    dbecher
    Padrão CUPS - Senha
    Pessoal,
    Estou seguindo este tutorial:
    Linux: Linux imprimindo em Windows via rede [Artigo]
    para imprimir da minha máquina que é Linux (Kubuntu 6.06) numa máquina Windows 98 (sob dominio SAMBA que ta num FC4).
    Eu entro no site que administra o CUPS que ta instalado e tal, e nao me pede senha nenhuma. Somente quando indico o modelo da impressora ele pede senha e nao aceita a senha de nenhum usuario da maquina. Nem a minha de usuario, nem a do Root, nada.
    Alguem tem ideia do que possa ser?
    Ja vou adiantando o meu cupsd.conf:
    Código :
    #   Sample configuration file for the Common UNIX Printing System (CUPS)
    #   scheduler.  See "man cupsd.conf" for a complete description of this
    #   file.
    # Log general information in error_log - change "info" to "debug" for
    # troubleshooting...
    LogLevel warning
    # Administrator user group...
    SystemGroup lp
    # Only listen for connections from the local machine.
    # These settings are configured in /etc/cups/cups.d/ports.conf so that
    # changing them does not require to change this file.
    # Listen localhost:631
    # Listen /var/run/cups/cups.sock
    # Show shared printers on the local network.
    # The 'Browsing' setting is configured in /etc/cups/cups.d/browse.conf
    # so that changing it does not require to change this file.
    # Browsing Off
    BrowseOrder allow
    BrowseAllow @LOCAL
    BrowseAddress @LOCAL
    # Default authentication type, when authentication is required...
    DefaultAuthType Basic
    # Restrict access to the server...
    <Location />
      Order allow,deny
      Allow localhost BACKUP02
    Allow from 192.168.1.0/24
    Allow @LOCAL
    </Location>
    # Restrict access to the admin pages...
    <Location /admin>
      Order allow,deny
    </Location>
    # Restrict access to configuration files...
    <Location /admin/conf>
      AuthType Basic
      Require user @SYSTEM
      Order allow,deny
    </Location>
    # Set the default printer/job policies...
    <Policy default>
      # Job-related operations must be done by the owner or an adminstrator...
      <Limit Send-Document Send-URI Hold-Job Release-Job Restart-Job Purge-Jobs Set-Job-Attributes Create-Job-Subscription Renew-Subscription Cancel-Subscription Get-Notifications Reprocess-Job Cancel-Current-Job Suspend-Current-Job Resume-Job CUPS-Move-Job>
        Require user @OWNER
        Order deny,allow
      </Limit>
      # All administration operations require an adminstrator to authenticate...
      <Limit Pause-Printer Resume-Printer Set-Printer-Attributes Enable-Printer Disable-Printer Pause-Printer-After-Current-Job Hold-New-Jobs Release-Held-New-Jobs Deactivate-Printer Activate-Printer Restart-Printer Shutdown-Printer Startup-Printer Promote-Job Schedule-Job-After CUPS-Add-Printer CUPS-Delete-Printer CUPS-Add-Class CUPS-Delete-Class CUPS-Accept-Jobs CUPS-Reject-Jobs CUPS-Set-Default>
        AuthType Basic
        Order deny,allow
      </Limit>
      # Only the owner or an administrator can cancel or authenticate a job...
      <Limit Cancel-Job CUPS-Authenticate-Job>
        Require user @OWNER @SYSTEM
        Order deny,allow
      </Limit>
      <Limit All>
        Order deny,allow
      </Limit>
    </Policy>
    # Include files in /etc/cups/conf.d
    Include /etc/cups/cups.d/ports.conf
    Include /etc/cups/cups.d/browse.conf
    Saudações amigo,
    Geralmente o usuário é root (sem R maiúsculo) e a senha é a sua senha de root.
    Foi exatamente isso que vc tentou?
    dbecher
    Aham. Foi.
