    gianrubio
    Padrão Natd + Proxy transparente
    Srs:
    Estou começando a usar iptables..nao tenho mto conhecimento..conheco bastante de pf e ipfw..
    A situacao e a seguinte..Algumas maquinas devem navegar pela nat e o resto pelo proxy transparente..
    As maquinas que devem usar nat sao as que estao dentro da regra # Trafego Local
    Segue meu rc.firewall
    Código :
    #!/bin/sh
    modprobe ip_conntrack
    modprobe ip_conntrack_ftp
    # Configuração Básica
    IPTABLES=`which iptables`
    PERMITIR_TCP="21 20 22 80"
    #1024:65535"
    PERMITIR_UDP="53 5100"
    INET_INT="eth0"
    LAN_INT="eth1"
    INTERNAL_LAN="192.168.0.0/24"
    MASQ_LAN="192.168.0.0/24"
    # DROP: com log colocar "LDROP"
    DROP="TREJECT"
    #DROP="LDROP"
    # Tcp Forward: Pserv:Pestacao>Ip
    TCPFORWARD="8888:8888>192.168.0.203"
    #UDPFORWARD="4672:4672>192.168.0.254 6346:6346>192.168.0.254 6666:6666>192.168.0.254"
    # Criando as Regras
    REGRAS="ENTRADANET SAIDANET TCPPERMITIDO LDROP TREJECT"
    # Habilitando o Masquerade
    # Habilitando TCP Syncookies
    if [ -e /proc/sys/net/ipv4/tcp_syncookies ] ; then
    	echo 1 > /proc/sys/net/ipv4/tcp_syncookies
    fi
    # Limpando as Regras Antigas
    ${IPTABLES} -t filter -F INPUT
    ${IPTABLES} -t filter -F OUTPUT
    ${IPTABLES} -t filter -F FORWARD
    ${IPTABLES} -t nat -F PREROUTING
    ${IPTABLES} -t nat -F OUTPUT
    ${IPTABLES} -t nat -F POSTROUTING
    ${IPTABLES} -t mangle -F PREROUTING
    ${IPTABLES} -t mangle -F OUTPUT
    for chain in ${REGRAS} ; do
    ${IPTABLES} -t filter -F ${chain} > /dev/null 2>&1
    ${IPTABLES} -t filter -X ${chain} > /dev/null 2>&1
    ${IPTABLES} -t filter -N ${chain}
    done
    ${IPTABLES} -t filter -P INPUT ACCEPT
    ${IPTABLES} -t filter -P OUTPUT ACCEPT
    ${IPTABLES} -t filter -P FORWARD DROP
    # Trafego Local
    for subnet in ${INTERNAL_LAN} ; do
    #${IPTABLES} -t filter -A FORWARD -s ${subnet} -j ACCEPT
    ${IPTABLES} -t filter -A FORWARD -s 192.168.0.50 -j ACCEPT
    ${IPTABLES} -t filter -A FORWARD -s 192.168.0.51 -j ACCEPT
    ${IPTABLES} -t filter -A FORWARD -s 192.168.0.52 -j ACCEPT
    ${IPTABLES} -t filter -A FORWARD -d ${subnet} -m state --state ESTABLISHED,RELATED -j ACCEPT
    ${IPTABLES} -t nat -A POSTROUTING -o eth0 -j MASQUERADE
    done
    #PROXY TRANSPARENTE
    #${IPTABLES} -t nat -A PREROUTING -s ${subnet} -p  tcp  --dport 80 -j REDIRECT --to-port 3128
    # Terminado configuraçao de regras
    ${IPTABLES} -t filter -A INPUT -i ${INET_INT} -j ENTRADANET
    ${IPTABLES} -t filter -A OUTPUT -o ${INET_INT} -j SAIDANET
    ${IPTABLES} -t filter -A LDROP -p tcp -m limit --limit 2/s -j LOG --log-level info --log-prefix "TCP Dropped "
    ${IPTABLES} -t filter -A LDROP -p udp -m limit --limit 2/s -j LOG --log-level info --log-prefix "UDP Dropped "
    ${IPTABLES} -t filter -A LDROP -p icmp -m limit --limit 2/s -j LOG --log-level info --log-prefix "ICMP Dropped "
    ${IPTABLES} -t filter -A LDROP -f -m limit --limit 2/s -j LOG --log-level warning --log-prefix "FRAGMENT Dropped "
    ${IPTABLES} -t filter -A LDROP -j DROP
    ${IPTABLES} -t filter -A TREJECT -p tcp -j REJECT --reject-with tcp-reset
    ${IPTABLES} -t filter -A TREJECT -p ! tcp -j REJECT --reject-with icmp-port-unreachable
    ${IPTABLES} -t filter -A TREJECT -j REJECT
    # Protegendo contra TCP SYN Flood
    ${IPTABLES} -t filter -A TCPPERMITIDO -p tcp --syn -m limit --limit 4/s -j ACCEPT
    ${IPTABLES} -t filter -A TCPPERMITIDO -p tcp ! --syn -j ACCEPT
