    Padrão squid + squidguard
    Caros, estou com um problema, tentei implementar o squid + squidguard, os dois serviços levantam sem nenhum problema, no squid.conf coloquei o "redirect_program /usr/bin/squidGuard -c /etc/squid/squidGuard.conf" pra subir o squidguard nos logs do squidguard diz q esta esperando requisição, so que as regras nao esta bloqueando.
    Saberiam me dizer o q pode ser??
    Grato
    Padrão Re: squid + squidguard
    Posta a sua configuração aí.
    Citação Postado originalmente por xstefanox
    la vai entao..
    ##squid.conf####################################
    http_port 10.0.0.1:3128
    hierarchy_stoplist cgi-bin ?
    cache deny QUERY
    #acl apache rep_header Server ^Apache
    #broken_vary_encoding allow apache
    cache_mem 8 MB
    cache_swap_low 90
    cache_swap_high 95
    maximum_object_size 16384 KB
    minimum_object_size 0 KB
    maximum_object_size_in_memory 20 KB
    cache_dir ufs /var/log/squid/cache 1000 16 256
    access_log /var/log/squid/logs/access.log squid
    cache_log /var/log/squid/logs/cache.log
    cache_store_log /var/log/squid/logs/store.log
    pid_filename /var/log/squid/logs/squid.pid
    ftp_passive on
    #auth_param basic program /usr/libexec/ncsa_auth /etc/squid/authentic
    #auth_param basic children 5
    #auth_param basic realm Digite sua senha:
    #auth_param basic credentialsttl 2 hours
    #auth_param basic casesensitive on
    refresh_pattern . 0 20% 4320
    #acl auth proxy_auth REQUIRED
    acl rede10 src 10.0.0.0/255.255.255.0
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    #acl deep proxy_auth "/etc/squid/users/deep"
    acl extensoes_blocked urlpath_regex -i .scr$ .exe$ .mp3$
    acl blocked_domains dstdom_regex -i "/etc/squid/blocked/domains"
    acl blocked_urls url_regex -i "/etc/squid/blocked/urls"
    acl unblocked_domains dstdom_regex -i "/etc/squid/unblocked/domains"
    acl unblocked_urls url_regex -i "/etc/squid/unblocked/urls"
    acl rede10_blocked src "/etc/squid/ips/ips_blocked"
    acl rede10_unblocked src "/etc/squid/ips/ips_unblocked"
    #http_access allow deep !deep_url_block
    #http_access deny deep !deep_url_unblock
    http_access allow rede10_blocked !blocked_domains !blocked_urls !extensoes_blocked
    http_access deny rede10_blocked !unblocked_domains !unblocked_urls
    http_access deny manager
    http_access deny !Safe_ports
    http_access deny all
    http_reply_access allow all
    httpd_accel_no_pmtu_disc on
    ie_refresh on
    icp_access allow all
    cache_effective_user squid
    coredump_dir /var/log/squid/cache
    ### fim ###
    ### squidGuard.conf ###
    logdir /usr/local/squidGuard/log
    dbhome /usr/local/squidGuard/db
    src escritorio {
    ip 10.0.0.0/24
    dest porn {
    domainlist domains
    acl {
    escritorio {
    pass !porn all
    default {
    pass none
    ### fim ###
    squid v. 2.6stable2
    squidguard 1.2
    Grato
    e ai alg teria alguma ideia do q pode estar acontecendo?
