    Padrão /var/log/messages
    Pessoal, bom dia...
    fui verificar os logs do meu firewall / proxy, e encontrei umas mensagens muito estranhas sempre repetindo, alguem sabe me dizer o que poderiam ser essas mensagens ??
    olhem ae:
    #May 9 08:02:44 SF-TANG squid[1251]: Squid Parent: child process 1253 exited due to signal 6
    #May 9 08:02:47 SF-TANG squid[1251]: Squid Parent: child process 1329 started
    #May 9 08:04:07 SF-TANG (squid): ipcache_init: DNS name lookup tests failed.
    #May 9 08:04:07 SF-TANG squid[1251]: Squid Parent: child process 1329 exited due to signal 6
    #May 9 08:04:10 SF-TANG squid[1251]: Squid Parent: child process 1341 started
    #May 9 08:05:31 SF-TANG (squid): ipcache_init: DNS name lookup tests failed.
    #May 9 08:05:31 SF-TANG squid[1251]: Squid Parent: child process 1341 exited due to signal 6
    #May 9 08:05:34 SF-TANG squid[1251]: Squid Parent: child process 1352 started
    #May 9 08:06:54 SF-TANG (squid): ipcache_init: DNS name lookup tests failed.
    #May 9 08:06:54 SF-TANG squid[1251]: Squid Parent: child process 1352 exited due to signal 6
    #May 9 08:06:57 SF-TANG squid[1251]: Squid Parent: child process 1363 started
    #May 9 08:08:17 SF-TANG (squid): ipcache_init: DNS name lookup tests failed.
    #May 9 08:08:17 SF-TANG squid[1251]: Squid Parent: child process 1363 exited due to signal 6
    #May 9 08:08:20 SF-TANG squid[1251]: Squid Parent: child process 1380 started
    #May 9 08:08:31 SF-TANG kdm_config[1497]: Unrecognized key 'AllowShutdown' at /usr/lib/kde3/share/config/kdm/kdmrc:22
    #May 9 08:08:31 SF-TANG kdm_config[1497]: Unrecognized key 'Language' at /usr/lib/kde3/share/config/kdm/kdmrc:59
    #May 9 08:09:40 SF-TANG (squid): ipcache_init: DNS name lookup tests failed.
    #May 9 08:09:40 SF-TANG squid[1251]: Squid Parent: child process 1380 exited due to signal 6
    #May 9 08:09:43 SF-TANG squid[1251]: Squid Parent: child process 1508 started
    #May 9 08:11:03 SF-TANG (squid): ipcache_init: DNS name lookup tests failed.
    #May 9 08:11:03 SF-TANG squid[1251]: Squid Parent: child process 1508 exited due to signal 6
    #May 9 08:11:06 SF-TANG squid[1251]: Squid Parent: child process 1513 started
    Padrão Re: /var/log/messages
    bem, tua maquina deve ter o squid instalado... entao... ele está funcionando perfeitamente????
    pois, meu proxy já deu algum erro desse.... e foi quando eu fui reiniciar o servico, pois eu estava com a interface da lan desligada.
    só pra saber... para o squid e depois inicia denovo, veja se vai dar algum erro.
    qual a distro do linux q vc tah usando???
    Tipo é proxy tb aquele servidor, o negocio é q é proxy transparente, e caso ele tivesse com algum problema o pessoal nao tava acessando site nenhum né....
    mas vou dar um restart no squid, e ja retorno....
    meu linux é Conectiva 10...
    Olha não sei ao certo o q esta acontecendo, mas de uma coisa tenho certeza.
    Ele não esta funcionando perfeitamente não, vc pode não estar percebendo mas seu squid esta com erro, ou alguma coisa causando erro no squid.
    Tente ver seu dns pois ele esta tentando fazer um teste de dns, e não esta conseguindo. Ou então tente rodar o squid sem fazer esse teste de resolução de nomes.
    T+
    E como q eu rodo o squid em fazer teste de resoluçao de nomes ?? vc sabe me explicar??
    se nao me engano é
    squid -D
    voce pode rodar ele em debug mode
    squid -X
    ai vc ve oq ta dando de errado
    []'s
    Ae, olhei no help do squid e é squid -D mesmo, tipo fiz o esquema de desabilitar a resoluçao do DNS, agora vou ver se meu problema vai ser resolvido....
    pessoal valeu ae
