    antoniaze
    Padrão Squid No brasileiro mesmo SOCORROOOO.
    Boa tarde moçada, e o seguinte estou com pane no squid.
    que da esta mensagen quando inicia.
    Failed to start Squid :
    criando diretórios de swap, espere... 2006/02/23 22:23:46| parseConfigFile: line 4 unrecognized: ' cache_men 32 MB'
    2006/02/23 22:23:46| parseConfigFile: line 12 unrecognized: ' refresh_pattem ^ftp: 15 20% 2280'
    2006/02/23 22:23:46| parseConfigFile: line 13 unrecognized: ' refresh_pattem ^gopher: 15 0% 2280'
    2006/02/23 22:23:46| parseConfigFile: line 14 unrecognized: ' refresh_pattem. 15 20% 2280'
    2006/02/23 22:23:46| squid.conf line 41: acl proibidos dstom_regex "/etc/squid/proibidos"
    2006/02/23 22:23:46| aclParseAclLine: Invalid ACL type 'dstom_regex'
    2006/02/23 22:23:46| squid.conf line 42: http_access deny proibidos
    2006/02/23 22:23:46| aclParseAccessLine: ACL name 'proibidos' not found.
    2006/02/23 22:23:46| aclParseAccessLine: Access line contains no ACL's, skipping
    FATAL: /usr/bin/squid/nsca_auth: (2) No such file or directory
    Squid Cache (Version 2.5.STABLE1): Terminated abnormally.
    CPU Usage: 0.020 seconds = 0.020 user + 0.000 sys
    Maximum Resident Size: 0 KB
    Page faults with physical i/o: 318
    [FALHOU]
    Iniciando squid 2006/02/23 22:23:46| parseConfigFile: line 4 unrecognized: ' cache_men 32 MB'
    CPU Usage: 0.030 seconds = 0.010 user + 0.020 sys
    /etc/rc.d/init.d/squid: line 118: 2530 Aborted $SQUID
    [FALHOU]
    Alguem por favor me ajuda.
    antoniaze
    Padrão Re: Squid No brasileiro mesmo SOCORROOOO.
    Citação Postado originalmente por antoniaze
    [FALHOU]
    [FALHOU]
    Este e o squid.conf
    http_port 3128
    visible_hostname proxy55
    cache_men 32 MB
    maximum_object_size_in_memory 64 KB
    maximum_object_size 512 MB
    minimum_object_size 0 KB
    cache_swap_low 90
    cache_swap_high 95
    cache_dir ufs /var/spool/squid 2048 16 256
    acl all src 0.0.0.0/0.0.0.0
    acl localhost src 127.0.0.1/32
    acl SSL_ports port 443 563
    acl Safe_ports port 80
    acl Safe_ports port 21
    acl Safe_ports port 443 563
    acl Safe_ports port 70
    acl Safe_ports port 210
    acl Safe_ports port 1025-65535
    acl Safe_ports port 280
    acl Safe_ports port 488
    acl Safe_ports port 591
    acl Safe_ports port 777
    acl Safe_ports port 901
    acl purge method PURGE
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny purge
    http_access deny !Safe_ports
    http_access deny CONNECT !SSL_Ports
    acl bloqueados dstdomain Orkut.com. www.orkut.co playboy.abril.com.br
    http_access deny bloqueados
    acl redelocal src 10.0.0.0/32
    http_access allow localhost
    http_access allow redelocal
    http_access deny all
    auth_param basic program /usr/bin/squid/nsca_auth /etc/squid/squid_passwd
    acl autenticados proxy_auth REQUIRED
    http_access allow Autenticados
    http_accel_host virtual
    http_accel_port 80
    http_accel_with_proxy on
    http_accel_uses_host_header on
    httpd_accel_with_proxy on
    cache_dir ufs /var/spool/squid 100 16 256
    wellington2
    Me parece que vc tem ai um squid que esta fazendo referencias que não existem mais um conselho que eu tenho pra te dar é copia este squid pra uma outra pasta e em seguida desinstala ele e depois instala novamente e reconfigura linha por linha e nai testando a cada linha ja tive um problema como este antes o squid ficou louco de um ahora pra outra e eu não consegui descobri qual foi o problema então fiz isso..vc esta tambem altenticando usuarios dentro do squid procura ver se estes usuarios que estão cadastrados não foram excluidos.
    Primeira coisa e resolver sao essas acls que tao erradas, por exemplo:
    sites: acl proibir_sites dstdomain "/etc/squid/sites"
    palavras: acl proibir_palavras url_regex -i "/etc/squid/palavras"
    ncsa_auth: primeiro deu um find / - name ncsa_auth pra saber a verdadeira localizaçao do arquivo, depois coloque no squid esse caminho.
    Tanto no arquivo palavras quanto no sites voce deve colocar um por linha, e dar permissao de leitura chmod +x /etc/squid/palavras e chmod +x /etc/squid/sites
    Faça isso e depois poste os resultados, o mais importante e saber identificar e resolver os problemas !!!
    Abraçao
    Olha um dos erros:
    "4 unrecognized: ' cache_men 32 MB'"
    O correto é "cache_mem 32 mb"
