  1. Bom dia galera, gostaria de saber quem usa htb, aki com pppoe-server, pois estou montando um pppoe-server, e gostaria de colocar HTB, para controlar a banda dos usuarios, segue meu script abaixo, gostaria de pedir ajuda aos colegas, e opniões pois ele até controla só que as vezes da um pico de 2 a 20 kbps a + da banda fixada
    Obs:testes efetuado na rede LAN, com um micro fazendo nat e um notebook recebendo o ip 10.0.0.2
    REDE=192.168.0.0/24 (ETH0)
    IP=192.168.0.2
    ETH1=10.0.0.0/8
    IP=10.0.0.1/8
    Tipo de conexão cabo crossover.
    ################SCRIPT PARA TESTE DO HTB
    #!/bin/sh
    IPTABLES="/usr/local/sbin/iptables"
    TC="/sbin/tc"
    IFC="/sbin/ifup"
    U32="filter add dev eth0 protocol ip parent 1:0 prio 1 u32"
    ###Deleta regras existentes
    $TC qdisc del dev eth0 root
    $TC qdisc del dev eth1 root
    ##Adciona controle root padrão
    $TC qdisc add dev eth0 root handle 1: htb default 10
    $TC class add dev eth0 parent 1: classid 1:1 htb rate 458kbit ceil 512kbit burst 2k quantum 1536
    #$TC class add dev eth0 parent 1:1 classid 1:10 htb rate 512kbit ceil 512kbit prio 4
    $TC class add dev eth0 parent 1:1 classid 1:10 htb rate 458kbit ceil 512kbit burst 2k quantum 1536
    $TC qdisc add dev eth0 parent 1:10 handle 10: sfq perturb 5
    #$TC filter add dev eth0 parent 1:0 protocol ip prio 4 handle 10 fw classid 1:10
    iptables -t mangle -F
    iptables -F FORWARD
    #addrules() {
    #/ permite no firewall
    $IPTABLES -A FORWARD -s 10.0.0.2 -j ACCEPT
    $IPTABLES -A FORWARD -d 10.0.0.2 -j ACCEPT
    # para upload
    $TC class add dev eth0 parent 1:1 classid 1:12 htb rate 64kbit ceil 85kbit burst 2k prio 6 quantum 1536
    #$TC class add dev eth0 parent 1:12 classid 1:13 htb rate 6kbit ceil 8kbit burst 2k prio 1 quantum 1500
    $TC ${U32} match ip src 10.0.0.2/32 flowid 1:12
    $TC qdisc add dev eth0 parent 1:12 handle 12: pfifo limit 5
    #$TC filter add dev eth0 parent 1:0 protocol ip prio 4 handle 12 fw classid 1:12
    $IPTABLES -t mangle -A FORWARD -s 10.0.0.2 -j MARK --set-mark 12
    #$IPTABLES -t mangle -A PREROUTING -p tcp --dport 80 -s 10.0.0.2 -j TOS --set-tos 0x10
    #$IPTABLES -t mangle -A POSTROUTING -p icmp -s 10.0.0.2 -j TOS --set-tos 0x08
    # para download
    #$IFC eth1
    $TC qdisc add dev eth1 root handle 1: htb default 10
    $TC class add dev eth1 parent 1: classid 1:1 htb rate 100kbit burst 2k quantum 1536
    $TC class add dev eth1 parent 1:1 classid 1:10 htb rate 20kbit ceil 100kbit burst 2k prio 6 quantum 1536
    $TC qdisc add dev eth1 parent 1:10 handle 10: pfifo limit 5
    #$TC class add dev eth1 parent 1:1 classid 1:10 htb rate 85kbit ceil 100kbit burst 2k prio 1 quantum 1536
    $TC ${U32} match ip dst 10.0.0.2/32 flowid 1:10
    #$TC qdisc add dev eth1 parent 1:1 handle 10: tbf rate 25kbit burst 2kb latency 70ms peakrate 101kbit minburst 1540
    #$TC qdisc add dev eth1 parent 1:10 handle 10: sfq perturb 5
    $IPTABLES -t mangle -A POSTROUTING -d 10.0.0.2 -j MARK --set-mark 10
    $IPTABLES -t mangle -A FORWARD -d 10.0.0.2 -j MARK --set-mark 10
    $IPTABLES -t mangle -A PREROUTING -d 10.0.0.2 -j MARK --set-mark 10
    #$IPTABLES -t mangle -A POSTROUTING -p tcp --sport 80 -d 10.0.0.2 -j TOS --set-tos 0x10
    #$IPTABLES -t mangle -A POSTROUTING -p icmp -d 10.0.0.2 -j TOS --set-tos 0x08
  2. E aee!!
    Kra hoje eu estava navegando pelo site do underlinux e achei esse artigo!
    Acho que pode te ajudar bastante!
    https://under-linux.org/5758-pppoe-r...bandlimit.html
    Falows!!
  3. Pois é kra ae ele mostra como instalar um pppoe-serve, este já até tenho, o meu negocio é com as regras HTB, mesmo.
  4. Então manow... se tu olhar bem ali ele tem os scripts ip-up e ip-down que você pode dar uma olhada! Eles estão usando CBQ mas ajuda!
    Falows!!
  5. Brother eu ja fiz um script para controlar as conexoes ppp
    é bom resalvar que vc vai ter que controloar o trafego das ppp+
    faça a marcacao dos pacotes nas interfaces ppp+ e amarre aos endereços
    ips
    o rc.bandlimit nao vai te ajudar, faça seu script na mão.
    o meu funcionou perfeitamente.
    abraços...
  1. PPPoE Server [Movido para sub-forum Mikrotik]
    Por gnsoares no fórum Redes
    Último Post: 01-04-2014, 11:44
  2. Respostas: 11
    Último Post: 17-02-2011, 11:30
  3. Respostas: 64
    Último Post: 16-05-2008, 03:17
  4. Respostas: 1
    Último Post: 08-04-2008, 12:20
  5. Preciso de ajuda para acrescentar o pppoe-server ao BrazilFW
    Por cussuol no fórum Servidores de Rede
    Último Post: 02-05-2007, 16:06
