    Padrão PHP no webmail
    Pessoal estou usando o webmail squirrelmail-1.4.5
    gostaria de colocar @meudominio.com.br depois do nome
    do usuário.
    Alguém ja fez isso e sabe em qual lugar devo mecher no
    login.php ?
    Padrão Re: PHP no webmail
    Opa e ai pessoal, aqui ta o meu login.php, como faço para adicionar o meu dominio aqui??
    att
    <?php
    * login.php -- simple login screen
    * Copyright (c) 1999-2005 The SquirrelMail Project Team
    * Licensed under the GNU GPL. For full terms see the file COPYING.
    * This a simple login screen. Some housekeeping is done to clean
    * cookies and find language.
    * @version $Id: login.php,v 1.98.2.8 2005/06/22 13:45:35 jangliss Exp $
    * @package squirrelmail
    * Path for SquirrelMail required files.
    * @ignore
    define('SM_PATH','../');
    /* SquirrelMail required files. */
    require_once(SM_PATH . 'functions/strings.php');
    require_once(SM_PATH . 'config/config.php');
    require_once(SM_PATH . 'functions/i18n.php');
    require_once(SM_PATH . 'functions/plugin.php');
    require_once(SM_PATH . 'functions/constants.php');
    require_once(SM_PATH . 'functions/page_header.php');
    require_once(SM_PATH . 'functions/html.php');
    require_once(SM_PATH . 'functions/global.php');
    require_once(SM_PATH . 'functions/forms.php');
    * $squirrelmail_language is set by a cookie when the user selects
    * language and logs out
    set_up_language($squirrelmail_language, TRUE, TRUE);
    * Find out the base URI to set cookies.
    if (!function_exists('sqm_baseuri')){
    require_once(SM_PATH . 'functions/display_messages.php');
    $base_uri = sqm_baseuri();
    * In case the last session was not terminated properly, make sure
    * we get a new one.
    sqsession_destroy();
    header('Pragma: no-cache');
    do_hook('login_cookie');
    $loginname_value = (sqGetGlobalVar('loginname', $loginname) ? htmlspecialchars($loginname) : '');
    /* Output the javascript onload function. */
    $header = "<script language=\"JavaScript\" type=\"text/javascript\">\n" .
    "<!--\n".
    " function squirrelmail_loginpage_onload() {\n".
    " document.forms[0].js_autodetect_results.value = '" . SMPREF_JS_ON . "';\n".
    " var textElements = 0;\n".
    " for (i = 0; i < document.forms[0].elements.length; i++) {\n".
    " if (document.forms[0].elements[i].type == \"text\" || document.forms[0].elements[i].type == \"password\") {\n".
    " textElements++;\n".
    " if (textElements == " . (isset($loginname) ? 2 : 1) . ") {\n".
    " document.forms[0].elements[i].focus();\n".
    " break;\n".
    " }\n".
    " }\n".
    " }\n".
    " }\n".
    "// -->\n".
    "</script>\n";
    $custom_css = 'none';
    displayHtmlHeader( "$org_name - " . _("lOGIN"), $header, FALSE );
    echo '<body text="#000000" bgcolor="#FFFFFF" link="#0000CC" vlink="#0000CC" alink="#0000CC" onload="squirrelmail_loginpage_onload();">' .
    "\n" . addForm('redirect.php', 'post');
    $username_form_name = 'login_username';
    $password_form_name = 'secretkey';
    do_hook('login_top');
    if(sqgetGlobalVar('mailto', $mailto)) {
    $rcptaddress = addHidden('mailto', $mailto);
    } else {
    $rcptaddress = '';
    /* If they don't have a logo, don't bother.. */
    if (isset($org_logo) && $org_logo) {
    /* Display width and height like good little people */
    $width_and_height = '';
    if (isset($org_logo_width) && is_numeric($org_logo_width) &&
    $org_logo_width>0) {
    $width_and_height = " width=\"$org_logo_width\"";
    if (isset($org_logo_height) && is_numeric($org_logo_height) &&
    $org_logo_height>0) {
    $width_and_height .= " height=\"$org_logo_height\"";
    echo html_tag( 'table',
    html_tag( 'tr',
    html_tag( 'td',
    '<center>'.
    ( isset($org_logo) && $org_logo
    ? '<img src="' . $org_logo . '" alt="' .
    sprintf(_("%s Logo"), $org_name) .'"' . $width_and_height .
    ' /><br />' . "\n"
    ( (isset($hide_sm_attributions) && $hide_sm_attributions) ? '' :
    '<small>' . sprintf (_("Compy Network Solution Provider"), $version) . '<br />' ."\n".
    ' ' . _("Pensou em Soluções Rede") . '<br />' . 'Pensou em compy...' . '</small>' . "\n" ) .
    html_tag( 'table',
    html_tag( 'tr',
    html_tag( 'td',
    '<b>' . sprintf (_("%s"), $org_name) . "</b>\n",
    'center', '#DCDCDC' )
    html_tag( 'tr',
    html_tag( 'td', "\n" .
    html_tag( 'table',
    html_tag( 'tr',
    html_tag( 'td',
    _("Usuário:") ,
    'right', '', 'width="30%"' ) .
    html_tag( 'td',
    addInput($username_form_name, $loginname_value),
    'left', '', 'width="*"' )
    ) . "\n" .
    html_tag( 'tr',
    html_tag( 'td',
    _("Senha:") ,
    html_tag( 'td',
    addPwField($password_form_name).
    addHidden('js_autodetect_results', SMPREF_JS_OFF).
    $rcptaddress .
    addHidden('just_logged_in', '1'),
    'center', '#ffffff', 'border="0" width="100%"' ) ,
    'left', '#FFFFFF' )
    html_tag( 'tr',
    html_tag( 'td',
    '<center>'. addSubmit(_("Entrar")) .'</center>',
    'left' )
    '', '#ffffff', 'border="0" width="350"' ) . '</center>',
    'center' )
    '', '#ffffff', 'border="0" cellspacing="0" cellpadding="0" width="100%"' );
    do_hook('login_form');
    echo '</form>' . "\n";
    do_hook('login_bottom');
    </body></html>
    Bom, no Debian pelo menos existe um script que configura o Squirrelmail inteiro chamado squirrelmail-configure, entretanto, ele chama um script chamado conf.pl.
    Abraços pra ti!
    Não é isso amigo, sei configurar o squirrel r tudo mais, mas não sei php, to usando uma solução do postfix com dominios virtuais, e para os usuários não precisarem escrever usuario@meudominio.com.br, queria saber como faço para adicionar o @meudominio.com.br automaticamnete.
    Ok
    att
