    Padrão apache
    e ae galera to aprendendo a conf o apache+php+mysql e montar 1 forum peguei o phpbb
    instalei o slackware full adicionei o modulo do php4 no apache segui uns tutoriais na net e ta funcionando dae criei 1 pasta downlods dentro do diretorio e coloquei umas musica so que ninguem consegue vizualiza so eu ja dei 1 chmod 755 no diretorio e nada alguem poderia me ajuda (estou ficando louko kase com isso) :? :?
    PS: apache1.3.33, php4, mysql 4
    Padrão Re: Apache
    Verifique se os logs do Apache acusam algum erro... Esta pasta está na raiz do site??
    mtec
    Padrão Re: apache
    sera 1 erro ow alguma coisa na configuração???
    Padrão Re: apache
    vo posta o meu httpd.conf se alguem acha alguma coisa erra me ajuda
    ### Section 1: Global Environment
    # The directives in this section affect the overall operation of Apache,
    # such as the number of concurrent requests it can handle or where it
    # can find its configuration files.
    # ServerType is either inetd, or standalone. Inetd mode is only supported on
    # Unix platforms.
    ServerType standalone
    # ServerRoot: The top of the directory tree under which the server's
    # configuration, error, and log files are kept.
    # NOTE! If you intend to place this on an NFS (or otherwise network)
    # mounted filesystem then please read the LockFile documentation
    # (available at <URL:http://www.apache.org/docs/mod/core.html#lockfile>);
    # you will save yourself a lot of trouble.
    ServerRoot "/usr"
