  1. Pessoal, estou compilando o net-snmp para configurar o Nagios.
    Quando faço o ./configure OK. Termina sem problemas
    Quando faço o make apresenta o erro abaixo.
    Como resolver ?
    # make
    gcc -E -Iinclude -I./include -I./agent/mibgroup -I. -I. -DDONT_INC_STRUCTS -DBINDIR=/usr/local/bin -x c ./sedscript.in | egrep '^s[/#]' | sed 's/REMOVEME//g;s# */#/#g;s/ *#/#/g;s#/ *#/#g;s/# g/#g/;' > sedscript
    echo 's#DATADIR#/usr/local/share#g' >> sedscript
    echo 's#LIBDIR#/usr/local/lib#g' >> sedscript
    echo 's#BINDIR#/usr/local/bin#g' >> sedscript
    echo 's#PERSISTENT_DIRECTORY#/var/net-snmp#g' >> sedscript
    echo 's#SYSCONFDIR#/usr/local/etc#g' >> sedscript
    /usr/bin/sed -f sedscript ./EXAMPLE.conf.def > EXAMPLE.conf
    making all in /usr/local/src/net-snmp-5.3.1/snmplib
    make[1]: Entrando no diretório `/usr/local/src/net-snmp-5.3.1/snmplib'
    /bin/sh ../libtool --mode=compile gcc -I../include -I. -I../snmplib -g -O2 -Dlinux -I/usr/include/rpm -c -o snmp_client.lo snmp_client.c
    mkdir .libs
    gcc -I../include -I. -I../snmplib -g -O2 -Dlinux -I/usr/include/rpm -c snmp_client.c -fPIC -DPIC -o .libs/snmp_client.lo
    In file included from /usr/include/bits/errno.h:25,
    from /usr/include/errno.h:36,
    from snmp_client.c:45:
    /usr/include/linux/errno.h:4:23: asm/errno.h: No such file or directory
    snmp_client.c: In function `snmp_synch_response_cb':
    snmp_client.c:1018: error: `EINTR' undeclared (first use in this function)
    snmp_client.c:1018: error: (Each undeclared identifier is reported only once
    snmp_client.c:1018: error: for each function it appears in.)
    snmp_client.c: In function `snmp_sess_synch_response':
    snmp_client.c:1097: error: `EINTR' undeclared (first use in this function)
    make[1]: ** [snmp_client.lo] Erro 1
    make[1]: Saindo do diretório `/usr/local/src/net-snmp-5.3.1/snmplib'
    make: ** [subdirs] Erro 1
  2. Fala spyder...
    Este net-snmp não seria para configurar o MRTG ao nvés do Nagios??
    Acredito que vc usa o Slack 10.2. Então pq vc simplesmente não o instala usando o slapt-get??
    Acredito que vc tenha problemas de dependêcia de pacotes / bibliotecas. Isso slapt vai resolver para vc!!
    O nome do pacote para Slackware 10.2 é net-snmp-5.3.0.1-i486-1kjz.
    Até
    PS: Ficou maior carnaval aí em cima... mas tudo bem, he he!!
  1. problemas na compilaçao do Openvpn
    Por roggy no fórum Servidores de Rede
    Último Post: 17-03-2006, 11:01
  2. problemas na compilação dos plugins do nagios
    Respostas: 9
    Último Post: 13-07-2005, 16:03
  3. Problemas na compilacao do pam_mysql
    Por danielssribeiro no fórum Servidores de Rede
    Último Post: 08-03-2005, 15:20
  4. Problema na compilação do iptables-p2p
    Por Daniels no fórum Servidores de Rede
    Último Post: 21-10-2004, 16:39
  5. Problema na compilaçao do kernel 2.6.7!
    Por nozey no fórum Servidores de Rede
    Respostas: 7
    Último Post: 03-08-2004, 19:28