    ${IPTABLES} -t filter -A TCPPERMITIDO -m limit --limit 2/s -j LOG --log-prefix "Mismatch in TCP"
    ${IPTABLES} -t filter -A TCPPERMITIDO -j ${DROP}
    # Pacotes com flag invalidas
    ${IPTABLES} -t filter -A ENTRADANET -m state --state INVALID -j ${DROP}
    # Descartando Ping flood
    ${IPTABLES} -t filter -A ENTRADANET -p icmp --icmp-type echo-request -m limit --limit 1/s -j ACCEPT
    ${IPTABLES} -t filter -A ENTRADANET -p icmp --icmp-type ! echo-request -j ACCEPT
    # Portas TCP a serem abertas
    if [ "$PERMITIR_TCP" != "" ] ; then
    	for port in ${PERMITIR_TCP} ; do
    	${IPTABLES} -t filter -A ENTRADANET -p tcp --dport ${port} -j TCPPERMITIDO
    	done
    fi
    #Teste com UDP ports
    if [ "$PERMITIR_UDP" != "" ] ; then
    	for port in ${PERMITIR_UDP} ; do
    	${IPTABLES} -t filter -A ENTRADANET -p udp --dport ${port} -j ACCEPT
    	done
    fi
    # Pacotes com flags validas
    ${IPTABLES} -t filter -A ENTRADANET -m state --state ESTABLISHED -j ACCEPT
    # TOS ]]
    ${IPTABLES} -t mangle -A OUTPUT -p tcp --dport 23 -j TOS --set-tos 0x10
    ${IPTABLES} -t mangle -A OUTPUT -p tcp --dport 22 -j TOS --set-tos 0x10
    ${IPTABLES} -t mangle -A OUTPUT -p tcp --dport 21 -j TOS --set-tos 0x10
    ${IPTABLES} -t mangle -A OUTPUT -p tcp --dport 20 -j TOS --set-tos 0x02
    #PASSIVE FTP
    ${IPTABLES} -A ENTRADANET -p tcp --sport 1024:65535 --dport 21 -m state --state NEW,ESTABLISHED -j ACCEPT
    ${IPTABLES} -A ENTRADANET -p tcp --sport 21 --dport 1024:65535 -m state --state NEW,ESTABLISHED -j ACCEPT
    ${IPTABLES} -A ENTRADANET -p tcp --sport 1024:65535 --dport 1024:65535 -m state --state RELATED,ESTABLISHED -j ACCEPT
    # Regras padrao
    ${IPTABLES} -t filter -A ENTRADANET -j ${DROP}
    ${IPTABLES} -t filter -A SAIDANET -j ACCEPT
    modprobe ip_nat_ftp
    Script meio doido, hehehe.
    Bem... o quê eu faria no caso é o seguinte: Criaria um array com IP's que não deveriam passar pelo proxy transparente e jogaria-os numa regra de MASQUERADE e depois criaria a regra de REDIRECT, algo como isso:
    Código :
    for IP in `cat IPS.txt`; do
       iptables -t nat -A POSTROUTING -o $INTERFACE_SAIDA -s "$IP" -j MASQUERADE
    done;
    iptables -t nat -A PREROUTING -i $INT_REDE_EXT -p TCP --dport 80 -j REDIRECT --to-port 3128
    iptables -t nat -A PREROUTING -i $INT_REDE_INT -p UDP --dport 80 -j REDIRECT --to-port 3128
    A partir do momento que o iptables casa uma regra, ele pula as outras, ele ignorará as regras de proxy transparente.
    Abraços!
    gianrubio
    vou testar amanha e respondo..
    obrigado por enquanto
    gianrubio
    Nao funcionou..ou funciona so a nat ou so o proxy
    as regras
    Código :
    # Trafego Local
    for IP in `cat /root/ips` ; do
            ${IPTABLES} -t filter -A FORWARD -s $IP -j ACCEPT
            ${IPTABLES} -t nat -A POSTROUTING -o $INET_INT -s $IP -j MASQUERADE
            ${IPTABLES} -t filter -A FORWARD -d $IP -m state --state ESTABLISHED,RELATED -j ACCEPT
    done
    #PROXY TRANSPARENTE
    ${IPTABLES} -t nat -A PREROUTING -i $INET_INT -p TCP --dport 80 -j REDIRECT --to-port 3128
    ${IPTABLES} -t nat -A PREROUTING -i $INET_INT -p UDP --dport 80 -j REDIRECT --to-port 3128
    gianrubio
    resolvido
    Código :
            ${IPTABLES} -t nat -A PREROUTING -p tcp --dport 80 -d 0/0 -s $IP -j ACCEPT
    done
    #PROXY TRANSPARENTE
    ${IPTABLES} -t nat -A PREROUTING -i $LAN_INT -p TCP --dport 80 -j REDIRECT --to-port 3128
    ${IPTABLES} -t nat -A PREROUTING -i $LAN_INT -p UDP --dport 80 -j REDIRECT --to-port 3128
