    mceiras
    Padrão kde, dependecia e apt-get
    Ola!
    Fui colocar o kde no ubuntu para rodar alguns programas dele, mas como fui dar apt-get eu interrompi logo no comeco com ctrl+c, depois quando fui fazer de novo ele não consegue montar e baixar as dependencias dando deu a seguinte msg:
    ps. Ja tentei o apt-get build-dep kde baixou algumas bibliotecas e nada.
    Ja tentei autoclean, check, clean e nada =(
    No google achei muita gente perguntando, mas nenhuma resposta que funcione...
    [email protected]:/etc/apt# apt-get install kde
    Reading package lists... Done
    Building dependency tree... Done
    Some packages could not be installed. This may mean that you have
    requested an impossible situation or if you are using the unstable
    distribution that some required packages have not yet been created
    or been moved out of Incoming.
    Since you only requested a single operation it is extremely likely that
    the package is simply not installable and a bug report against
    that package should be filed.
    The following information may help to resolve the situation:
    The following packages have unmet dependencies:
    kde: Depends: kdesdk but it is not going to be installed
    E: Broken packages
    Padrão Re: kde, dependecia e apt-get
    apt-get -f update
    apt-get -f upgrade ou caso vc esteja atualizando a versao do sistema apt-get -f dist-upgrade
