  1. Ola
    A empresa em que trabalho tem um servidor rodando o mandriva 2006. Acontece que quando coloquei politicas de acesso a site dentro do squid e tentei iniciar o mesmo usando o comando:
    service squid restart [FALHOU]
    Então tentei usar:
    /etc/rc.d/init.d/squid start [FALHOU]
    O que fazer para que o squid volte a funcionar? ja pesquisei algum problema igual ao meu mas não econtrei nada.
    Abaixo segue o arquivo squid.conf:
    http_port 3128
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    cache_dir diskd /var/spool/squid 100 16 256
    cache_store_log none
    auth_param basic children 5
    auth_param basic realm Squid proxy-caching web server
    auth_param basic credentialsttl 2 hours
    refresh_pattern . 0 20% 4320
    half_closed_clients off
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    acl sitetaua url_regex -i Prefeitura Municipal de Tauá
    no_cache deny sitetaua
    http_access deny manager
    http_access deny !Safe_ports
    http_access deny to_localhost
    acl mynetwork src 192.168.0.0/255.255.255.0
    http_access allow mynetwork
    http_access allow localhost
    http_reply_access allow all
    icp_access allow all
    visible_hostname myfirewall@mydomain.com
    httpd_accel_host virtual
    httpd_accel_with_proxy on
    append_domain .cidadedigital.com.br
    err_html_text admin@mydomain.com
    deny_info ERR_CUSTOM_ACCESS_DENIED all
    memory_pools off
    coredump_dir /var/spool/squid
    ie_refresh on
    Agradecido
  2. verifica no /var/log/squid/cache.log
    o que o squid esta acusando de errado !!
  3. esses são os erros:
    2006/11/21 00:48:27| Preparing for shutdown after 8577 requests
    2006/11/21 00:48:27| Waiting 30 seconds for active connections to finish
    2006/11/21 00:48:27| FD 11 Closing HTTP connection
    2006/11/21 00:48:27| Shutting down...
    2006/11/21 00:48:27| FD 13 Closing ICP connection
    2006/11/21 00:48:27| FD 14 Closing HTCP socket
    2006/11/21 00:48:27| FD 15 Closing SNMP socket
    2006/11/21 00:48:27| Closing unlinkd pipe on FD 10
    2006/11/21 00:48:27| storeDirWriteCleanLogs: Starting...
    2006/11/21 00:48:27| Finished. Wrote 28899 entries.
    2006/11/21 00:48:27| Took 0.0 seconds (1913080.9 entries/sec).
    CPU Usage: 13.459 seconds = 6.401 user + 7.058 sys
    Maximum Resident Size: 0 KB
    Page faults with physical i/o: 2
    Memory usage for squid via mallinfo():
    total space in arena: 15068 KB
    Ordinary blocks: 14901 KB 232 blks
    Small blocks: 0 KB 9 blks
    Holding blocks: 208 KB 1 blks
    Free Small blocks: 0 KB
    Free Ordinary blocks: 166 KB
    Total in use: 15109 KB 100%
    Total free: 166 KB 1%
    2006/11/21 00:48:27| Open FD 12 squid -> diskd
    2006/11/21 00:48:27| Squid Cache (Version 2.5.STABLE10): Exiting normally.
    2006/11/21 07:11:47| Starting Squid Cache version 2.5.STABLE10 for i586-mandriva-linux-gnu...
    2006/11/21 07:11:47| Process ID 5817
    2006/11/21 07:11:47| With 1024 file descriptors available
    2006/11/21 07:11:47| DNS Socket created at 0.0.0.0, port 32771, FD 5
    2006/11/21 07:11:47| Adding nameserver 172.30.0.1 from /etc/resolv.conf
    2006/11/21 07:11:47| User-Agent logging is disabled.
    2006/11/21 07:11:47| Referer logging is disabled.
