    Padrão Limitar Download
    Observei a ordem das regras tentei assim, e não deu certo.
    reply_body_max_size 1597440 allow all
    reply_body_max_size 5242880 allow proxy_auth fulano
    Mudei a ordem dessas linhas e nada, da a mesma mensagem de erro, deem uma olhada nela
    squid.conf line 2019: reply_body_max_size 52428800 allow proxy_auth fulano
    aclParseAccessLine: ACL name 'proxy_auth' not found.
    aclParseAccessLine: ACL name 'fulano' not found.
    aclParseAccessLine: Access line contains no ACL's, skipping
    Agradeço desde ja a ajuda de todos.
    Padrão Re: Limitar Download
    Do arquivo de configuração do Squid, squid.conf:
    # TAG: reply_body_max_size bytes allow|deny acl acl...
    # This option specifies the maximum size of a reply body in bytes.
    # It can be used to prevent users from downloading very largefiles,
    # such as MP3's and movies. When the reply headers are recieved,
    # the reply_body_max_size lines are processed, and the first line with
    # a result of "allow" is used as the maximum body size for this reply.
    # This size is checked twice. First when we get the reply headers,
    # we check the content-length value. If the content length value exists
    # and is larger than the allowed size, the request is denied and the
    # user receives an error message that says "the request or reply
    # is too large." If there is no content-length, and the reply
    # size exceeds this limit, the client's connection is just closed
    # and they will receive a partial reply.
    # WARNING: downstream caches probably can not detect a partial reply
    # if there is no content-length header, so they will cache
    # partial responses and give them out as hits. You should NOT
    # use this option if you have downstream caches.
    # If you set this parameter to zero (the default), there will be
    # no limit imposed.
    #Default:
    # reply_body_max_size 0 allow all
    O problema é que você não declarou as ACL's que você está puxando, como proxy_auth e fulano, só para lembrar um pouco, proxy_auth é um tipo de ACL, e não pode ser utilizado como o nome de ACL's.
    Para utilizar da maneira que deseja, você deve criar uma ACL, chamada fulano:
    Código :
    acl fulano proxy_auth uepaehmeunomedeusuario
    E utilizar a tag da seguinte maneira:
    Código :
    reply_body_max_size 20971520 allow fulano
    Sacou, sacou?
    Um abraço!
    E utilizar da seguinte maneira:
    Deu 100% certo, agradeço a ajuda de todos só tem fera aqui na under, espero aprender muito aqui com vc's.
    Abraço a todos
    O karma positivo ninguém lembra, hehehehe.
    Stéfano ...........
    De Squid é sopa para voê ..........
    Eu fico só acompanhando e aprendendo ...........hehehehehehe
    E continue assim .................
    Squid é contigo mesmo ............... :-)
