Ae Pessoal, instalei o squid pelo seu pacote tgz, nao apresenta erro durante compilação, acontece que quando o inicio (squid -D) no log de cache ele apresenta o seguinte log:
2006/08/07 11:53:23| Starting Squid Cache version 2.5.STABLE10 for i686-pc-linux-gnu...
2006/08/07 11:53:23| Process ID 4994
2006/08/07 11:53:23| With 1024 file descriptors available
2006/08/07 11:53:23| DNS Socket created at 0.0.0.0, port 32784, FD 5
2006/08/07 11:53:23| Warning: Could not find any nameservers. Trying to use localhost
2006/08/07 11:53:23| Please check your /etc/resolv.conf file
2006/08/07 11:53:23| or use the 'dns_nameservers' option in squid.conf.
2006/08/07 11:53:23| Unlinkd pipe opened on FD 10
2006/08/07 11:53:23| Swap maxSize 6291456 KB, estimated 483958 objects
2006/08/07 11:53:23| Target number of buckets: 24197
2006/08/07 11:53:23| Using 32768 Store buckets
2006/08/07 11:53:23| Max Mem size: 102400 KB
2006/08/07 11:53:23| Max Swap size: 6291456 KB
2006/08/07 11:53:23| Rebuilding storage in /var/lib/squid/cache (DIRTY)
2006/08/07 11:53:23| Using Least Load store dir selection
2006/08/07 11:53:23| Current Directory is /root
2006/08/07 11:53:23| Loaded Icons.
2006/08/07 11:53:23| Accepting HTTP connections at 0.0.0.0, port 3128, FD 11.
2006/08/07 11:53:23| Accepting ICP messages at 0.0.0.0, port 3130, FD 12.
2006/08/07 11:53:23| Accepting SNMP messages on port 3401, FD 13.
2006/08/07 11:53:23| WCCP Disabled.
Caso o problema seja o dns , nao entendo o pq , já que o dns que coloquei eh o mesmo que uso pra navegar em clientes.
Segue abaixo também, o squid.conf:
http_port 3128
visible_hostname Slackware
#Configuracao do Cache
cache_mem 100 MB
maximum_object_size_in_memory 64 KB
maximum_object_size 512 MB
minimum_object_size 0 KB
cache_swap_low 90
cache_swap_high 95
cache_dir ufs /var/lib/squid/cache 6144 16 256
cache_access_log /var/lib/squid/logs/access.log
refresh_pattern . 15 20% 2280
acl all src 0.0.0.0/0.0.0.0
acl SSL_ports port 443 563
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl purge method PURGE
acl CONNECT method CONNECT
http_access deny manager
http_access deny purge
http_access deny !Safe_ports
http_access allow localhost
cache_effective_user nobody
cache_effective_group nogroup
# Configuracao da senha para internet
acl redelocal src 192.168.10.104
http_access allow redelocal
http_access deny all
#Proxy Transparente
httpd_accel_host virtual
httpd_accel_port 80
httpd_accel_with_proxy on
>>> Quando o Inicio, nas maquinas clientes elas nao navegam, apesar de ecntrar o dominio, mas nao carrega, penso tb que possa ser um problema no cache. mas as permissões foram dadas para escrita ao usuário nobody
Citação
