    duker
    Padrão ALI5455 no kernel 2.6.16.1 #UPDATED
    Tah dando esse erro ao carregar o rc.alsa
    Loading ALSA mixer settings: /usr/sbin/alsactl restore
    /usr/sbin/alsactl: load_state:1267: No soundcards found...
    Loading OSS compatibility modules for ALSA.
    FATAL: Module snd_pcm_oss not found.
    FATAL: Module snd_mixer_oss not found.
    e se tentar abrir o alsamixer dah nisso:
    alsamixer: function snd_ctl_open failed for default: No such file or directory
    se eu uso (o mais óbvio_) alsaconf, ele afirma ter encontrado o driver da placa de som usando o modulo:
    "intel8x0 Ali Corporation M5455 PCI AC-Link Controler Audio Device "
    dai eu coloco que OK depois aparece isso
    "Configuring snd-intel8x0
    Do you want to modify /etc/modprobe.conf ?"
    Coloco q sim e
    Now ALSA is ready to use.
    For adjustment of volumes, use your favorite mixer.
    Have a lot of fun!
    FUN ?! rsrs
    Por favor ajudem me a ouvir musica aki plz !!!
    To mandando o script rc.alsa e o modproble.conf
    plz se precisarem de + alguma informação naum desistam de mim... perguntem plz
    duker
    Padrão Re: ALI5455 no kernel 2.6.16.1 #UPDATED
    se eu tento tb tocar alguma coisa dah nisso:
    [email protected]:/mnt/sata1/mp3# mpg123 flyingbeans_fiz.mp3
    ALSA lib confmisc.c:550snd_determine_driver) could not open control for card 0
    ALSA lib conf.c:3463_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
    ALSA lib confmisc.c:387snd_func_concat) error evaluating strings
    ALSA lib conf.c:3463_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
    ALSA lib confmisc.c:945snd_func_refer) error evaluating name
    ALSA lib conf.c:3463_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
    ALSA lib conf.c:3932snd_config_expand) Evaluate error: No such file or directory
    ALSA lib pcm.c:2068snd_pcm_open_noupdate) Unknown PCM default
    No default libao driver available.
