Estou com problemas para instalar o este modem no Slamd64 10.2b,
se alguém puder me ajudar... postei também as mensagens que recebo
[email protected]:/home/progs/modems/Intel-537# make clean
cd coredrv; make clean
make[1]: Entering directory `/home/progs/modems/Intel-537/coredrv'
rm -f *.ko *.o *~ core
make[1]: Leaving directory `/home/progs/modems/Intel-537/coredrv'
rm -f *.o *.ko
[email protected]:/home/progs/modems/Intel-537# make 537
Module precompile check
Current running kernel is: 2.6.11.10
/lib/modules... autoconf.h exists
diff: /boot/vmlinuz.autoconf.h: No such file or directory
autoconf.h matches running kernel
diff: /boot/vmlinuz.version.h: No such file or directory
version.h matches running kernel
2.6.11.10
make -C /lib/modules/2.6.11.10/build SUBDIRS=/home/progs/modems/Intel-537/coredrv modules
make[2]: Entering directory `/usr/src/linux-2.6.11.10'
CC [M] /home/progs/modems/Intel-537/coredrv/coredrv.o
/home/progs/modems/Intel-537/coredrv/coredrv.c:73: warning: type defaults to `int' in declaration of `EXPORT_SYMBOL_NOVERS'
/home/progs/modems/Intel-537/coredrv/coredrv.c:73: warning: parameter names (without types) in function declaration
/home/progs/modems/Intel-537/coredrv/coredrv.c:73: warning: data definition has no type or storage class
/home/progs/modems/Intel-537/coredrv/coredrv.c: In function `open':
/home/progs/modems/Intel-537/coredrv/coredrv.c:407: warning: `pm_register' is deprecated (declared at include/linux/pm.h:106)
/home/progs/modems/Intel-537/coredrv/coredrv.c: In function `close':
/home/progs/modems/Intel-537/coredrv/coredrv.c:439: warning: `pm_unregister' is deprecated (declared at include/linux/pm.h:111)
/home/progs/modems/Intel-537/coredrv/coredrv.c: At top level:
/home/progs/modems/Intel-537/coredrv/coredrv.c:880: warning: initialization makes integer from pointer without a cast
CC [M] /home/progs/modems/Intel-537/coredrv/clmmain.o
CC [M] /home/progs/modems/Intel-537/coredrv/rts.o
CC [M] /home/progs/modems/Intel-537/coredrv/task.o
CC [M] /home/progs/modems/Intel-537/coredrv/uart.o
CC [M] /home/progs/modems/Intel-537/coredrv/wwh_dflt.o
CC [M] /home/progs/modems/Intel-537/coredrv/locks.o
CC [M] /home/progs/modems/Intel-537/coredrv/softserial_io.o
CC [M] /home/progs/modems/Intel-537/coredrv/softserial_ioctl.o
CC [M] /home/progs/modems/Intel-537/coredrv/softserial.o
CC [M] /home/progs/modems/Intel-537/coredrv/afedsp_int.o
/home/progs/modems/Intel-537/coredrv/afedsp_int.c:39: warning: initialization makes integer from pointer without a cast
/home/progs/modems/Intel-537/coredrv/afedsp_int.c:48: warning: function declaration isn't a prototype
/home/progs/modems/Intel-537/coredrv/afedsp_int.c:61: warning: initialization from incompatiblepointer type
/home/progs/modems/Intel-537/coredrv/afedsp_int.c:65: warning: function declaration isn't a prototype
/home/progs/modems/Intel-537/coredrv/afedsp_int.c:446: warning: initialization from incompatible pointer type
LD [M] /home/progs/modems/Intel-537/coredrv/Intel537.o
ld: Relocatable linking with relocations from format elf32-i386 (/home/progs/modems/Intel-537/coredrv/537core.lib) to format elf64-x86-64 (/home/progs/modems/Intel-537/coredrv/Intel537.o) is not supported
make[3]: *** [/home/progs/modems/Intel-537/coredrv/Intel537.o] Error 1
make[2]: *** [_module_/home/progs/modems/Intel-537/coredrv] Error 2
make[2]: Leaving directory `/usr/src/linux-2.6.11.10'
make[1]: *** [537core_26] Error 2
2.6.11.10
Failed to build driver
