    Padrão A saga: pptp não conecta!!
    Caros colegas,
    olhando o tutorial em http://www.dicas-l.com.br/dicas-l/20030710.php e tentando solucionar meu problema com pptp, instalei do http://pptpclient.sourceforge.net o pptp e estou tentando conectar mas nao consigo. Diferentemente do que esta mencionado no artigo, o arquivo options do pptp nao é o /etc/ppp/options e sim o /etc/ppp/options.pptp que tem o seguinte conteudo:
    # $Id: options.pptp,v 1.1 2005/02/18 01:40:23 quozl Exp $
    # Sample PPTP PPP options file /etc/ppp/options.pptp
    # Options used by PPP when a connection is made by a PPTP client.
    # This file can be referred to by an /etc/ppp/peers file for the tunnel.
    # Changes are effective on the next connection. See "man pppd".
    # You are expected to change this file to suit your system. As
    # packaged, it requires PPP 2.4.2 or later from http://ppp.samba.org/
    # and the kernel MPPE module available from the CVS repository also on
    # http://ppp.samba.org/, which is packaged for DKMS as kernel_ppp_mppe.
    # Lock the port
    lock
    # Authentication
    # We don't need the tunnel server to authenticate itself
    noauth
    # We won't do EAP, CHAP, or MSCHAP, but we will accept MSCHAP-V2
    refuse-eap
    refuse-chap
    refuse-mschap
    # Compression
    # Turn off compression protocols we know won't be used
    nobsdcomp
    nodeflate
    # Encryption
    # (There have been multiple versions of PPP with encryption support,
    # choose with of the following sections you will use. Note that MPPE
    # requires the use of MSCHAP-V2 during authentication)
    # http://ppp.samba.org/ the PPP project version of PPP by Paul Mackarras
    # ppp-2.4.2 or later with MPPE only, kernel module ppp_mppe.o
    # Require MPPE 128-bit encryption
    require-mppe-128
    # http://polbox.com/h/hs001/ fork from PPP project by Jan Dubiec
    # ppp-2.4.2 or later with MPPE and MPPC, kernel module ppp_mppe_mppc.o
    #mppe required,stateless
    Quando dou o comando pptp 10.0.0.138, aparece a mensagem:
    [email protected] ~# pptp 10.0.0.138
    Using interface ppp0
    Connect: ppp0 <--> /dev/pts/1
    LCP: timeout sending Config-Requests
    Connection terminated.
    tcflush failed: Bad file descriptor
    tcsetattr: Invalid argument (line 1001)
    Alguem sabe o que pode ser?
    Padrão Re: A saga: pptp não conecta!!
    vejam o que aparece no /var/log/messages quando dou o comando pptp 10.0.0.138:
    May 15 15:14:04 Server pptp[696]: anon log[mainptp.c:267]: The synchronous
    pptp option is NOT activated
    May 15 15:14:04 Server pptp[699]: anon log[ctrlp_repptp_ctrl.c:251]: Sent
    control packet type is 1 'Start-Control-Connection-Request'
    May 15 15:14:04 Server pptp[699]: anon log[ctrlp_dispptp_ctrl.c:738]:
    Received Start Control Connection Reply
    May 15 15:14:04 Server pptp[699]: anon log[ctrlp_dispptp_ctrl.c:772]:
    Client connection established.
    May 15 15:14:05 Server pptp[699]: anon log[ctrlp_repptp_ctrl.c:251]: Sent
    control packet type is 7 'Outgoing-Call-Request'
    May 15 15:14:05 Server pptp[699]: anon log[ctrlp_dispptp_ctrl.c:857]:
    Received Outgoing Call Reply.
    May 15 15:14:05 Server pptp[699]: anon log[ctrlp_dispptp_ctrl.c:896]:
    Outgoing call established (call ID 0, peer's call ID 0).
    May 15 15:14:36 Server pptp[702]: anon warn[decaps_hdlcptp_gre.c:197]:
    short read (-1): Input/output error
    May 15 15:14:36 Server pptp[702]: anon warn[decaps_hdlcptp_gre.c:209]:
    pppd may have shutdown, see pppd log
    May 15 15:14:36 Server pptp[699]: anon log[callmgr_mainptp_callmgr.c:231]:
    Closing connection (unhandled)
    May 15 15:14:36 Server pptp[699]: anon log[ctrlp_repptp_ctrl.c:251]: Sent
    control packet type is 12 'Call-Clear-Request'
    May 15 15:14:36 Server pptp[699]: anon log[call_callbackptp_callmgr.c:78]:
    Closing connection (call state)
    O que seria esse: The synchronous pptp option is NOT activated?