    # The LockFile directive sets the path to the lockfile used when Apache
    # is compiled with either USE_FCNTL_SERIALIZED_ACCEPT or
    # USE_FLOCK_SERIALIZED_ACCEPT. This directive should normally be left at
    # its default value. The main reason for changing it is if the logs
    # directory is NFS mounted, since the lockfile MUST BE STORED ON A LOCAL
    # DISK. The PID of the main server process is automatically appended to
    # the filename.
    #LockFile /var/run/httpd.lock
    # PidFile: The file in which the server should record its process
    # identification number when it starts.
    PidFile /var/run/httpd.pid
    # ScoreBoardFile: File used to store internal server process information.
    # Not all architectures require this. But if yours does (you'll know because
    # this file will be created when you run Apache) then you *must* ensure that
    # no two invocations of Apache share the same scoreboard file.
    ScoreBoardFile /var/run/httpd.scoreboard
    # In the standard configuration, the server will process httpd.conf (this
    # file, specified by the -f command line option), srm.conf, and access.conf
    # in that order. The latter two files are now distributed empty, as it is
    # recommended that all directives be kept in a single file for simplicity.
    # The commented-out values below are the built-in defaults. You can have the
    # server ignore these files altogether by using "/dev/null" (for Unix) or
    # "nul" (for Win32) for the arguments to the directives.
    #ResourceConfig /etc/apache/srm.conf
    #AccessConfig /etc/apache/access.conf
    # Timeout: The number of seconds before receives and sends time out.
    Timeout 300
    # KeepAlive: Whether or not to allow persistent connections (more than
    # one request per connection). Set to "Off" to deactivate.
    KeepAlive On
    # MaxKeepAliveRequests: The maximum number of requests to allow
    # during a persistent connection. Set to 0 to allow an unlimited amount.
    # We recommend you leave this number high, for maximum performance.
    MaxKeepAliveRequests 100
    # KeepAliveTimeout: Number of seconds to wait for the next request from the
    # same client on the same connection.
    KeepAliveTimeout 15
    # Server-pool size regulation. Rather than making you guess how many
    # server processes you need, Apache dynamically adapts to the load it
    # sees --- that is, it tries to maintain enough server processes to
    # handle the current load, plus a few spare servers to handle transient
    # load spikes (e.g., multiple simultaneous requests from a single
    # Netscape browser).
    # It does this by periodically checking how many servers are waiting
    # for a request. If there are fewer than MinSpareServers, it creates
    # a new spare. If there are more than MaxSpareServers, some of the
    # spares die off. The default values are probably OK for most sites.
    MinSpareServers 5
    MaxSpareServers 10
    # Number of servers to start initially --- should be a reasonable ballpark
    # figure.
    StartServers 5
    # Limit on total number of servers running, i.e., limit on the number
    # of clients who can simultaneously connect --- if this limit is ever
    # reached, clients will be LOCKED OUT, so it should NOT BE SET TOO LOW.
    # It is intended mainly as a brake to keep a runaway server from taking
    # the system with it as it spirals down...
    MaxClients 150
    # MaxRequestsPerChild: the number of requests each child process is
    # allowed to process before the child dies. The child will exit so
    # as to avoid problems after prolonged use when Apache (and maybe the
    # libraries it uses) leak memory or other resources. On most systems, this
    # isn't really needed, but a few (such as Solaris) do have notable leaks
    # in the libraries. For these platforms, set to something like 10000
    # or so; a setting of 0 means unlimited.
    MaxRequestsPerChild 0
    # Listen: Allows you to bind Apache to specific IP addresses and/or
    # ports, instead of the default. See also the <VirtualHost>
    # directive.
    #Listen 3000
    #Listen 12.34.56.78:80
    # BindAddress: You can support virtual hosts with this option. This directive
    # is used to tell the server which IP address to listen to. It can either
    # contain "*", an IP address, or a fully qualified Internet domain name.
    # See also the <VirtualHost> and Listen directives.
    #BindAddress *
    # Dynamic Shared Object (DSO) Support
    # To be able to use the functionality of a module which was built as a DSO you
    # have to place corresponding `LoadModule' lines at this location so the
    # directives contained in it are actually available _before_ they are used.
    # Please read the file http://httpd.apache.org/docs/dso.html for more
    # details about the DSO mechanism and run `httpd -l' for the list of already
    # built-in (statically linked and thus always available) modules in your httpd
    # binary.
    # Note: The order in which modules are loaded is important. Don't change
    # the order below without expert advice.
    # Example:
    # LoadModule foo_module libexec/mod_foo.so
    LoadModule vhost_alias_module libexec/apache/mod_vhost_alias.so
    LoadModule env_module libexec/apache/mod_env.so
    LoadModule define_module libexec/apache/mod_define.so
    LoadModule config_log_module libexec/apache/mod_log_config.so
    LoadModule mime_magic_module libexec/apache/mod_mime_magic.so
    LoadModule mime_module libexec/apache/mod_mime.so
    LoadModule negotiation_module libexec/apache/mod_negotiation.so
    LoadModule status_module libexec/apache/mod_status.so
    LoadModule info_module libexec/apache/mod_info.so
    LoadModule includes_module libexec/apache/mod_include.so
