    Padrão Antispam Iniciando + Relay Aberto QMAIL
    Galera, começou dar o ar da graça as configurações que eu fiz no servidor do cara.
    PORÉM ,
    Ao mandar enviar e receber com o Thunderbird continua vindo os SPAMS.
    A unica diferença é que consta essa informação abaixo na mesma agora. Mas no servidor não excluiu automaticamente
    Preciso fechar o relay porque eu testei e está aberto
    QMAIL + Relay (OPEN).
    Spam detection software, running on the system "vps7320.MEUSERVER.net", has
    identified this incoming email as possible spam. The original message
    has been attached to this so you can view it (if it isn't spam) or block
    similar future email. If you have any questions, see
    the administrator of that system for details.
    Content preview: Nova pagina 1
    URI:http://www.multcarpo.com.br/rec_mult.htm Recurso de multa de
    trânsito com fundamento jurídico.
    URI:http://www.multcarpo.com.br/imagens/panfleto2.jpg [...]
    Content analysis details: (9.4 points, 5.0 required)
    pts rule name description
    1.0 DATE_MISSING Missing Date: header
    2.0 BR_FROM_KEYS From com a palavras-chave
    0.5 BR_RECEIVED_SPAMMER Received com endereco DSL ou Dial-Up de Spammers
    0.0 HTML_MESSAGE BODY: HTML included in message
    0.1 HTML_70_80 BODY: Message is 70% to 80% HTML
    0.1 MIME_HTML_ONLY BODY: Message only has text/html MIME parts
    2.2 HTML_IMAGE_ONLY_02 BODY: HTML: images with 0-200 bytes of words
    1.6 FRONTPAGE BODY: Frontpage used to create the message
    0.7 MIME_HTML_NO_CHARSET RAW: Message text in HTML without charset
    1.1 NO_DNS_FOR_FROM Domain in From header has no MX or A DNS records
    The original message was not completely plain text, and may be unsafe to
    open with some email clients; in particular, it may contain a virus,
    or confirm that your address can receive spam. If you wish to view
    it, it may be safer to save it to a file and open it with an editor.
    _________________
    Padrão Re: Antispam Iniciando + Relay Aberto QMAIL
    Instala o patch SMTP-Auth que resolve.
    Abraços!
    O problema velho é que não tem nesse servidor os pacotes onde foi compilado o qmail
    Varri ele todo e num tem.
    Eu fiz um teste e olha so
    essoal, fiz um teste com para verificar o relay e o mesmo foi aceito.
    O ultimo teste foi aceito.
    Alguem ja conseguiu corrigir ?
    :Relay test: #test 3
    >>> mail from: <[email protected]>
    <<< 250 ok
    >>> rcpt to: <[email protected]>
    <<< 553 sorry, that domain isn't in my list of allowed rcpthosts (#5.7.1)
    >>> rset
    <<< 250 flushed
    :Relay test: #Test 4
    >>> mail from: <spamtest>
    <<< 250 ok
    >>> rset
    <<< 250 flushed
    :Relay test: #Test 5
    >>> mail from: <>
    <<< 250 ok
    >>> rset
    <<< 250 flushed
    :Relay test: #Test 6
    <<< 250 ok
    >>> rset
    <<< 250 flushed
    :Relay test: #Test 7
    >>> mail from: <[email protected][67.15.153.63]>
    <<< 250 ok
    >>> rset
    <<< 250 flushed
    :Relay test: #Test 8
    <<< 250 ok
    >>> rcpt to: <nobody%[email protected]>
    >>> rset
    <<< 250 flushed
    :Relay test: #Test 9
    <<< 250 ok
    >>> rcpt to: <nobody%[email protected][67.15.153.63]>
    >>> rset
    <<< 250 flushed
    :Relay test: #Test 10
    <<< 250 ok
    >>> rcpt to: <"[email protected]">
    >>> rset
    <<< 250 flushed
    :Relay test: #Test 11
    <<< 250 ok
    >>> rcpt to: <"nobody%mail-abuse.org">
    <<< 250 ok
    >>> QUIT
    <<< 221 srv34.MEUDOMINIO.com.br
    _________________
    Recompila o qmail então. Os sources tu pode encontrar em http://cr.yp.to
    Abraços.
