    Padrão Mensagem do Kernel
    Bom dia a todos ae, será q alguem sabe o que pode ser essas mensagem q está aparecendo várias vezes no meu log?
    Aug 8 08:33:02 sf kernel: NETDEV WATCHDOG: eth0: transmit timed out
    Aug 8 08:33:02 sf kernel: eth0: transmit timed out, tx_status 00 status e000.
    Aug 8 08:33:02 sf kernel: diagnostics: net 0812 media 8880 dma 00000012 fifo 0000
    Aug 8 08:33:02 sf kernel: Flags; bus-master 1, dirty 1402893(13) current 1402909(13)
    Aug 8 08:33:02 sf kernel: Transmit list 00000000 vs. c626aa20.
    Aug 8 08:33:02 sf kernel: 0: @c626a200 length 8000042f status 0001042f
    Aug 8 08:33:02 sf kernel: 1: @c626a2a0 length 80000045 status 00010045
    Aug 8 08:33:02 sf kernel: 2: @c626a340 length 8000042f status 0001042f
    Aug 8 08:33:02 sf kernel: 3: @c626a3e0 length 80000045 status 00010045
    Aug 8 08:33:02 sf kernel: 4: @c626a480 length 80000066 status 00010066
    Aug 8 08:33:02 sf kernel: 5: @c626a520 length 8000042f status 0001042f
    Aug 8 08:33:02 sf kernel: 6: @c626a5c0 length 80000172 status 00010172
    Aug 8 08:33:02 sf kernel: 7: @c626a660 length 8000002a status 0001002a
    Aug 8 08:33:02 sf kernel: 8: @c626a700 length 8000042f status 0001042f
    Aug 8 08:33:02 sf kernel: 9: @c626a7a0 length 80000172 status 00010172
    Aug 8 08:33:02 sf kernel: 10: @c626a840 length 80000054 status 00010054
    Aug 8 08:33:02 sf kernel: 11: @c626a8e0 length 8000002a status 8001002a
    Aug 8 08:33:02 sf kernel: 12: @c626a980 length 80000045 status 80010045
    Aug 8 08:33:02 sf kernel: 13: @c626aa20 length 8000042f status 0001042f
    Aug 8 08:33:02 sf kernel: 14: @c626aac0 length 80000066 status 00010066
    Aug 8 08:33:02 sf kernel: 15: @c626ab60 length 8000042f status 0001042f
    hijack
    Padrão Re: Mensagem do Kernel
    Mas você realmente usa uma placa de Watchdog?
    Citação Postado originalmente por hijack
    Rapaz, eu nao tenho nem ideia do que seria uma placa de Watchdog...
    hijack
    É um dispositivo usado para monitorar o hardware, caso ele "trave" ou de algum pau, o watch dog reseta a maquina. Desabilite no kernel ou procure o nome do modulo (lsmod) e tire ele na inicialização... (/etc/modules.conf)
    Abraços!
    se seu computador estava funcionando normalmente de uma hora pra outra comecou a enviar essa mensagem é porque sua placa de rede esta com mau contato no slot ou esta com defeito na mesma....ja tive essa problema antes e era a placa de rede
    Citação Postado originalmente por Bravo
    Realmente, começou a aparecer ha alguns dias essa msg... eu até tinha pensado na placa de rede, agora tenho certeza... vou trocar ela entao.
    Vlw
    se vc trocou a placa de rede e funcionou , nos envie a resposta pra que esse topico seja finalizado, assim tira a duvida de outros colegas..
    Abracos a todos
    É o seguinte, eu nao troquei a placa de rede nao.... vou explicar o q eu fiz:
    Esse meu pc q tava dando esse erro, estava tb com um outro problema de "segmentation fault" entao no sábado a tarde, eu peguei e montei um outro servidor e coloquei no lugar dele pra nao atrapalhar a galera que trabalha aqui, e assim eu poder dar manutençao com calma. Quando fui reinstalar os pacotes coreutils, ele comecou a dar pau... e bichou de vez. Entao formatei ele e levantei todos os processos novamente, e nessa hora eu decidi nao trocar a placa de rede, pra ver se mesmo formatado ele ia continuar dando o erro citado acima. Aí a minha surpresa, depois de formatar meu server, e levantá-lo novamente, ele nao deu mais esse erro que eu perguntei acima, me deixando com a conclusão de q o problema nao era minha placa de rede. Está aí o resultado pessoal, nao era a minha placa de rede, era algum problema no meu linux, e infelizmente ele deu pau e nao tive como descobrir o que poderia ser.
    Mas valeu a todos.
