    Padrão firewall bloqueando minha propria conexão velox
    Boa tarde a todos !!!!!
    Galera estou com um problema. (como sempre)
    o que acontece?
    só consigo fazer conexão com a velox, se eu limpar minhas regras do firewall.
    segue o meu firewall.
    #!/bin/bash
    ### Limpa a tela #######################################################
    clear
    ### Define as variaveis #################################################
    IPT=iptables
    REDE=eth0
    LAN=192.168.1.0/24
    IFNET=ppp+
    LO=lo
    LOCALHOST=127.0.0.1
    ### Carregando os modulos necessarios ###################################
    modprobe ip_tables
    modprobe iptable_nat
    modprobe iptable_filter
    modprobe iptable_mangle
    modprobe ipt_conntrack
    modprobe ipt_limit
    modprobe ipt_REDIRECT
    modprobe ipt_TOS
    modprobe ipt_MASQUERADE
    ### Apagando e definindo as politicas padroes do firewall ###############
    $IPT -t filter -F
    $IPT -t filter -X
    $IPT -t filter -Z
    $IPT -t nat -F
    $IPT -t nat -X
    $IPT -t nat -Z
    $IPT -t filter -P INPUT DROP
    $IPT -t filter -P OUTPUT ACCEPT
    $IPT -t filter -P FORWARD ACCEPT
    $IPT -t nat -P PREROUTING ACCEPT
    $IPT -t nat -P OUTPUT ACCEPT
    $IPT -t nat -P POSTROUTING ACCEPT
    $IPT -t mangle -P PREROUTING ACCEPT
    $IPT -t mangle -P OUTPUT ACCEPT
    ### Anti-spoofing #######################################################
    for i in /proc/sys/net/ipv4/conf/*/rp_filter; do
    echo 1 >$i
    done
    ### Ativa o redirecionamento de pacotes #################################
    # Define o máximo de conexões para evitar sobrecarga do servidor ########
    echo 4096 > /proc/sys/net/ipv4/ip_conntrack_max
    ###################### Tabela filter ####################################
    ### Chain INPUT #########################################################
    # Criamos uma nova chain para tratamento da internet
    $IPT -N ppp-input
    ### Aceita todo o tráfego vindo do loopback e indo para o loopback ######
    $IPT -A INPUT -i $LO -j ACCEPT
    ### Todo o tráfego da rede interna também é aceito ######################
    $IPT -A INPUT -s $LAN -i $REDE -j ACCEPT
    ### Libera a porta do SSH ################################################
    $IPT -A INPUT -p tcp --syn --dport 22 -j ACCEPT
    $IPT -A INPUT -p tcp --dport 3050 -j ACCEPT
    $IPT -A INPUT -p udp --dport 3050 -j ACCEPT
    $IPT -A INPUT -p tcp --dport 3050 -m state --state ESTABLISHED,RELATED -j ACCEPT
    $IPT -A OUTPUT -p tcp --dport 3050 -m state --state ESTABLISHED,RELATED -j ACCEPT
    ### Conexões vindas da interface ppp0 são tratadas pela chain ppp-input ##
    $IPT -A INPUT -i $IFNET -j ppp-input
    ### Qualquer outra conexão desconhecida é imediatamente logada e derrubada
    #$IPT -A INPUT -j LOG --log-prefix "Firewall: Input-derrubado"
    #$IPT -A INPUT -j DROP
    #### Chain FORWARD #######################################################
    # Permite o redirecionamento de conexões entre as interfaces locais ######
    # Qualquer tráfego indo e vindo para outras interfaces será bloqueado ####
    # Bloqueia o msn
    $IPT -A FORWARD -s $LAN -p tcp --dport 1863 -j DROP
    # Bloqueia a transferencia de arquivos do msn
    $IPT -A FORWARD -s $LAN -i $REDE -o $IFNET -p tcp --dport 6891:6900 -j DROP
    $IPT -A FORWARD -d $LAN -i $IFNET -o $REDE -p tcp --dport 6891:6900 -j DROP
    # Bloqueia o orkut
    $IPT -A FORWARD -s $LAN -i $REDE -p tcp -d 64.233.171.85 -j DROP