    LoadModule autoindex_module libexec/apache/mod_autoindex.so
    LoadModule dir_module libexec/apache/mod_dir.so
    LoadModule cgi_module libexec/apache/mod_cgi.so
    LoadModule asis_module libexec/apache/mod_asis.so
    LoadModule imap_module libexec/apache/mod_imap.so
    LoadModule action_module libexec/apache/mod_actions.so
    LoadModule speling_module libexec/apache/mod_speling.so
    LoadModule userdir_module libexec/apache/mod_userdir.so
    LoadModule alias_module libexec/apache/mod_alias.so
    LoadModule rewrite_module libexec/apache/mod_rewrite.so
    LoadModule access_module libexec/apache/mod_access.so
    LoadModule auth_module libexec/apache/mod_auth.so
    LoadModule anon_auth_module libexec/apache/mod_auth_anon.so
    LoadModule dbm_auth_module libexec/apache/mod_auth_dbm.so
    LoadModule digest_module libexec/apache/mod_digest.so
    LoadModule proxy_module libexec/apache/libproxy.so
    LoadModule cern_meta_module libexec/apache/mod_cern_meta.so
    LoadModule expires_module libexec/apache/mod_expires.so
    LoadModule headers_module libexec/apache/mod_headers.so
    LoadModule usertrack_module libexec/apache/mod_usertrack.so
    LoadModule log_forensic_module libexec/apache/mod_log_forensic.so
    LoadModule unique_id_module libexec/apache/mod_unique_id.so
    LoadModule setenvif_module libexec/apache/mod_setenvif.so
    LoadModule php4_module /usr/libexec/apache/libphp4.so
    # Reconstruction of the complete module list from all available modules
    # (static and shared ones) to achieve correct module execution order.
    # [WHENEVER YOU CHANGE THE LOADMODULE SECTION ABOVE UPDATE THIS, TOO]
    ClearModuleList
    AddModule mod_vhost_alias.c
    AddModule mod_env.c
    AddModule mod_define.c
    AddModule mod_log_config.c
    AddModule mod_mime_magic.c
    AddModule mod_mime.c
    AddModule mod_negotiation.c
    AddModule mod_status.c
    AddModule mod_info.c
    AddModule mod_include.c
    AddModule mod_autoindex.c
    AddModule mod_dir.c
    AddModule mod_cgi.c
    AddModule mod_asis.c
    AddModule mod_imap.c
    AddModule mod_actions.c
    AddModule mod_speling.c
    AddModule mod_userdir.c
    AddModule mod_alias.c
    AddModule mod_rewrite.c
    AddModule mod_access.c
    AddModule mod_auth.c
    AddModule mod_auth_anon.c
    AddModule mod_auth_dbm.c
    AddModule mod_digest.c
    AddModule mod_proxy.c
    AddModule mod_cern_meta.c
    AddModule mod_expires.c
    AddModule mod_headers.c
    AddModule mod_usertrack.c
    AddModule mod_log_forensic.c
    AddModule mod_unique_id.c
    AddModule mod_so.c
    AddModule mod_setenvif.c
    AddModule mod_php4.c
    # ExtendedStatus controls whether Apache will generate "full" status
    # information (ExtendedStatus On) or just basic information (ExtendedStatus
    # Off) when the "server-status" handler is called. The default is Off.
    #ExtendedStatus On
    ### Section 2: 'Main' server configuration
    # The directives in this section set up the values used by the 'main'
    # server, which responds to any requests that aren't handled by a
    # <VirtualHost> definition. These values also provide defaults for
    # any <VirtualHost> containers you may define later in the file.
    # All of these directives may appear inside <VirtualHost> containers,
    # in which case these default settings will be overridden for the
    # virtual host being defined.
    # If your ServerType directive (set earlier in the 'Global Environment'
    # section) is set to "inetd", the next few directives don't have any
    # effect since their settings are defined by the inetd configuration.
    # Skip ahead to the ServerAdmin directive.
    # Port: The port to which the standalone server listens. For
    # ports < 1023, you will need httpd to be run as root initially.
    Port 80
    # If you wish httpd to run as a different user or group, you must run
    # httpd as root initially and it will switch.
    # User/Group: The name (or #number) of the user/group to run httpd as.
    # . On SCO (ODT 3) use "User nouser" and "Group nogroup".
    # . On HPUX you may not be able to use shared memory as nobody, and the
    # suggested workaround is to create a user www and use that user.
    # NOTE that some kernels refuse to setgid(Group) or semctl(IPC_SET)
    # when the value of (unsigned)Group is above 60000;
    # don't use Group "#-1" on these systems!
    User nobody
    Group nobody
    # ServerAdmin: Your address, where problems with the server should be
    # e-mailed. This address appears on some server-generated pages, such
    # as error documents.
    ServerAdmin [email protected]
    # ServerName allows you to set a host name which is sent back to clients for
    # your server if it's different than the one the program would get (i.e., use
    # "www" instead of the host's real name).
    # Note: You cannot just invent host names and hope they work. The name you
    # define here must be a valid DNS name for your host. If you don't understand
    # this, ask your network administrator.
    # If your host doesn't have a registered DNS name, enter its IP address here.
    # You will have to access it by its address (e.g., http://123.45.67.89/)
    # anyway, and this will make redirections work in a sensible way.
    # 127.0.0.1 is the TCP/IP local loop-back address, often named localhost. Your
    # machine always knows itself by this address. If you use Apache strictly for
    # local testing and development, you may use 127.0.0.1 as the server name.
    #ServerName www.example.com
    # DocumentRoot: The directory out of which you will serve your
    # documents. By default, all requests are taken from this directory, but
    # symbolic links and aliases may be used to point to other locations.
    DocumentRoot "/var/www/htdocs"
