  1. Bom dia galerix,
    Eu estou com um servidor rolando o proftpd e o que esta acontecendo é que eu estou com um escript em anexo que cria usuarios de ftp, só que esse não funciona, sendo que em outro servidor meu esta normal e funciona certinho.
    A unica coisa que funciona é com usuario criado diretamente na maquina.
    Segue em anexo o arquivo que cria usuario e também o arquivo de configurar do proftpd
    []´s
    Nilson
    # /etc/proftpd.conf -- This is a basic ProFTPD configuration file.
    # To really apply changes reload proftpd after modifications.
    ServerName "EDUMED"
    ServerType standalone
    DeferWelcome off
    MultilineRFC2228 on
    DefaultServer on
    ShowSymlinks on
    TimeoutNoTransfer 600
    TimeoutStalled 600
    TimeoutIdle 1200
    DisplayLogin welcome.msg
    DisplayFirstChdir .message
    ListOptions "-l"
    DenyFilter \*.*/
    # Uncomment this if you are using NIS or LDAP to retrieve passwords:
    #PersistentPasswd off
    # Uncomment this if you would use TLS module:
    #TLSEngine on
    # Uncomment this if you would use quota module:
    #Quotas on
    # Uncomment this if you would use ratio module:
    #Ratios on
    # Port 21 is the standard FTP port.
    Port 21
    # To prevent DoS attacks, set the maximum number of child processes
    # to 30. If you need to allow more than 30 concurrent connections
    # at once, simply increase this value. Note that this ONLY works
    # in standalone mode, in inetd mode you should use an inetd server
    # that allows you to limit maximum number of processes per service
    # (such as xinetd)
    MaxInstances 30
    # Set the user and group that the server normally runs at.
    User nobody
    Group nogroup
    # Umask 022 is a good standard umask to prevent new files and dirs
    # (second parm) from being group and world writable.
    Umask 022 022
    # Normally, we want files to be overwriteable.
    AllowOverwrite on
    # Delay engine reduces impact of the so-called Timing Attack described in
    # http://security.lss.hr/index.php?pag...LSS-2004-10-02
    # It is on by default.
    #DelayEngine off
    # A basic anonymous configuration, no upload directories.
    # <Anonymous ~ftp>
    # User ftp
    # Group nogroup
    # # We want clients to be able to login with "anonymous" as well as "ftp"
    # UserAlias anonymous ftp
    # # Cosmetic changes, all files belongs to ftp user
    # DirFakeUser on ftp
    # DirFakeGroup on ftp
    # RequireValidShell off
    # # Limit the maximum number of anonymous logins
    # MaxClients 10
    # # We want 'welcome.msg' displayed at login, and '.message' displayed
    # # in each newly chdired directory.
    # DisplayLogin welcome.msg
    # DisplayFirstChdir .message
    # # Limit WRITE everywhere in the anonymous chroot
    # <Directory *>
    # <Limit WRITE>
    # DenyAll
    # </Limit>
    # </Directory>
    # # Uncomment this if you're brave.
    # # <Directory incoming>
    # # # Umask 022 is a good standard umask to prevent new files and dirs
    # # # (second parm) from being group and world writable.
    # # Umask 022 022
    # # <Limit READ WRITE>
    # # DenyAll
    # # </Limit>
    # # <Limit STOR>
    # # AllowAll
    # # </Limit>
    # # </Directory>
    # </Anonymous>
  2. Kra... reveja seu script e verifique se ele tem um interpretador padrão!!
    Pelo menos no arquivo que vc anexou, não tem!!
    Um abc
    mtec :-)
  1. Problema para limitar conexão por usuário
    Por andunno no fórum Servidores de Rede
    Respostas: 5
    Último Post: 10-05-2007, 17:47
  2. Respostas: 7
    Último Post: 25-01-2007, 07:42
  3. Problema para adicionar usuário no LDAP
    Último Post: 14-12-2006, 17:07
  4. Configurar procmail para dois usuarios e dominios diferentes
    Por _edinh0_ no fórum Servidores de Rede
    Último Post: 21-02-2003, 15:07
  5. Problema para instalar o openssh
    Último Post: 22-11-2002, 14:06
