Pessoal , isso ta mi ferrando.
Tenho um desktop que esta com o kurumin,
Quando o mesmo inicia, aparece a mensagem. Checking rot file system
fsck 1.37 (21-mar-2005)
fsck.ext2: Is a directory while trying to open /
The superblock could ext2 filesystem
If the device is valid and it really contains an ext2 filesystem (and not swap or ufs or something else), then the superblock is corrupt and you might try running e2fsck with an alternative superblock:
e2fsck -b 8193 <device>
fsck falied. Please repair manually and rebot. Please note that the root filesystem is currently mounted read-only.
to remount it read-write.
Ja passei e2fsck -b 8193 /dev/hda2 e nada.
Dou <enter> e nao vai.
A particao na verdade eh reiserfs e nao sei porque diz ser ext2.
O que fazer ?
			 erro no disco Kurumin   - RESOLVIDO
						 Citação
  Citação