    # Each directory to which Apache has access, can be configured with respect
    # to which services and features are allowed and/or disabled in that
    # directory (and its subdirectories).
    # First, we configure the "default" to be a very restrictive set of
    # permissions.
    <Directory />
    Options FollowSymLinks
    AllowOverride None
    </Directory>
    # Note that from this point forward you must specifically allow
    # particular features to be enabled - so if something's not working as
    # you might expect, make sure that you have specifically enabled it
    # below.
    # This should be changed to whatever you set DocumentRoot to.
    <Directory "/var/www/htdocs">
    # This may also be "None", "All", or any combination of "Indexes",
    # "Includes", "FollowSymLinks", "ExecCGI", or "MultiViews".
    # Note that "MultiViews" must be named *explicitly* --- "Options All"
    # doesn't give it to you.
    Options Indexes FollowSymLinks MultiViews
    # This controls which options the .htaccess files in directories can
    # override. Can also be "All", or any combination of "Options", "FileInfo",
    # "AuthConfig", and "Limit"
    AllowOverride None
    # Controls who can get stuff from this server.
    Order allow,deny
    Allow from all
    </Directory>
    # UserDir: The name of the directory which is appended onto a user's home
    # directory if a ~user request is received.
    <IfModule mod_userdir.c>
    UserDir public_html
    </IfModule>
    # Control access to UserDir directories. The following is an example
    # for a site where these directories are restricted to read-only.
    #<Directory /home/*/public_html>
    # AllowOverride FileInfo AuthConfig Limit
    # Options MultiViews Indexes SymLinksIfOwnerMatch IncludesNoExec
    # <Limit GET POST OPTIONS PROPFIND>
    # Order allow,deny
    # Allow from all
    # </Limit>
    # <LimitExcept GET POST OPTIONS PROPFIND>
    # Order deny,allow
    # Deny from all
    # </LimitExcept>
    #</Directory>
    # DirectoryIndex: Name of the file or files to use as a pre-written HTML
    # directory index. Separate multiple entries with spaces.
    <IfModule mod_dir.c>
    DirectoryIndex index.html index.php index.htm
    </IfModule>
    <IfModule mod_php4.c>
    AddType application/x-httpd-php .php4 .php3 .phtml .php
    AddType application/x-httpd-php-source .phps
    </IfModule>
    # AccessFileName: The name of the file to look for in each directory
    # for access control information.
    AccessFileName .htaccess
    # The following lines prevent .htaccess files from being viewed by
    # Web clients. Since .htaccess files often contain authorization
    # information, access is disallowed for security reasons. Comment
    # these lines out if you want Web visitors to see the contents of
    # .htaccess files. If you change the AccessFileName directive above,
    # be sure to make the corresponding changes here.
    # Also, folks tend to use names such as .htpasswd for password
    # files, so this will protect those as well.
    <Files ~ "^\.ht">
    Order allow,deny
    Deny from all
    Satisfy All
    </Files>
    # CacheNegotiatedDocs: By default, Apache sends "Pragma: no-cache" with each
    # document that was negotiated on the basis of content. This asks proxy
    # servers not to cache the document. Uncommenting the following line disables
    # this behavior, and proxies will be allowed to cache the documents.
    #CacheNegotiatedDocs
    # UseCanonicalName: (new for 1.3) With this setting turned on, whenever
    # Apache needs to construct a self-referencing URL (a URL that refers back
    # to the server the response is coming from) it will use ServerName and
    # Port to form a "canonical" name. With this setting off, Apache will
    # use the hostnameort that the client supplied, when possible. This
    # also affects SERVER_NAME and SERVER_PORT in CGI scripts.
    UseCanonicalName On
    # TypesConfig describes where the mime.types file (or equivalent) is
    # to be found.
    <IfModule mod_mime.c>
    TypesConfig /etc/apache/mime.types
    </IfModule>
    # DefaultType is the default MIME type the server will use for a document
    # if it cannot otherwise determine one, such as from filename extensions.
    # If your server contains mostly text or HTML documents, "text/plain" is
    # a good value. If most of your content is binary, such as applications
    # or images, you may want to use "application/octet-stream" instead to
    # keep browsers from trying to display binary files as though they are
    # text.
    DefaultType text/plain
    # The mod_mime_magic module allows the server to use various hints from the
    # contents of the file itself to determine its type. The MIMEMagicFile
    # directive tells the module where the hint definitions are located.
    # mod_mime_magic is not part of the default server (you have to add
