    dbanet
    Acabei de instalar o Samba 3.0.22 e naum consigo autenticar
    OBS! Interessante que que os usuarios que crio naum estao indo pro /etc/samba/smbpasswd
    Add no Linux e depois com smbpasswd -a usuario e nada
    Veja meu script do smb.conf
    [global]
    #Grupo, nome e comentario
    workgroup = GROUP
    netbios name = TUX_SERVER
    server string = servidor
    # Arquivo de log
    log file = /var/log/samba/%m.log
    max log size = 50
    debug level = 2
    # Senha criptografada
    security = USER
    encrypt passwords = yes
    smb passwd file = /etc/samba/smbpasswd
    username map = /etc/samba/smbusers
    dd machine script = /usr/sbin/adduser -n -r -g machines -c "Samba machine " -d /dev/null -s /bin/false %u
    passdb backend = smbpasswd
    socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
    # Interfaces
    interfaces = eth0
    bind interfaces only = yes
    domain logons = Yes
    os level = 100
    preferred master = Yes
    domain master = Yes
    [netlogon]
    comment = Logon de Serviços Network
    path = /etc/samba/netlogon
    guest ok = yes
    write list = teste
    [DADOS]
    comment = Diretório para arquivar dados
    path = /mnt/dados
    public = no
    valid users = @dados
    write list = @dados
    force group = @dados
    read only = No
    writable = Yes
    #create mask = 0664
    force create mode = 0740
    #directory mask = 0775
    force directory mode = 0740
    o meu .bat tah assim
    ECHO OFF
    net time \\TUX_SERVER /set /yes
    net use J: \\TUX_SERVER\DADOS
    Alguem pode me ajudar?
    Grato
    gilsonpaulo
    Seque um smb.conf meu que tenho utilizado para meus servidores samba, tem funcionado no samba 3.
    [global]
    workgroup = SEU GRUPO DE TRABALHO
    netbios name = NOME DO SERVIDOR QUE IRA APARECER NO AMBIENTE DE REDE
    server string = Samba Server
    time server = yes
    ; nt acl support = yes
    security = user
    unix password sync = yes
    passwd program = /usr/bin/passwd %u
    passwd chat = *New*Unix*password* %n\n *ReType*New*UNIX*password* %n\n *passwd:*all*authentication*tokens*update*successfully*
    ; hosts allow = 192.168.1. 192.168.2. 127.
    ; load printers = yes
    ; printcap name = /etc/printcap
    ; printcap name = lpstat
    ; printing = cups
    guest account = nobody
    log file = /var/log/samba.%m
    max log size = 50
    ; password server = <NT-Server-Name>
    ; realm = MY_REALM
    passdb backend = tdbsam guest
    ; include = /usr/local/samba/lib/smb.conf.%m
    ; interfaces = 192.168.12.2/24 192.168.13.2/24
    local master = yes
    os level = 100
    domain master = yes
    preferred master = yes
    domain logons = yes
    ; logon script = %U.bat
    ; logon drive = H:
    ; logon path = \\%L\ProfilesNT\%U
    ; logon home = \\%L\%U
    preserve case = yes
    short preserve case = yes
    case sensitive = no
    wins support = yes
    ; wins server = w.x.y.z
    wins proxy = yes
    dns proxy = no
    ; add user script = /usr/sbin/useradd %u
    ; add group script = /usr/sbin/groupadd %g
    ; add machine script = /usr/sbin/adduser -g maq -c "Conta do Computador no Dominio" -d /dev/null -s /bin/false %m
    ; delete user script = /usr/sbin/userdel %u
    ; delete user from group script = /usr/sbin/deluser %u %g
    ; delete group script = /usr/sbin/groupdel %g
    #============================ Share Definitions ==============================
    [homes]
    comment = Home Directories
    browseable = no
    writable = yes
    [netlogon]
    comment = Network Logon Service
    path = /home/netlogon
    guest ok = yes
    writable = no
    share modes = no
    #Diretorio Sistema
    [Sistema]
    Comment = Diretorio Sistema
    path = /sistema
    username = root
    valid users = caixa
    read list = caixa
    write list = caixa
    force user = root
    force group = root
    ;[printers]
    ; comment = All Printers
    ; path = /var/spool/samba
    ; browseable = no
    ; guest ok = no
    ; writable = no
    ; printable = yes
    Eu trabalho com tdbsam para os usuarios no samba.
    Para adicionar um usuario no samba digite: pdbedit -a usuario ( mas primeiro vc adiciona no Linux useradd bla bla
  1. Win98 não consegue autenticar no Samba
    Por bau no fórum Servidores de Rede
    Respostas: 13
    Último Post: 22-02-2005, 17:24
  2. não consigo montar com smbmount
    Por mcyberx no fórum Servidores de Rede
    Respostas: 5
    Último Post: 28-08-2004, 05:43
  3. Nao consigo acessar o samba pelo win98
    Por crazy4tech no fórum Servidores de Rede
    Último Post: 14-02-2004, 10:46
  4. Não consigo logar com DHCP depois que migrei do w2k pro win9
    Por ThE_PuNiShEr no fórum Servidores de Rede
    Último Post: 07-08-2003, 12:48
  5. Não consigo funcionar esse SAMBA
    Respostas: 11
    Último Post: 17-06-2003, 08:55