    $IPT -A FORWARD -s 64.233.171.85 -i $IFNET -p tcp -d $LAN -j DROP
    $IPT -A FORWARD -d $LAN -i $IFNET -o $REDE -j ACCEPT
    $IPT -A FORWARD -s $LAN -i $REDE -o $IFNET -j ACCEPT
    #$IPT -A FORWARD -j LOG --log-prefix "Firewall: FORWARD negado"
    $IPT -A FORWARD -j DROP
    #Libera o outlook
    $IPT -A FORWARD -p udp -s 192.168.1.0/24 -d 200.149.55.142 --dport 53 -j ACCEPT
    $IPT -A FORWARD -p udp -s 192.168.1.0/24 -d 200.165.132.155 --dport 53 -j ACCEPT
    $IPT -A FORWARD -p udp -s 200.165.132.155 --sport 53 -d 192.168.1.0/24 -j ACCEPT
    $IPT -A FORWARD -p udp -s 200.149.55.142 --sport 53 -d 192.168.1.0/24 -j ACCEPT
    $IPT -A INPUT -p tcp -i $IFNET --sport 80 -j ACCEPT
    $IPT -A INPUT -p tcp -i $IFNET --sport 443 -j ACCEPT
    $IPT -A INPUT -p tcp -i $IFNET --sport 20 -j ACCEPT
    $IPT -A INPUT -p tcp -i $IFNET --sport 21 -j ACCEPT
    $IPT -A FORWARD -p tcp -s 192.168.1.0/24 --dport 25 -j ACCEPT
    $IPT -A FORWARD -p tcp -s 192.168.1.0/24 --dport 110 -j ACCEPT
    $IPT -A FORWARD -p tcp --sport 25 -j ACCEPT
    $IPT -A FORWARD -p tcp --sport 110 -j ACCEPT
    #### Chain ppp-input #####################################################
    # Aceita pings vindos da internet com certa limitação ####################
    $IPT -A ppp-input -p icmp -m limit --limit 2/s -j ACCEPT
    ### Aceitamos o tráfego vindo da internet para o serviço www (porta 80) ##
    $IPT -A ppp-input -p tcp --dport 80 -j ACCEPT
    ### Tentativas de acesso aos serviços listados abaixo serão registrados ##
    #$IPT -A ppp-input -p tcp --dport 21 -j LOG --log-prefix "Firewall: FTP "
    #$IPT -A ppp-input -p tcp --dport 22 -j LOG --log-prefix "Firewall: SSH "
    #$IPT -A ppp-input -p tcp --dport 25 -j LOG --log-prefix "Firewall: SMTP "
    #$IPT -A ppp-input -p udp --dport 53 -j LOG --log-prefix "Firewall: DNS "
    #$IPT -A ppp-input -p tcp --dport 110 -j LOG --log-prefix "Firewall: POP3 "
    #$IPT -A ppp-input -p tcp --dport 113 -j LOG --log-prefix "Firewall: IDENTD "
    #$IPT -A ppp-input -p tcp --dport 111 -j LOG --log-prefix "Firewall: RPC "
    #$IPT -A ppp-input -p udp --dport 111 -j LOG --log-prefix "Firewall: RPC "
    #$IPT -A ppp-input -p tcp --dport 137:139 -j LOG --log-prefix "Firewall: SMB "
    #$IPT -A ppp-input -p udp --dport 137:139 -j LOG --log-prefix "Firewall: SMB "
    ### Bloqueia qualquer conexão de fora para esta máquina ##################
    #$IPT -A ppp-input -m state --state ! ESTABLISHED,RELATED -j LOG --log-prefix "Firewall: ppp-in "
    $IPT -A ppp-input -m state --state ! ESTABLISHED,RELATED -j DROP
    ### Qualquer outro tipo de tráfego é aceito ##############################
    $IPT -A ppp-input -j ACCEPT
    ########################## Tabela nat ###################################
    ##### Chain POSTROUTING ######
    # Permite qualquer conexão vinda com destino a lo e rede local para placa
    # de rede da rede interna ( ethx ) ######################################
    $IPT -t nat -A POSTROUTING -o $LO -j ACCEPT
    $IPT -t nat -A POSTROUTING -s $LAN -o $REDE -j ACCEPT
    ### Redirecionamento de VNC no micro da rede interna #####################
    # terminal server ########################################################
    #IPT -t nat -A PREROUTING -p tcp --dport 5900 -i $REDE -j DNAT --to 10.0.0.5
    #IPT -t nat -A PREROUTING -p udp --dport 5900 -i $REDE -j DNAT --to 10.0.0.5
    ### Não queremos que os usuários tenham acesso externo aos serviços listados
