    mirror
    Quando tento ingressar um XP no samba + ldap, eu recebo a seguinte mensagem:
    Erro durante a tentativa de ingresso no dominio "labs"
    O nome da rede especificado não está mais disponível.
    Essa msg eh dada após informar o usuário e senha.
    Esse é o trecho de um dos arquivos de log:
    [2006/09/19 16:30:13, 3] smbd/sesssetup.c:reply_sesssetup_and_X_spnego(633)
    Doing spnego session setup
    [2006/09/19 16:30:13, 3] smbd/sesssetup.c:reply_sesssetup_and_X_spnego(664)
    NativeOS=[Windows 2002 Service Pack 2 2600] NativeLanMan=[Windows 2002 5.1] PrimaryDomain=[]
    [2006/09/19 16:30:13, 3] libsmb/ntlmssp.c:ntlmssp_server_auth(647)
    Got user=[ root] domain=[labs] workstation=[ADM_TI_004] len1=24 len2=24
    outro log:
    [2006/09/19 16:03:31, 3] smbd/service.c:close_cnum(885)
    adm_ti_004 (192.168.0.149) closed connection to service IPC$
    [2006/09/19 16:03:31, 3] smbd/connection.c:yield_connection(69)
    Yielding connection to IPC$
    [2006/09/19 16:03:31, 3] smbd/sec_ctx.c:set_sec_ctx(288)
    setting sec ctx (0, 0) - sec_ctx_stack_ndx = 0
    [2006/09/19 16:03:52, 3] smbd/process.c:timeout_processing(1447)
    timeout_processing: End of file from client (client has disconnected).
    [2006/09/19 16:03:52, 3] smbd/sec_ctx.c:set_sec_ctx(288)
    [2006/09/19 16:03:52, 2] smbd/server.c:exit_server(614)
    Closing connections
    [2006/09/19 16:03:52, 3] smbd/connection.c:yield_connection(69)
    [2006/09/19 16:03:52, 3] smbd/server.c:exit_server(655)
    Server exit (normal exit)
    [2006/09/19 16:08:46, 3] lib/util_seaccess.c:se_access_check(250)
    [2006/09/19 16:08:46, 3] lib/util_seaccess.c:se_access_check(251)
    se_access_check: user sid is S-1-5-21-2075056165-4197823942-2122372495-3000
    se_access_check: also S-1-5-21-2075056165-4197823942-2122372495-1001
    se_access_check: also S-1-1-0
    se_access_check: also S-1-5-11
    se_access_check: also S-1-5-32-544
    [2006/09/19 16:08:46, 3] printing/printing.c:start_background_queue(1379)
    start_background_queue: Starting background LPQ thread
    [2006/09/19 16:08:46, 2] smbd/server.cpen_sockets_smbd(336)
    waiting for a connection
    Obrigado a todos,
    Lucas
  2. fala lucas!
    verifique se o serviço smbd está carregado.. já tive o mesmo problema e era o serviço que não estava carregado!
    o samba tem uma doc extensa e muitos tutoriais na net.. a maioria dos erros é configuração errada mesmo!
    abraços..
  1. Windows XP reinicia quando tenta logar no samba+ldap
    Por noir no fórum Servidores de Rede
    Respostas: 5
    Último Post: 07-04-2008, 22:58
  2. Pequeno erro após fazer LOGON com Windows XP no SAMBA (PDC)
    Por mardonio no fórum Servidores de Rede
    Último Post: 27-03-2005, 10:01
  3. Erro ao logar no SAMBA
    Último Post: 07-05-2004, 06:18
  4. erro de logon no samba
    Por TonTux no fórum Servidores de Rede
    Último Post: 26-08-2003, 20:08
  5. Mensagem pedindo para trocar senha apos logon do XP no Samba
    Por Hacinn no fórum Servidores de Rede
    Respostas: 5
    Último Post: 20-06-2003, 08:01