    # it yourself with a LoadModule [see the DSO paragraph in the 'Global
    # Environment' section], or recompile the server and include mod_mime_magic
    # as part of the configuration), so it's enclosed in an <IfModule> container.
    # This means that the MIMEMagicFile directive will only be processed if the
    # module is part of the server.
    <IfModule mod_mime_magic.c>
    MIMEMagicFile /etc/apache/magic
    </IfModule>
    # HostnameLookups: Log the names of clients or just their IP addresses
    # e.g., www.apache.org (on) or 204.62.129.132 (off).
    # The default is off because it'd be overall better for the net if people
    # had to knowingly turn this feature on, since enabling it means that
    # each client request will result in AT LEAST one lookup request to the
    # nameserver.
    HostnameLookups Off
    # ErrorLog: The location of the error log file.
    # If you do not specify an ErrorLog directive within a <VirtualHost>
    # container, error messages relating to that virtual host will be
    # logged here. If you *do* define an error logfile for a <VirtualHost>
    # container, that host's errors will be logged there and not here.
    ErrorLog /var/log/apache/error_log
    # LogLevel: Control the number of messages logged to the error_log.
    # Possible values include: debug, info, notice, warn, error, crit,
    # alert, emerg.
    LogLevel warn
    # The following directives define some format nicknames for use with
    # a CustomLog directive (see below).
    LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
    LogFormat "%h %l %u %t \"%r\" %>s %b" common
    LogFormat "%{Referer}i -> %U" referer
    LogFormat "%{User-agent}i" agent
    # The location and format of the access logfile (Common Logfile Format).
    # If you do not define any access logfiles within a <VirtualHost>
    # container, they will be logged here. Contrariwise, if you *do*
    # define per-<VirtualHost> access logfiles, transactions will be
    # logged therein and *not* in this file.
    Padrão Re: apache
    vo postar o resto do arquivo
    CustomLog /var/log/apache/access_log common
    # If you would like to have agent and referer logfiles, uncomment the
    # following directives.
    #CustomLog /var/log/apache/referer_log referer
    #CustomLog /var/log/apache/agent_log agent
    # If you prefer a single logfile with access, agent, and referer information
    # (Combined Logfile Format) you can use the following directive.
    #CustomLog /var/log/apache/access_log combined
    # Optionally add a line containing the server version and virtual host
    # name to server-generated pages (error documents, FTP directory listings,
    # mod_status and mod_info output etc., but not CGI generated documents).
    # Set to "EMail" to also include a mailto: link to the ServerAdmin.
    # Set to one of: On | Off | EMail
    ServerSignature On
    # EBCDIC configuration:
    # (only for mainframes using the EBCDIC codeset, currently one of:
    # Fujitsu-Siemens' BS2000/OSD, IBM's OS/390 and IBM's TPF)!!
    # The following default configuration assumes that "text files"
    # are stored in EBCDIC (so that you can operate on them using the
    # normal POSIX tools like grep and sort) while "binary files" are
    # stored with identical octets as on an ASCII machine.
    # The directives are evaluated in configuration file order, with
    # the EBCDICConvert directives applied before EBCDICConvertByType.
    # If you want to have ASCII HTML documents and EBCDIC HTML documents
    # at the same time, you can use the file extension to force
    # conversion off for the ASCII documents:
    # > AddType text/html .ahtml
    # > EBCDICConvert Off=InOut .ahtml
    # EBCDICConvertByType On=InOut text/* message/* multipart/*
    # EBCDICConvertByType On=In application/x-www-form-urlencoded
    # EBCDICConvertByType On=InOut application/postscript model/vrml
    # EBCDICConvertByType Off=InOut */*
    # Aliases: Add here as many aliases as you need (with no limit). The format is
    # Alias fakename realname
    <IfModule mod_alias.c>
    # Note that if you include a trailing / on fakename then the server will
    # require it to be present in the URL. So "/icons" isn't aliased in this
    # example, only "/icons/". If the fakename is slash-terminated, then the
    # realname must also be slash terminated, and if the fakename omits the
    # trailing slash, the realname must also omit it.
    Alias /icons/ "/var/www/icons/"
    <Directory "/var/www/icons">
    Options Indexes MultiViews
    AllowOverride None
    Order allow,deny
    Allow from all
    </Directory>
    # This Alias will project the on-line documentation tree under /manual/
    # even if you change the DocumentRoot. Comment it if you don't want to
    # provide access to the on-line documentation.
    Alias /manual/ "/var/www/htdocs/manual/"