    2006/11/21 07:11:47| Unlinkd pipe opened on FD 10
    2006/11/21 07:11:47| Swap maxSize 307200 KB, estimated 23630 objects
    2006/11/21 07:11:47| Target number of buckets: 1181
    2006/11/21 07:11:47| Using 8192 Store buckets
    2006/11/21 07:11:47| Max Mem size: 8192 KB
    2006/11/21 07:11:47| Max Swap size: 307200 KB
    2006/11/21 07:11:47| Store logging disabled
    2006/11/21 07:11:47| Rebuilding storage in /var/spool/squid (CLEAN)
    2006/11/21 07:11:47| Using Least Load store dir selection
    2006/11/21 07:11:47| Set Current Directory to /var/spool/squid
    2006/11/21 07:11:47| Loaded Icons.
    2006/11/21 07:11:48| Accepting HTTP connections at 0.0.0.0, port 3128, FD 11.
    2006/11/21 07:11:48| Accepting ICP messages at 0.0.0.0, port 3130, FD 13.
    2006/11/21 07:11:48| Accepting HTCP messages on port 4827, FD 14.
    2006/11/21 07:11:48| Accepting SNMP messages on port 3401, FD 15.
    2006/11/21 07:11:48| WCCP Disabled.
    2006/11/21 07:11:48| Ready to serve requests.
    2006/11/21 07:11:50| Store rebuilding is 14.2% complete
    2006/11/21 07:11:57| Done reading /var/spool/squid swaplog (28899 entries)
    2006/11/21 07:11:57| Finished rebuilding storage from disk.
    2006/11/21 07:11:57| 28899 Entries scanned
    2006/11/21 07:11:57| 0 Invalid entries.
    2006/11/21 07:11:57| 0 With invalid flags.
    2006/11/21 07:11:57| 28899 Objects loaded.
    2006/11/21 07:11:57| 0 Objects expired.
    2006/11/21 07:11:57| 0 Objects cancelled.
    2006/11/21 07:11:57| 0 Duplicate URLs purged.
    2006/11/21 07:11:57| 0 Swapfile clashes avoided.
    2006/11/21 07:11:57| Took 10.0 seconds (2877.7 objects/sec).
    2006/11/21 07:11:57| Beginning Validation Procedure
    2006/11/21 07:11:57| Completed Validation Procedure
    2006/11/21 07:11:57| Validated 28899 Entries
    2006/11/21 07:11:57| store_swap_size = 276476k
    2006/11/21 07:11:57| storeLateRelease: released 0 objects
    2006/11/21 08:03:01| WARNING: failed to unpack meta data
    2006/11/21 08:05:01| WARNING: failed to unpack meta data
    2006/11/21 08:08:43| WARNING: failed to unpack meta data
    2006/11/21 08:46:43| WARNING: failed to unpack meta data
    2006/11/21 08:46:46| WARNING: failed to unpack meta data
    2006/11/21 08:46:47| WARNING: failed to unpack meta data
    2006/11/21 08:46:49| WARNING: failed to unpack meta data
    2006/11/21 08:46:52| WARNING: failed to unpack meta data
    2006/11/21 08:49:54| httpReadReply: Excess data from "GET http://shopping.busca.uol.com.br/favicon.ico"
    2006/11/21 08:49:58| httpReadReply: Excess data from "GET http://shopping.busca.uol.com.br/favicon.ico"
    2006/11/21 08:50:16| httpReadReply: Excess data from "GET http://shopping.busca.uol.com.br/favicon.ico"
    2006/11/21 08:50:18| httpReadReply: Excess data from "GET http://shopping.busca.uol.com.br/favicon.ico"
    2006/11/21 08:50:21| httpReadReply: Excess data from "GET http://shopping.busca.uol.com.br/favicon.ico"
    2006/11/21 08:50:44| httpReadReply: Excess data from "GET http://shopping.busca.uol.com.br/favicon.ico"
    2006/11/21 08:51:26| httpReadReply: Excess data from "GET http://shopping.busca.uol.com.br/favicon.ico"
    2006/11/21 10:06:39| httpReadReply: Excess data from "GET http://www.cbox.ws/box/jsv4_1.php?r=1"
