- SENAO 2511
SENAO 2511
Não vi ninguém mencionar nos tópicos anteriores, então estou postando:
CARTÂO SENÃO 2511, não funciona criptografia WEP adequadamente no MT. Principalmente com placas clientes DLINK e Samsung.
No manual está assim:
"Prism card doesn't report that the use of WEP is required for all data type frames, which means that
some clients will not see that access point uses encryption and will not be able to connect to such
AP. This is a Prism hardware problem and can not be fixed. Use Atheros-based cards (instead of
Prism) on APs if you want to provide WEP in your wireless network."
Re: SENAO 2511
É realmente Sergio, se ligo o WEP os D-Link nem acham o AP...
Mas também acho que ninguem usa WEP mais mesmo, e WPA funfa legal!