    <Directory "/var/www/htdocs/manual">
    Options Indexes FollowSymlinks MultiViews
    AllowOverride None
    Order allow,deny
    Allow from all
    </Directory>
    # ScriptAlias: This controls which directories contain server scripts.
    # ScriptAliases are essentially the same as Aliases, except that
    # documents in the realname directory are treated as applications and
    # run by the server when requested rather than as documents sent to the client.
    # The same rules about trailing "/" apply to ScriptAlias directives as to
    # Alias.
    ScriptAlias /cgi-bin/ "/var/www/cgi-bin/"
    # "/var/www/cgi-bin" should be changed to whatever your ScriptAliased
    # CGI directory exists, if you have that configured.
    <Directory "/var/www/cgi-bin">
    AllowOverride None
    Options None
    Order allow,deny
    Allow from all
    </Directory>
    </IfModule>
    # End of aliases.
    # Redirect allows you to tell clients about documents which used to exist in
    # your server's namespace, but do not anymore. This allows you to tell the
    # clients where to look for the relocated document.
    # Format: Redirect old-URI new-URL
    # Directives controlling the display of server-generated directory listings.
    <IfModule mod_autoindex.c>
    # FancyIndexing is whether you want fancy directory indexing or standard
    IndexOptions FancyIndexing
    # AddIcon* directives tell the server which icon to show for different
    # files or filename extensions. These are only displayed for
    # FancyIndexed directories.
    AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
    AddIconByType (TXT,/icons/text.gif) text/*
    AddIconByType (IMG,/icons/image2.gif) image/*
    AddIconByType (SND,/icons/sound2.gif) audio/*
    AddIconByType (VID,/icons/movie.gif) video/*
    AddIcon /icons/binary.gif .bin .exe
    AddIcon /icons/binhex.gif .hqx
    AddIcon /icons/tar.gif .tar
    AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
    AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
    AddIcon /icons/a.gif .ps .ai .eps
    AddIcon /icons/layout.gif .html .shtml .htm .pdf
    AddIcon /icons/text.gif .txt
    AddIcon /icons/c.gif .c
    AddIcon /icons/p.gif .pl .py
    AddIcon /icons/f.gif .for
    AddIcon /icons/dvi.gif .dvi
    AddIcon /icons/uuencoded.gif .uu
    AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
    AddIcon /icons/tex.gif .tex
    AddIcon /icons/bomb.gif core
    AddIcon /icons/back.gif ..
