  1. Gente configurei o DNS daqui e ta funcionando quando chamo www.accesspower.com.br ele acessa o apache normal, da tentei criar um servidor de email e descobri que meu reverso naum ta normal quando testo ele no www.terra.com.br/postmaster da o seguinte erro
    ERRO
    $ host 200.223.252.243
    Host 243.252.223.200.in-addr.arpa not found: 3(NXDOMAIN)
    Segue abaixo meus arquivos de acordo com oque a telemar mandou preciso muito de ajuda.
    named.conf
    options {
    directory "/var/named";
    allow-transfer{
    200.223.252.243;
    listen-on{
    200.223.252.243;
    127.0.0.1;
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    */ version "[EF DNS SERVER]";
    query-source address * port 53;
    dump-file "/var/named/dump/named_dump.db";
    statistics-file "/var/named/dump/named.stats";
    // a shared secret for the rndc tool
    // this key must be the same one that is in the
    // /etc/rndc.conf file
    key key_rndc{
    algorithm "hmac-md5";
    secret "kZpfpfxdUYkuHRKHkd5n4g==";
    // a control channel for the new rndc tool
    controls{
    inet 127.0.0.1 allow{
    localhost;
    } keys{
    key_rndc;
    zone "." {
    type hint;
    file "named.ca";
    zone "accesspower.com.br" {
    type master;
    file "accesspower.com.br.db";
    zone "0.0.127.in-addr.arpa" {
    type master;
    file "named.local";
    zone "240-247.252.223.200.IN-ADDR.ARPA" {
    type master;
    file "accesspower.com.br.rev";
    Meu accesspower.com.br.db
    accesspower.com.br. IN SOA ns1.accesspower.com.br. root.ns1.accesspower.com.br. (
    2006031001 ; serial
    1D ; refresh
    1H ; retry
    1000H ; expire
    1H ; default_ttl
    accesspower.com.br. IN A 200.223.252.243
    accesspower.com.br. IN NS ns1.accesspower.com.br.
    accesspower.com.br. IN MX 5 mx.accesspower.com.br.
    www IN A 200.223.252.243
    ftp IN A 200.223.252.243
    mx IN A 200.223.252.243
    ns1 IN A 200.223.252.243
    Meu accesspower.com.br.rev
    @ORIGIN 240-247.252.223.200.in-addr.arpa.
    @ IN SOA www.accesspower.com.br. suporte.accesspower.com.br (
    200605107u ; serial
    1D ; refresh
    1H ; retry
    1000H ; expire
    1H ; default_ttl
    IN NS ns4.telemar.net.br.
    IN NS ns2.telemar.net.br.
    243 IN PTR HYPERLINK "http://ns1.accesspower.com.br/
    "ns1.accesspower.com.br
    Meu named.local
    @ IN SOA localhost. root.localhost. (
    2006050812 ; Serial
    28800 ; Refresh
    14400 ; Retry
    3600000 ; Expire
    86400 ) ; Minimum
    IN NS localhost.
  2. Faltou o setup de um PTR record apontando de volta:
    243.240-247.252.223.200.in-addr.arpa. in PTR accesspower.com.br
  3. Citação Postado originalmente por cybersank
    200605107u ; serial
    1D ; refresh
    1H ; retry
    1000H ; expire
    1H ; default_ttl
    ;coloquei a alteração aqui abaixo
    Agora na consulta de IP reverso da o seguinte erro.
    $ host 243.252.223.200
    Host 200.223.252.243.in-addr.arpa not found: 3(NXDOMAIN)
  4. Amigo, o DNS reverso, tem que ser cadastrado também pelo provedor do seu link.
    Mesmo que vc consiga resolver na sua maquina linux no local, a consulta no terra vai retornar dns reverso incorreto.
    att
    Luiz
  5. Citação Postado originalmente por cunhajr
    att
    Luiz
    Sim mais foi a telemar que mandou eu testar lá, ha telemar me pessou as informações do reverso e mandou testar lá, agora naum intendi.?
  1. Respostas: 5
    Último Post: 20-09-2014, 22:12
  2. DNS da Erro
    Por uoquisala no fórum Servidores de Rede
    Último Post: 15-07-2005, 10:45
  3. shapecfg - 2 interfaces dá erro
    Por vandemberg no fórum Servidores de Rede
    Último Post: 19-09-2003, 11:36
  4. Cdrw não consigo gravar da erro ?
    Último Post: 26-04-2003, 14:30
  5. DNS Pirado - Ip Reverso
    Último Post: 27-11-2002, 01:15
