    testeteste
    Bom pessoal vou explicar
    Tenho 03 Eth's
    Eth0 = Router ( Internet )
    Eth1= Lan Segura ( Acesso Full )
    Eth2= Lan insegura ( Proxy)
    Como este script quero deixar um nat full para a eth1 e o que passar pela eth2 cair no proxy
    segue firewall
    #!/bin/bash
    IPT=`which iptables`;
    LAN_ROUTER='eth0'
    LAN_INTRANET_SEG='eth1'
    LAN_INTRANET_LAB='eth2'
    IP_ROUTER='10.68.25.1'
    IP_INTRASEG='192.168.1.1'
    IP_INTRALAB='192.168.2.1'
    LAN_IP_ROUTER='10.68.25.0/8'
    LAN_IP_SEG='192.168.1.0/24'
    LAN_IP_LAB='192.168.2.0/24'
    #ativa o roteamento dinamico
    echo 1 > /proc/sys/net/ipv4/ip_dynaddr
    # ================ POLITICAS PADRAO ===================
    $IPT -t filter -P INPUT DROP
    $IPT -t filter -P FORWARD DROP
    $IPT -t filter -P OUTPUT ACCEPT
    $IPT -t nat -P PREROUTING ACCEPT
    $IPT -t nat -P POSTROUTING ACCEPT
    $IPT -t nat -P OUTPUT ACCEPT
    $IPT -t mangle -P PREROUTING ACCEPT
    $IPT -t mangle -P POSTROUTING ACCEPT
    $IPT -t mangle -P OUTPUT ACCEPT
    $IPT -t mangle -P INPUT ACCEPT
    $IPT -t mangle -P FORWARD ACCEPT
    # Cria chain com regras de segurança
    $IPT -N BLOCK
    $IPT -A BLOCK -p icmp --icmp-type echo-request -j DROP
    $IPT -A BLOCK -p icmp --icmp-type echo-request -m limit --limit 1/s -j ACCEPT
    $IPT -A BLOCK -p tcp -m limit --limit 1/s -j ACCEPT
    $IPT -A BLOCK -p tcp --tcp-flags SYN,ACK,FIN,RST SYN -m limit --limit 1/s -j ACCEPT
    $IPT -A BLOCK -m unclean -j DROP
    $IPT -A BLOCK -m state --state ESTABLISHED,RELATED -j ACCEPT
    $IPT -A BLOCK -j LOG --log-prefix "FW_ALERT: "
    $IPT -A BLOCK -j DROP
    # Muda a prioridade dos pacotes (Type Of Service) para agilizar as coisas
    $IPT -t mangle -A OUTPUT -o $LAN_ROUTER -p tcp -m multiport --dports 21,22,80,6667 -j TOS --set-tos 0x10
    # Libera todo o trafego local
    $IPT -t filter -A INPUT -i lo -j ACCEPT
    $IPT -t filter -A INPUT -i $LAN_INTRANET_SEG -j ACCEPT
    $IPT -t filter -A INPUT -i $LAN_INTRANET_LAB -j ACCEPT
    $IPT -t filter -A FORWARD -i $LAN_INTRANET_SEG -j ACCEPT
    $IPT -t filter -A FORWARD -i $LAN_INTRANET_LAB -j ACCEPT
    # Libera a conexao para a rede interna
    $IPT -t nat -A POSTROUTING -s $LAN_IP_SEG -j MASQUERADE
    iptables -t nat -A PREROUTING -i $LAN_ROUTER -p tcp --dport 80 -j DNAT --to 192.168.2.1:3128
    # Regras para evitar packet flood
    $IPT -A INPUT -j BLOCK
    $IPT -A FORWARD -j BLOCK
    ainda estou terminando
    leysen
    não esquece de dar uma olhada no msn , ataques por bruta força !
  1. script htb esta correto ?
    Por odragaonegro no fórum Servidores de Rede
    Último Post: 12-09-2008, 20:10
  2. firewall esta correto?
    Por X-LOGAN no fórum Servidores de Rede
    Último Post: 27-06-2005, 10:53
  3. firewall esta bloqueando dhcp???
    Por Neckratal no fórum Servidores de Rede
    Último Post: 24-03-2004, 14:34
  4. Erro no script Firewall
    Por danielvbhp no fórum Servidores de Rede
    Respostas: 5
    Último Post: 01-02-2004, 09:33
  5. Vejam esse script firewall/nat, aonde tá o erro?
    Respostas: 5
    Último Post: 02-11-2002, 21:47
