid
    Por roggy no fórum Servidores de Rede
    Último Post: 25-09-2002, 15:12
