Amigos,
To precisando configurar um DNS Interno e tha dando erro ao seguinte comando:
#service named stop
rndc: connect failed: connection refused
Quando mando startart não faz nada:
#service named start
Iniciando named: [FALHOU]
O log mostra:
[root@srv-02 mail]# tail -v /var/log/messages
==> /var/log/messages <==
Apr 18 14:20:14 srv-02 named: named shutdown failed
Apr 18 14:21:35 srv-02 named[8538]: starting BIND 9.2.3 -u named -t /var/named
Apr 18 14:21:35 srv-02 named[8538]: using 1 CPU
Apr 18 14:21:35 srv-02 named[8538]: loading configuration from '/etc/named.conf'
Apr 18 14:21:35 srv-02 named[8538]: no IPv6 interfaces found
Apr 18 14:21:35 srv-02 named[8538]: listening on IPv4 interface lo, 127.0.0.1#53
Apr 18 14:21:35 srv-02 named[8538]: listening on IPv4 interface eth0, 192.168.0.2#53
Apr 18 14:21:35 srv-02 named[8538]: could not configure root hints from 'root.cache': file not found
Apr 18 14:21:35 srv-02 named[8538]: loading configuration: file not found
Apr 18 14:21:35 srv-02 named[8538]: exiting (due to fatal error)
Não encontro nenhuma explicação para resolver este erro!
O meu conf:
###############INICIO################
options {
directory "/var/named";
logging {
category lame-servers { null; };
category cname { null; };
zone "dominio.com.br" in {
type master;
file "named.hosts";
zone "0.168.192.in-addr.arpa" in {
type master;
file "named.reverse";
zone "." in {
type hint;
file "root.cache";
zone "0.0.127.in-addr.arpa" in {
type master;
file "named.local";
zone "teste1.com.br" in {
notify no;
type master;
file "qualquercoisa.hosts";
zone "teste2.com.br" in {
notify no;
type master;
zone "teste3.com.br" in {
notify no;
type master;
###############FIM################
E o arquivo qualquercoisa.hosts:
$TTL 86400
@ IN SOA dominio.com.br.
webmaster.dominio.com.br. (
2002101905; serial
3600 ; refresh
900 ; retry
1209600 ; expire
43200 ; default_ttl
@ IN NS dominio.com.br.
;Section 3 - hosts-to-IP addrs
@ IN A 192.168.0.2
www IN A 192.168.0.2
pop3 IN A 192.168.0.2
smtp IN A 192.168.0.2
#############FIM#################
Alguém jah teve este problema?
Como faço para resolver isso??
Desde já agradeço a atenção de todos,
Marcelo Oliveira
Citação
