    Padrão (RESOLVIDO) bloqueio messenger,emule,mopheus,kazaa
    Ai galera....resolvi os meus problemas...vou passar scripts...para vcs nao sei se vai resolver para vcs pra min ta blz agora..desde ja agradeco a ajuda de todos.LEMBRO QUE TBM NAO SEI SE ASSIM TO PROTEGIDO SO SEI QUE O MESSENGER JA ERA.
    #FIREAL
    firewall_start(){
    # Abre para uma faixa de endereços da rede local
    iptables -A INPUT -p tcp -s 192.168.1.0/255.255.255.0 -j ACCEPT
    iptables -A INPUT -p udp -s 192.168.1.0/255.255.255.0 -j ACCEPT
    #============================ BLOQUEIO MESSENGER E OUTROS =====================================
    iptables -A FORWARD -s 192.168.1.0/24 -p tcp --dport 1024:65535 -j DROP
    iptables -A FORWARD -s 192.168.1.0/24 -p udp --dport 1024:65535 -j DROP
    # Abre uma porta (inclusive para a Internet)
    iptables -A INPUT -p tcp --destination-port 80 -j ACCEPT
    iptables -A INPUT -p tcp --destination-port 22 -j ACCEPT
    iptables -A INPUT -p tcp --destination-port 8080 -j ACCEPT
    # Ignora pings
    echo "1" > /proc/sys/net/ipv4/icmp_echo_ignore_all
    # Protege contra synflood
    echo "1" > /proc/sys/net/ipv4/tcp_syncookies
    # Proteção contra ICMP Broadcasting
    echo "1" > /proc/sys/net/ipv4/icmp_echo_ignore_broadcasts
    # Bloqueia traceroute
    iptables -A INPUT -p udp --dport 33435:33525 -j DROP
    # Proteções diversas contra portscanners, ping of death, ataques DoS, etc.
    iptables -A FORWARD -p icmp --icmp-type echo-request -m limit --limit 1/s -j ACCEPT
    iptables -A FORWARD -p tcp -m limit --limit 1/s -j ACCEPT
    iptables -A FORWARD -m state --state ESTABLISHED,RELATED -j ACCEPT
    iptables -A FORWARD -p tcp --tcp-flags SYN,ACK,FIN,RST RST -m limit --limit 1/s -j ACCEPT
    iptables -A FORWARD --protocol tcp --tcp-flags ALL SYN,ACK -j DROP
    iptables -A FORWARD -m unclean -j DROP
    iptables -A INPUT -m state --state INVALID -j DROP
    iptables -N VALID_CHECK
    iptables -A VALID_CHECK -p tcp --tcp-flags ALL FIN,URG,PSH -j DROP
    iptables -A VALID_CHECK -p tcp --tcp-flags ALL SYN,RST,ACK,FIN,URG -j DROP
    iptables -A VALID_CHECK -p tcp --tcp-flags ALL ALL -j DROP
    iptables -A VALID_CHECK -p tcp --tcp-flags ALL FIN -j DROP
    iptables -A VALID_CHECK -p tcp --tcp-flags SYN,RST SYN,RST -j DROP
    iptables -A VALID_CHECK -p tcp --tcp-flags SYN,FIN SYN,FIN -j DROP
    iptables -A VALID_CHECK -p tcp --tcp-flags ALL NONE -j DROP
    # Abre para a interface de loopback.
    # Esta regra é essencial para o KDE e outros programas gráficos funcionarem adequadamente.
    #iptables -A INPUT -p tcp --syn -s 127.0.0.1/255.0.0.0 -j ACCEPT
    #iptables -A INPUT -i lo -j ACCEPT
    #************************ LIBERACAO PARA CAIXA SEFIP CNS******************************************************#
    iptables -A INPUT -p all -s 200.201.166.200 -j ACCEPT
    iptables -A INPUT -p all -s 200.152.40.23 -j ACCEPT
    iptables -A INPUT -p all -s 200.152.40.50 -j ACCEPT
    iptables -A FORWARD -p all -s 200.201.166.200 -j ACCEPT
    iptables -A FORWARD -p all -s 200.151.40.23 -j ACCEPT
    iptables -A FORWARD -p all -s 200.151.40.50 -j ACCEPT
    iptables -A INPUT -p all -s 200.201.174.207 -j ACCEPT
    iptables -A FORWARD -p all -s 200.201.174.207 -j ACCEPT
    iptables -A INPUT -p all -s 200.201.174.204 -j ACCEPT
    iptables -A FORWARD -p all -s 200.201.174.204 -j ACCEPT
    iptables -A INPUT -p all -s 200.201.173.68 -j ACCEPT
    iptables -A FORWARD -p all -s 200.201.173.68 -j ACCEPT
    iptables -A FORWARD -i lo -j ACCEPT
    iptables -A INPUT -p tcp --syn -s 192.168.1.0/24 -j ACCEPT
    iptables -A INPUT -p tcp -s 192.168.1.0/24 --dport 3128 -m state --state NEW -j ACCEPT
    #FAZENDO O MASCARAMENTO PARA O CNS
    iptables -t nat -I POSTROUTING -s 192.168.1.0/24 -d 200.201.174.202 -j MASQUERADE
    iptables -t nat -I POSTROUTING -s 192.168.1.0/24 -d 200.201.174.203 -j MASQUERADE
    iptables -t nat -I POSTROUTING -s 192.168.1.0/24 -d 200.201.174.204 -j MASQUERADE
    iptables -t nat -I POSTROUTING -s 192.168.1.0/24 -d 200.201.174.205 -j MASQUERADE
    iptables -t nat -I POSTROUTING -s 192.168.1.0/24 -d 200.201.174.206 -j MASQUERADE
    iptables -t nat -I POSTROUTING -s 192.168.1.0/24 -d 200.201.174.207 -j MASQUERADE
