    crock-linux
    Padrão Ajuda no proftpd
    Ola amigos
    eu instalei o slackware 11 e ta tudo funcionando....
    porem criei um usuario chamado crocklinux e estou tentando acessar ftp porem ele nao conecta
    alguem tem aguma ideia de que pode ser.
    o proftp ja esta rodando ..
    geofesteiro
    Padrão Re: Ajuda no proftpd
    posta o seu proftpd.conf ai pra gente pode da uma olhada
    okk
    crock-linux
    Ola amigo
    segue abaixo:
    # This is a basic ProFTPD configuration file.
    # It establishes a single server and a single anonymous login.
    # It assumes that you have a user/group "nobody" and "ftp"
    # for normal/anonymous operation.
    ServerName "ProFTPD Servidor Crock-Linux - Linux"
    #ServerType standalone
    ServerType inetd
    DefaultServer on
    DefaultRoot ~
    ServerAdmin [email protected]
    UseReverseDNS off
    IdentLookups off
    # Port 21 is the standard FTP port.
    Port 21
    # Umask 022 is a good standard umask to prevent new dirs and files
    # from being group and world writable.
    Umask 022
    # To prevent DoS attacks, set the maximum number of child processes
    # to 30. If you need to allow more than 30 concurrent connections
    # at once, simply increase this value. Note that this ONLY works
    # in standalone mode, in inetd mode you should use an inetd server
    # that allows you to limit maximum number of processes per service
    # (such as xinetd)
    MaxInstances 30
    # Set the user and group that the server normally runs at.
    User nobody
    Group nogroup
    # This next option is required for NIS or NIS+ to work properly:
    #PersistentPasswd off
    SystemLog /var/log/proftpd.log
    TransferLog /var/log/xferlog
    # Normally, we want files to be overwriteable.
    <Directory /*>
    AllowOverwrite on
    </Directory>
    # A basic anonymous FTP server configuration.
    # To enable this, remove the user ftp from /etc/ftpusers.
    <Anonymous ~ftp>
    RequireValidShell off
    User ftp
    Group ftp
    # We want clients to be able to login with "anonymous" as well as "ftp"
    UserAlias anonymous ftp
    # Limit the maximum number of anonymous logins
    MaxClients 50
    # We want 'welcome.msg' displayed at login, and '.message' displayed
    # in each newly chdired directory.
    DisplayLogin welcome.msg
    DisplayFirstChdir .message
    # Limit WRITE everywhere in the anonymous chroot
    <Limit WRITE>
    DenyAll
    </Limit>
    # An upload directory that allows storing files but not retrieving
    # or creating directories.
    # <Directory incoming/*>
    # <Limit READ>
    # DenyAll
    # </Limit>
    # <Limit STOR>
    # AllowAll
    # </Limit>
    # </Directory>
    </Anonymous>
    to com musuario criado e porem ele nao conecta
    Jul 2001
    Campinas Area
    Que erro ele da?
    crock-linux
    ola amigo
    nao conecta
    Jul 2001
    Campinas Area
    Nao conecta onde? Como? Que erro da? Could not connect?
    O que tem em hosts.allow? e no hosts.deny?
    crock-linux
    Ola amigo
    hosts.allow? e no hosts.deny? os dois nao tem nada
    Jul 2001
    Campinas Area
    E qual é a mensagem de erro que nao sabemos ainda?
    crock-linux
    Ola amigo
    olha o erro que da
    [16:07:52] SmartFTP v2.0.997.4
    [16:07:52] Solucionando nome do domínio "205.57.157.168"
    [16:07:52] Conectando a 205.57.157.168 Porta: 21
    [16:07:52] Conectado a 205.57.157.168.
    [16:07:52] 220 ProFTPD 1.2.10 Server (ProFTPD Servidor Crock-Linux - Linux) [205.57.157.168]
    [16:07:52] USER crocklinux
    [16:07:52] 331 Password required for dedkey.
    [16:07:52] PASS (hidden)
    [16:07:52] 530 Login incorrect.
    [16:07:52] Active Help: http://www.smartftp.com/support/kb/index.php/51
    [16:07:52] Cannot login waiting to retry (30s)...
    so ip que nao ip é esse
    Jul 2001
    Campinas Area
    Bom, ele ta dando erro de usuario/senha, confere se ta certo, caps nao ta ligado, etc
    crock-linux
    ola amigo
    olha so...eu criei um grupo para crocklinux
    ta assim grupo crocklinux usuario crocklinux
    onde eu habilito par ao grupo crocklinux fazer ftp.
    acho que é isso
    Jul 2001
    Campinas Area
    Adiciona o grupo crocklinux em /etc/ftpusers
    crock-linux
    adcionei e reiniciei o proftp porem nao funcionou
    geofesteiro
    entao meu eu testei teu arquivo de conf e ak funciono normal so que o unico detalhe que eu deu uma reparada é o seguinte as duas variaveis de usuario e grupo
    tenta troca as duas para o grupo crocklinux so pra da uma testada que provavelmente vai funciona okk se num funciona posta ai denovo
    crock-linux
    Ola amigo
    User nobody
    Group nogroup
    crocklinux crocklinux
    ok ?
    entao nao funcionou ...
    crock-linux
    Ola amigos
    olha so que tava acontecendo...depois uqe habilitei funcionou
    Nome do usuário ID Group Nome real Diretório inicial Shell
    crocklinux 500 crocklinux Meunome /home/dedkey /bin/false
    mudei para :
    crocklinux 500 crocklinux Meunome /home/dedkey /bin/bash
    so habilitei o bash
    porem que ta o problema.
    este este usuario nao pode ter acesso ao shell, e com isso ele acessa o shell nao faz muita coisa porem tem acesso.
    tenho que deixar usar somente ftp para ele.
    Jul 2001
    Campinas Area
    Cara, voce pois o grupo no lugar errado,
    Esse é o grupo ao qual o daemon faz parte, o seu é lá embaixo, no final do arquivo, junto com ftp, etc.
    crock-linux
    ola amigo..
    vc fala aqui ?
    <Anonymous ~ftp>
    User ftp
    Group ftp
    crocklinux ftp
    assim
    ja tentei e nao funciona se eu tiver com bash bloqueado para ele
    Jul 2001
    Campinas Area
    Edita o arquivo /etc/shells e adiciona "/bin/false"