    vou ver isso e tb como fazer com os 80 dominios que tem nele
    Dando um ps -efw | grep qmail
    qmails 22863 1 0 May08 ? 00:00:12 qmail-send
    qmaill 22865 22863 0 May08 ? 00:00:01 splogger qmail
    root 22866 22863 0 May08 ? 00:00:01 qmail-lspawn ./Maildir/
    qmailr 22867 22863 0 May08 ? 00:00:00 qmail-rspawn
    qmailq 22868 22863 0 May08 ? 00:00:01 qmail-clean
    popuser 22937 1 0 May08 ? 00:00:26 /usr/bin/spamd --username=popuser --daemonize --helper-home-dir=/var/qmail --max-children 20 --pidfile=/var/run/spamd/spamd_full.pid --socketpath=/tmp/spamd_full.sock
    popuser 22946 1 0 May08 ? 00:00:02 /usr/bin/spamd --username=popuser --daemonize --helper-home-dir=/var/qmail --max-children 20 --pidfile=/var/run/spamd/spamd_light.pid --socketpath=/tmp/spamd_light.sock
    qmaild 17086 22661 0 22:46 ? 00:00:00 /var/qmail/bin/qmail-smtpd /var/qmail/bin/smtp_auth /var/qmail/bin/true /var/qmail/bin/cmd5checkpw /var/qmail/bin/true
    qmaild 17187 22661 0 22:46 ? 00:00:00 /var/qmail/bin/qmail-smtpd /var/qmail/bin/smtp_auth /var/qmail/bin/true /var/qmail/bin/cmd5checkpw /var/qmail/bin/true
    qmaild 17209 22661 0 22:47 ? 00:00:00 /var/qmail/bin/qmail-smtpd /var/qmail/bin/smtp_auth /var/qmail/bin/true /var/qmail/bin/cmd5checkpw /var/qmail/bin/true
    qmailr 17255 22867 0 22:47 ? 00:00:00 qmail-remote superbweb.com [email protected]
    qmailr 17261 22867 0 22:47 ? 00:00:00 qmail-remote vcsmco.org [email protected]
    root 17266 22661 0 22:47 ? 00:00:00 /usr/sbin/rblsmtpd -r DOMINIO.com.br -r kontacto.com.br /var/qmail/bin/relaylock /var/qmail/bin/qmail-smtpd /var/qmail/bin/smtp_auth /var/qmail/bin/true /var/qmail/bin/cmd5checkpw /var/qmail/bin/true
    root 17270 22661 0 22:47 ? 00:00:00 tcp-env /usr/sbin/rblsmtpd -r DOMINIO.com.br -r kontacto.com.br /var/qmail/bin/relaylock /var/qmail/bin/qmail-smtpd /var/qmail/bin/smtp_auth /var/qmail/bin/true /var/qmail/bin/cmd5checkpw /var/qmail/bin/true
    root 17272 22661 0 22:47 ? 00:00:00 /usr/sbin/rblsmtpd -r DOMINIO.com.br -r kontacto.com.br /var/qmail/bin/relaylock /var/qmail/bin/qmail-smtpd /var/qmail/bin/smtp_auth /var/qmail/bin/true /var/qmail/bin/cmd5checkpw /var/qmail/bin/true
    root 17274 22661 0 22:47 ? 00:00:00 /usr/sbin/rblsmtpd -r DOMINIO.com.br -r kontacto.com.br /var/qmail/bin/relaylock /var/qmail/bin/qmail-smtpd /var/qmail/bin/smtp_auth /var/qmail/bin/true /var/qmail/bin/cmd5checkpw /var/qmail/bin/true
    root 17276 22661 0 22:47 ? 00:00:00 /usr/sbin/rblsmtpd -r DOMINIO.com.br -r kontacto.com.br /var/qmail/bin/relaylock /var/qmail/bin/qmail-smtpd /var/qmail/bin/smtp_auth /var/qmail/bin/true /var/qmail/bin/cmd5checkpw /var/qmail/bin/true
    root 17277 22661 0 22:47 ? 00:00:00 /usr/sbin/rblsmtpd -r DOMINIO.com.br -r kontacto.com.br /var/qmail/bin/relaylock /var/qmail/bin/qmail-smtpd /var/qmail/bin/smtp_auth /var/qmail/bin/true /var/qmail/bin/cmd5checkpw /var/qmail/bin/true
    root 17278 22661 0 22:47 ? 00:00:00 tcp-env /usr/sbin/rblsmtpd -r DOMINIO.com.br -r kontacto.com.br /var/qmail/bin/relaylock /var/qmail/bin/qmail-smtpd /var/qmail/bin/smtp_auth /var/qmail/bin/true /var/qmail/bin/cmd5checkpw /var/qmail/bin/true