    AddIcon /icons/hand.right.gif README
    AddIcon /icons/folder.gif ^^DIRECTORY^^
    AddIcon /icons/blank.gif ^^BLANKICON^^
    # DefaultIcon is which icon to show for files which do not have an icon
    # explicitly set.
    DefaultIcon /icons/unknown.gif
    # AddDescription allows you to place a short description after a file in
    # server-generated indexes. These are only displayed for FancyIndexed
    # directories.
    # Format: AddDescription "description" filename
    #AddDescription "GZIP compressed document" .gz
    #AddDescription "tar archive" .tar
    #AddDescription "GZIP compressed tar archive" .tgz
    # ReadmeName is the name of the README file the server will look for by
    # default, and append to directory listings.
    # HeaderName is the name of a file which should be prepended to
    # directory indexes.
    ReadmeName README.html
    HeaderName HEADER.html
    # IndexIgnore is a set of filenames which directory indexing should ignore
    # and not include in the listing. Shell-style wildcarding is permitted.
    IndexIgnore .??* *~ *# HEADER* README* RCS CVS *,v *,t
    </IfModule>
    # End of indexing directives.
    # Document types.
    # AddLanguage allows you to specify the language of a document. You can
    # then use content negotiation to give a browser a file in a language
    # it can understand.
    # Note 1: The suffix does not have to be the same as the language
    # keyword --- those with documents in Polish (whose net-standard
    # language code is pl) may wish to use "AddLanguage pl .po" to
    # avoid the ambiguity with the common suffix for perl scripts.
    # Note 2: The example entries below illustrate that in quite
    # some cases the two character 'Language' abbreviation is not
    # identical to the two character 'Country' code for its country,
    # E.g. 'Danmark/dk' versus 'Danish/da'.
    # Note 3: In the case of 'ltz' we violate the RFC by using a three char
    # specifier. But there is 'work in progress' to fix this and get
    # the reference data for rfc1766 cleaned up.
    # Danish (da) - Dutch (nl) - English (en) - Estonian (ee)
    # French (fr) - German (de) - Greek-Modern (el)
    # Italian (it) - Korean (kr) - Norwegian (no) - Norwegian Nynorsk (nn)
    # Portugese (pt) - Luxembourgeois* (ltz)
    # Spanish (es) - Swedish (sv) - Catalan (ca) - Czech(cs)
    # Polish (pl) - Brazilian Portuguese (pt-br) - Japanese (ja)
    # Russian (ru)
    AddLanguage da .dk
    AddLanguage nl .nl
    AddLanguage en .en
    AddLanguage et .ee
    AddLanguage fr .fr
    AddLanguage de .de
    AddLanguage el .el
    AddLanguage he .he
    AddCharset ISO-8859-8 .iso8859-8
    AddLanguage it .it
    AddLanguage ja .ja
    AddCharset ISO-2022-JP .jis
    AddLanguage kr .kr
    AddCharset ISO-2022-KR .iso-kr
    AddLanguage nn .nn
    AddLanguage no .no
    AddLanguage pl .po
    AddCharset ISO-8859-2 .iso-pl
    AddLanguage pt .pt
    AddLanguage pt-br .pt-br
    AddLanguage ltz .lu
    AddLanguage ca .ca
    AddLanguage es .es
    AddLanguage sv .sv
    AddLanguage cs .cz .cs
    AddLanguage ru .ru
    AddLanguage zh-TW .zh-tw
    AddCharset Big5 .Big5 .big5
    AddCharset WINDOWS-1251 .cp-1251
    AddCharset CP866 .cp866
    AddCharset ISO-8859-5 .iso-ru
    AddCharset KOI8-R .koi8-r
    AddCharset UCS-2 .ucs2
    AddCharset UCS-4 .ucs4
    AddCharset UTF-8 .utf8
    # LanguagePriority allows you to give precedence to some languages
    # in case of a tie during content negotiation.
    # Just list the languages in decreasing order of preference. We have
    # more or less alphabetized them here. You probably want to change this.
    <IfModule mod_negotiation.c>
    LanguagePriority en da nl et fr de el it ja kr no pl pt pt-br ru ltz ca es sv tw
    </IfModule>
    # AddType allows you to tweak mime.types without actually editing it, or to
    # make certain files to be certain types.
    AddType application/x-tar .tgz
    # AddEncoding allows you to have certain browsers uncompress
    # information on the fly. Note: Not all browsers support this.
    # Despite the name similarity, the following Add* directives have nothing
    # to do with the FancyIndexing customization directives above.
    AddEncoding x-compress .Z
    AddEncoding x-gzip .gz .tgz
    # If the AddEncoding directives above are commented-out, then you
    # probably should define those extensions to indicate media types:
    #AddType application/x-compress .Z
    #AddType application/x-gzip .gz .tgz
    # AddHandler allows you to map certain file extensions to "handlers",
    # actions unrelated to filetype. These can be either built into the server
    # or added with the Action command (see below)
    # If you want to use server side includes, or CGI outside
    # ScriptAliased directories, uncomment the following lines.
    # To use CGI scripts:
    #AddHandler cgi-script .cgi
    # To use server-parsed HTML files
    #AddType text/html .shtml
    #AddHandler server-parsed .shtml
    # Uncomment the following line to enable Apache's send-asis HTTP file
    # feature
    #AddHandler send-as-is asis
    # If you wish to use server-parsed imagemap files, use
    #AddHandler imap-file map
    # To enable type maps, you might want to use
    #AddHandler type-map var
    </IfModule>
    # End of document types.
    # Action lets you define media types that will execute a script whenever
    # a matching file is called. This eliminates the need for repeated URL
    # pathnames for oft-used CGI file processors.
    # Format: Action media/type /cgi-script/location
    # Format: Action handler-name /cgi-script/location
    # MetaDir: specifies the name of the directory in which Apache can find
    # meta information files. These files contain additional HTTP headers
    # to include when sending the document
    #MetaDir .web
    # MetaSuffix: specifies the file name suffix for the file containing the
    # meta information.
    #MetaSuffix .meta
    # Customizable error response (Apache style)
    # these come in three flavors
    # 1) plain text
    #ErrorDocument 500 "The server made a boo boo.