    ### abaixo usaremos o squid para controle
    ### Redireciona as con. da porta 80 p/ 3120 do squid
    $IPT -t nat -N SRed
    $IPT -t nat -A SRed -p tcp -j REDIRECT --to-port 3128
    $IPT -t nat -I SRed -s $LAN -d 64.247.85.226 -i $IFNET -j RETURN
    $IPT -t nat -A PREROUTING -i $REDE -s $LAN -p tcp --dport 80 -j SRed
    $IPT -t nat -A PREROUTING -i $REDE -p tcp --dport 80 -j REDIRECT --to-port 3128
    ### Registramos as tentativas de conexões diretas a estes serviços #######
    #$IPT -t nat -A POSTROUTING -s $LAN -o $IFNET -p tcp --dport 80 -j LOG --log-prefix "Firewall: SNAT-www "
    #$IPT -t nat -A POSTROUTING -s $LAN -o $IFNET -p tcp --dport 25 -j LOG --log-prefix "Firewall: SNAT-smtp "
    #$IPT -t nat -A POSTROUTING -s $LAN -o $IFNET -p tcp --dport 25 -j DROP
    #$IPT -t nat -A POSTROUTING -s $LAN -o $IFNET -p tcp --dport 80 -j DROP
    ### É feito o masquerading dos outros serviços da rede interna indo para a
    ### interface ppp+
    $IPT -t nat -A POSTROUTING -s $LAN -o $IFNET -j MASQUERADE
    ### Qualquer outra origem de tráfego desconhecida indo para a placa de rede
    # da rede interna (ethx) #################################################
    #$IPT -t nat -A POSTROUTING -o $REDE -d $LAN -j LOG --log-prefix "Firewall: SNAT-unknow "
    #$IPT -t nat -A POSTROUTING -o $REDE -d $LAN -j DROP
    ### Não bloquearemos a conexão PPP+ ######################################
    $IPT -t nat -A POSTROUTING -o $IFNET -j ACCEPT
    ### Registra e bloqueia qualquer outro tipo de tráfego desconhecido #####
    #$IPT -t nat -A POSTROUTING -j LOG --log-prefix "Firewall: SNAT "
    $IPT -t nat -A POSTROUTING -j DROP
    ######## Tabela mangle ###################################################
    #### Chain OUTPUT ######
    # prioriza o DNS #########################################################
    $IPT -t mangle -A OUTPUT -o $IFNET -p udp --dport 53 -j TOS --set-tos 0x10
    #$IPT -t mangle -A OUTPUT -o $IFNET -p udp --dport 443 -j TOS --set-tos 0x10
    $IPT -t mangle -A OUTPUT -o $IFNET -p udp --dport 3050 -j TOS --set-tos 0x10
    ### prioriza o SSH #######################################################
    $IPT -t mangle -A OUTPUT -o $IFNET -p tcp --dport 22 -j TOS --set-tos 0x10
    ### Precaução ############################################################
    $IPT -A INPUT -p tcp --syn -j DROP
    se alguém conseguir visualizar aonde está errado, agradeço.
    Padrão Re: firewall bloqueando minha propria conexão velox
    William,
    Dei uma olhada rápida, e a principio o que notei é na declaração das variaveis, você colocou ppp+, mais normalmente as coneções são criadas como ppp0. Tente mudar para ver, que amanhã com mais calma farei um teste em firewall de testes e te passo os resultados..
    Abs,
    Wellington R. Felix
    Muito obrigado!!
    Cara acredito eu que, o que poderia estar acontecendo estava referente a rotas.
    Pois logo depois de executar o comando route del default e route add default ppp0 consegui navegar.
    vc ache que devo incluir esta regra do firewall para sempre adicionar uma rota?
    e se não estou engando o ppp+ server para informar que e qualquer tipo de conexão ppp, não importando que seje ppp0 ou ppp1 e assim consecutivamente.
    cara me desculpa se falei besteira, enho apenas seis meses de servidores linux. então ainda estou muiot enrolado em abordar algumas soluções.
    Atenciosamente,
    WILLIAM FAHHAM
    Pois é ... sua variante devria ser ppp0 e não ppp+
    Falow ...