    2006/11/21 10:07:39| httpReadReply: Excess data from "GET http://www.cbox.ws/box/jsv4_1.php?r=1"
    2006/11/21 10:18:40| WARNING: failed to unpack meta data
    2006/11/21 10:37:56| httpReadReply: Excess data from "POST http://www.crackdb.org/x.php"
    2006/11/21 19:23:40| httpReadReply: Excess data from "GET http://c.goclick.com/r?X=uEvgptEUnt2SjEFeptASmTATjENxsuq9mT2XjFeRpteRnDqRnd2Wota6nTIYmda6ot2RmCzfwfq9mcztsuq9mtuGue9tptaGuVa9mwiSytnCytrEnwfLjFvdptaOmtu"
    2006/11/21 19:28:46| httpReadReply: Excess data from "GET http://c.goclick.com/r?X=uEvgptEUnt2SjEFeptASmTATjENxsuq9mT2XjFeRpteRnDqRnd2Zode6mtm6odiToD2XnCzfwfq9mcztsuq9mtuGue9tptaGuVa9mwiSytnCytrEnwfLjFvdptaOmtu"
    2006/11/21 20:27:46| httpReadReply: Excess data from "GET http://prima.certifica.com/cert/hit.dll?sitio_id=200062&path=Proprio/Homepages/usuarios/fabriciofa.ubbihp.com.br&referer=http%3A//www.aonde.com/clique/clique.php%3Farquivo%3Dsexo/50066.htm%26id_site%3D44457%26url%3Dhttp%3A//www.fabriciofa.ubbihp.com.br&size=1024&colors=24&java=false&descr=Paginas%20de%20usuarios"
    2006/11/21 21:11:13| parseHttpRequest: Unsupported method 'recipientid=99&sessionid=5189
    2006/11/21 21:11:13| clientReadRequest: FD 48 Invalid Request
    2006/11/21 21:11:13| clientReadRequest: FD 54 Invalid Request
    2006/11/21 21:56:46| httpReadReply: Excess data from "GET http://www.br.inter.net/bannermanager/adimage.php?filename=fidelidade.gif&contenttype=gif"
    2006/11/21 21:57:42| httpReadReply: Excess data from "GET http://www.br.inter.net/bannermanager/adimage.php?filename=fidelidade.gif&contenttype=gif"
    2006/11/21 21:58:40| httpReadReply: Excess data from "GET http://www.br.inter.net/bannermanager/adimage.php?filename=fidelidade.gif&contenttype=gif"
    2006/11/21 21:59:54| httpReadReply: Excess data from "GET http://www.br.inter.net/bannermanager/adimage.php?filename=fidelidade.gif&contenttype=gif"
    2006/11/21 22:01:15| httpReadReply: Excess data from "GET http://www.br.inter.net/bannermanager/adimage.php?filename=fidelidade.gif&contenttype=gif"
    2006/11/22 00:43:55| Preparing for shutdown after 124024 requests
    2006/11/22 00:43:55| Waiting 30 seconds for active connections to finish
    2006/11/22 00:43:55| FD 11 Closing HTTP connection
  4. Geralmente isso acontece quando o cache está zoado. Tente zerá-lo deletando as pastas de dentro de /var/spool/squid (Pode estar em outra localização) e recriando o cache com squid -z.
    Outra: evite utilizar o tipo aufs de cache, optando ou por diskd ou por ufs.
    Abraços!
    Última edição por xstefanox; 22-11-2006 às 12:50.
  5. B0a n0ite car0 Xstafan0x. Iss0 ac0nteceu c0mig0 na semana passada.
    Tive que entrar na pasta d0 cache e deletar tud0. Recriei c0m squid -z e v0lt0u tud0 a0 n0rmal.
    Valeus ................
  1. Squid não inicia
    Último Post: 10-10-2004, 17:14
  2. Compilação Squid - Não inicia !!!
    Por Beto no fórum Servidores de Rede
    Respostas: 6
    Último Post: 01-06-2004, 20:35
  3. Squid não inicia
    Por guardian_metal no fórum Servidores de Rede
    Respostas: 17
    Último Post: 29-09-2003, 16:11
  4. Squid não inicia
    Último Post: 11-06-2003, 14:02
  5. Squid não inicia
    Último Post: 11-06-2003, 12:27