    # n.b. the single leading (") marks it as text, it does not get output
    # 2) local redirects
    #ErrorDocument 404 /missing.html
    # to redirect to local URL /missing.html
    #ErrorDocument 404 /cgi-bin/missing_handler.pl
    # N.B.: You can redirect to a script or a document using server-side-includes.
    # 3) external redirects
    #ErrorDocument 402 http://www.example.com/subscription_info.html
    # N.B.: Many of the environment variables associated with the original
    # request will *not* be available to such a script.
    # Customize behaviour based on the browser
    <IfModule mod_setenvif.c>
    # The following directives modify normal HTTP response behavior.
    # The first directive disables keepalive for Netscape 2.x and browsers that
    # spoof it. There are known problems with these browser implementations.
    # The second directive is for Microsoft Internet Explorer 4.0b2
    # which has a broken HTTP/1.1 implementation and does not properly
    # support keepalive when it is used on 301 or 302 (redirect) responses.
    BrowserMatch "Mozilla/2" nokeepalive
    BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
    # The following directive disables HTTP/1.1 responses to browsers which
    # are in violation of the HTTP/1.0 spec by not being able to grok a
    # basic 1.1 response.
    BrowserMatch "RealPlayer 4\.0" force-response-1.0
    BrowserMatch "Java/1\.0" force-response-1.0
    BrowserMatch "JDK/1\.0" force-response-1.0
    </IfModule>
    # End of browser customization directives
    # Allow server status reports, with the URL of http://servername/server-status
    # Change the ".example.com" to match your domain to enable.
    #<Location /server-status>
    # SetHandler server-status
    # Order deny,allow
    # Deny from all
    # Allow from .example.com
    #</Location>
    # Allow remote server configuration reports, with the URL of
    # http://servername/server-info (requires that mod_info.c be loaded).
    #<Location /server-info>
    # SetHandler server-info
    # Order deny,allow
    # Deny from all
    #</Location>
    # There have been reports of people trying to abuse an old bug from pre-1.1
    # days. This bug involved a CGI script distributed as a part of Apache.
    # By uncommenting these lines you can redirect these attacks to a logging
    # script on phf.apache.org. Or, you can record them yourself, using the script
    # support/phf_abuse_log.cgi.
    #<Location /cgi-bin/phf*>
    # Deny from all
    # ErrorDocument 403 http://phf.apache.org/phf_abuse_log.cgi
    #</Location>
    ### Section 3: Virtual Hosts
    # VirtualHost: If you want to maintain multiple domains/hostnames on your
    # machine you can setup VirtualHost containers for them. Most configurations
    # use only name-based virtual hosts so the server doesn't need to worry about
    # IP addresses. This is indicated by the asterisks in the directives below.
    # Please see the documentation at <URL:http://www.apache.org/docs/vhosts/>
    # for further details before you try to setup virtual hosts.
    # You may use the command line option '-S' to verify your virtual host
    # configuration.
    # Use name-based virtual hosting.
    #NameVirtualHost *:80
    # VirtualHost example:
    # Almost any Apache directive may go into a VirtualHost container.
    # The first VirtualHost section is used for requests without a known
    # server name.
    #<VirtualHost *:80>
    # ServerAdmin [email protected]
    # DocumentRoot /www/docs/dummy-host.example.com
    # ServerName dummy-host.example.com
    # ErrorLog logs/dummy-host.example.com-error_log
    # CustomLog logs/dummy-host.example.com-access_log common
    #</VirtualHost>
    # By default, all external Apache modules are disabled. To enable a particular
    # module for Apache, make sure the necessary packages are installed. Then
    # uncomment the appropriate Include line below, save the file, and restart
    # Apache. Note that some modules may need additional configuration steps. For
    # example, mod_ssl requires a site certificate which you may need to generate.
    # Lastly, if you remove a module package, be sure to edit this file and comment
    # out the appropriate Include line.
    # ==> mod_php configuration settings <==
    # PACKAGES REQUIRED: openssl-solibs (A series) and/or openssl (N series),
    # mysql (AP series), gmp (L series), mhash (L series),
    # and apache (N series)
    #Include /etc/apache/mod_php.conf
    # ==> mod_ssl configuration settings <==
    # PACKAGES REQUIRED: apache (N series) and openssl (N series)
    #Include /etc/apache/mod_ssl.conf
    Padrão Re: apache
    Aparece algum erro nos logs quando vc tenta acessar pelo navegador?
    Padrão Re: apache
    aonde q eu vejo os logs....mais eu acho q ele ta bloqueando seila ta muito estranho!!!
    Padrão Re: apache
    /dir_do_apache/logs/access_logs
    geralmente: /usr/local/apache/logs/access_log
    O que aparece na tela do navegador? 404?
    O arquivo tá dentro de DocumentRoot?
    Falou
    Padrão Re: apache
    /var/log
    procure o error_log e veja qual erro esta acontecendo !!