    iptables -t nat -I POSTROUTING -s 192.168.1.0/24 -d 200.201.174.208 -j MASQUERADE
    iptables -t nat -I POSTROUTING -s 192.168.1.0/24 -d 200.201.174.209 -j MASQUERADE
    iptables -t nat -I POSTROUTING -s 192.168.1.0/24 -d 200.252.47.237 -j MASQUERADE
    iptables -t nat -I POSTROUTING -s 192.168.1.0/24 -d 200.201.166.100 -j MASQUERADE
    iptables -t nat -I POSTROUTING -s 192.168.1.0/24 -d 200.201.174.68 -j MASQUERADE
    iptables -t nat -I POSTROUTING -d 192.168.1.0/24 -s 200.201.173.68 -j MASQUERADE
    iptables -t nat -I PREROUTING -s 192.168.1.0/24 -d 200.201.174.0/24 -j ACCEPT
    iptables -t nat -I PREROUTING -s 192.168.1.0/24 -d 200.201.173.0/24 -j ACCEPT
    iptables -t nat -I PREROUTING -s 192.168.1.0/24 -d 200.201.166.0/24 -j ACCEPT
    #****************************** FIM **************************************************************************************#
    # Fecha as portas udp de 1 a 1024, abre para o localhost
    iptables -A INPUT -p udp -s 127.0.0.1/255.0.0.0 -j ACCEPT
    iptables -A INPUT -p udp --dport 1:1024 -j DROP
    iptables -A INPUT -p udp --dport 59229 -j DROP
    # Esta regra é o coração do firewall do Kurumin,
    # ela bloqueia qualquer conexão que não tenha sido permitida acima, justamente por isso ela é a última da cadeia.
    iptables -A INPUT -p tcp --syn -j DROP
    /etc/skel-fix/firewall-msg
    firewall_stop(){
    iptables -F
    iptables -X
    iptables -P INPUT ACCEPT
    iptables -P FORWARD ACCEPT
    iptables -P OUTPUT ACCEPT
    case "$1" in
    "start")
    firewall_start
    "stop")
    firewall_stop
    echo "O kurumin-firewall está sendo desativado"
    sleep 2
    echo "ok."
    "restart")
    sleep 1
    echo "ok."
    firewall_stop; firewall_start
    iptables -L -n
    esac
    #================== FIM#=============
    #=========CONFIGURACOES COMPLETA DO SQUID.CONFIG
    http_port 3128
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    cache_mem 16 MB
    maximum_object_size_in_memory 64 KB
    maximum_object_size 16 MB
    minimum_object_size 0 KB
    cache_swap_low 90
    cache_swap_high 95
    cache_dir ufs /var/spool/squid 512 16 256
    visible_hostname kurumin
    ftp_user [email protected]
    refresh_pattern . 15 20% 2280
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl purge method PURGE
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny purge
    http_access deny !Safe_ports
    http_access allow localhost
    #============ LIVRES PARA ACESSO =======================================
    acl livre dstdom_regex "/etc/squid/livre"
    http_access allow livre
    #LIBERACAO PATRAO....AQUI LIBERA TUDO PARA OS CHEFAOS. ATE MESSENGER E OUTROS
    acl rede src 192.168.1.0/24
    acl especial src "/etc/squid/especial"
    http_access deny rede !especial
    # src 192.168.1.0/24 = minha rede exemplo vc adqua a sua
    # /24=mascara 255.255.255.0
    #acl especial libera os patroes, os ips deles estao dentro do arq.txt neste caminho eu criei
    #=================== PROXY TRANSPARENTE
    httpd_accel_host virtual
    httpd_accel_port 80
    httpd_accel_with_proxy on
    #===FIM
    #espero ter ajuda alguem........valeu galera
    Padrão Re: (RESOLVIDO) bloqueio messenger,emule,mopheus,kazaa
    Kra, bastava apenas vc "DROPAR" todas as conexões:
    iptables -P INPUT DROP
    iptables -P FORWARD DROP
    E liberar o que te interessava!!
    Até,
    mtec :-)
    Citação Postado originalmente por mtec
    Até,
    mtec :-)
    Cara, isso me deu uma idéia massa. O que acham de escrever um script para firewall. Todos podem contribuir. Mas cho que para muitos a política padrão DROP não cai muito bem. Podemos fazer duas versões. Padrão DROP e padrão ACCEPT. O que acha?
    Velho valeu pela ideia de bloquear tudo,,,so q eu nao tenho conhecimento nenhum...desse lance que resolve fazer......ai eu fui pegando ideias daqui outras ali...bom e saiu o que passei...mais blz..a partir de agora vou estudar melhor estas opcoes..
    qnto o script do fireall...bom como ja disse vai ficar meio dificil pra mim ajudar por nao ter conhecimento...mais vamo la eu topo ajudar claro.......vamos montar um ideia do que queremos vamo comessa trocando informacoes.....
    AGUARDANDO ....VALEU GALERA..
