    morenocm
    Padrão OPENVPN
    Prezado,
    Alguem tem um exemplo de cofiguração do openvpn 2.0 explicado! Eu disse OPENVPN 2.0 nao versao 1.6 ou 1.8!!!!!!!
    Ou algum tutorial para uma ligação LAN-to-LAN ?
    Obrigado!
    ajsmit
    Padrão Re: OPENVPN
    Segui por aqui e funcionou perfeitamente.
    http://openvpn.net/howto.html
    Tem esse.
    http://www.altoriopreto.com.br/artigos_3rd/howto.php
    thiagog
    Padrão Re: OPENVPN
    ajuda (instalei 2.0 hoje)
    server.conf
    dev tun
    ifconfig 10.8.0.1 10.8.0.2
    secret static.key
    keepalive 10 60
    ping-timer-rem
    persist-tun
    persist-key
    user nobody
    group nobody
    daemon
    log /var/log/openvpn.log
    verb 1
    client.conf
    remote IP_SERVIDOR
    dev tun
    port 1194
    proto udp
    comp-lzo
    ifconfig 10.8.0.2 10.8.0.1
    secret static.key
    route 192.168.0.0 255.255.254.0
    tcpdump da interface tun1 do servidor qdo tento pingar (ping 10.8.0.1)[[email protected] ~]# tcpdump -i tun1 -p -n -vvvvv
    tcpdump: WARNING: arptype 65534 not supported by libpcap - falling back to cooked socket
    tcpdump: listening on tun1, link-type LINUX_SLL (Linux cooked), capture size 96 bytes
    11:50:39.281515 IP15 bad-len 0
    11:50:47.553829 IP15 bad-len 0
    11:50:52.781909 IP15 bad-len 0
    11:50:58.282280 IP15 bad-len 0
    11:51:03.782711 IP15 bad-len 0
    saida ifconfig
    eth0 Link encap:Ethernet HWaddr 00:E0:7D1:8B:4A
    inet addr:192.168.0.XX Bcast:192.168.1.255 Mask:255.255.254.0
    inet6 addr: fe80::2e0:7dff:fed1:8b4a/64 Scope:Link
    UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
    RX packets:39061867 errors:0 dropped:0 overruns:0 frame:0
    TX packets:3510968 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:1000
    RX bytes:673793920 (642.5 MiB) TX bytes:435012719 (414.8 MiB)
    Interrupt:10 Base address:0xd000
    tun1 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
    inet addr:10.8.0.1 P-t-P:10.8.0.2 Mask:255.255.255.255
    UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
    RX packets:33 errors:0 dropped:0 overruns:0 frame:0
    TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
    RX bytes:1282 (1.2 KiB) TX bytes:0 (0.0 b)
    se nao consigo pingar o meu gateway TUN como sei que funcionou ?
    []s
