    mrsoliveira
    Padrão ProFTP Bloqueado
    Amigos,
    Parou o FTP do nada!
    [[email protected] usr]# service proftpd status
    proftpd morto, porém subsys está bloqueado
    A conf:
    ServerName "FTP - empresa"
    ServerType standalone
    DefaultServer on
    ScoreboardFile /var/run/proftpd/scoreboard
    DeferWelcome on
    ServerAdmin [email protected]
    SyslogFacility AUTH
    Serverident on "Bem Vindo ao FTP da empresa"
    # Port 21 (ftp standard) is used in case of standalone more
    Port 21
    # Umask 022 is a good default value to prevent new directories and
    # files from being writable by the group or by other users
    Umask 022
    # To prevent DoS attacks, the max number of instances is limited to 30.
    # If one wants to allow more then 30 simultaneous connectionva, just
    # increment this value. This directive only applies if running in standalone
    # mode
    MaxInstances 30
    # This option, if enabled, will make the users unable to access anything
    # outside their home directory tree. READ THE DOCS!
    #DefaultRoot ~ !root
    # User and Group the server will run as
    #;User proftpd
    #;Group proftpd
    User nobody
    Group users
    #ftp stream tcp nowait root /usr/sbin/tcpd in.proftpd
    <Directory /*>
    AllowOverwrite no
    </Directory>
    # Default configuration for anonymous ftp, without an incoming directory.
    #<Anonymous /srv/ftp>
    # User ftp
    # Group ftp
    # DirFakeUser on
    # DirFakeGroup on
    # RequireValidShell off
    # UserAlias anonymous ftp
    # MaxClients 10 "Sorry, max %m users -- try again later"
    # MaxClientsPerHost 2 "Too many simultaneous connections"
    # DisplayLogin welcome.msg
    # DisplayFirstChdir .message
    # AccessGrantMsg "Anonymous access granted for %u."
    # # Write disabled in anonymous chroot
    # <Limit WRITE>
    # DenyAll
    # </Limit>
    #</Anonymous>
    <Global>
    RootLogin on
    DefaultChdir /dados/pub
    LoginPasswordPrompt on
    AccessGrantMsg "Login efetuado com sucesso"
    AuthAliasOnly off
    </Global>
    <Anonymous /dados/pub>
    User nobody
    UserAlias anonymous nobody guest
    Group nobody
    DisplayLogin .message
    </Anonymous>
    <Limit WRITE>
    DenyAll
    </Limit>
    Padrão Re: ProFTP Bloqueado
    De uma olhada no script de iniciação do proftp... qq coisa mata o processo e inicializa novamente
    geofesteiro
    Qual a versao do seu proftpd ???
    tente atualizar ele pois eu tive este mesmo problema e com a atualizacao funcionou normal
    flow
    mrsoliveira
    Citação Postado originalmente por geofesteiro
    flow
    [[email protected] home]# proftpd -v
    - ProFTPD Version 1.2.10
    geofesteiro
    estranho que é a mesma versao que eu uso + se vc preferir eu posto o meu conf ai pra vc pode dar uma comparada okk
    espero resp
    flow
