  1. Pessoal, alguém teve esse problema ao rodar o amsn ?
    instalei o pacote.tgz dele e ao rodar o amsn da o erro abaixo.
    # amsn
    Application initialization failed: no display name and no $DISPLAY environment variable
    Error in startup script: no display name and no $DISPLAY environment variable
    while executing
    "load /usr/lib/tk8.4/../libtk8.4.so Tk"
    ("package ifneeded" script)
    invoked from within
    "package require Tk"
    (file "/usr/bin/amsn" line 46)
  2. Você tem que instalar o " tk ".
    Falow ...
  3. installpkg tk-8.4.13-i486-1.tgz
    Installing package tk-8.4.13-i486-1...
    PACKAGE DESCRIPTION:
    tk: tk (Tk toolkit for Tcl)
    tk:
    tk: Tk is an extension to Tcl that allows you to quickly and easily build
    tk: X11 applications that have the look and feel of Motif apps.
    tk:
    Executing install script for tk-8.4.13-i486-1...
    root@darkstar:/home/rodrigo# installpkg tcl-8.4.13-i486-2.tgz
    Installing package tcl-8.4.13-i486-2...
    tcl: tcl (Tool Command Language)
    tcl:
    tcl: Tcl, developed by Dr. John Ousterhout, is a simple to use text-based
    tcl: script language with many built-in features which make it especially
    tcl: nice for writing interactive scripts.
    tcl:
    Executing install script for tcl-8.4.13-i486-2...
    root@darkstar:/home/rodrigo# amsn
    while executing
    invoked from within
    (file "/usr/sbin/amsn" line 46)
  4. bom.. estou a algum tempo sem usar o slack! mas não seria o caso de atualizar as bibliotecas com o ldconfig?
    se eu estiver errado alguém me corriga!
  5. vá no seu terminal e set a variavel $DISPLAY com o seguinte valor :0.0 que o problema estará resolvido
    Feliz 2007 !!!
  1. Seu AMSN não funciona?
    Por Mero_Aprendiz no fórum Servidores de Rede
    Último Post: 20-10-2003, 10:44
  2. Seu AMSN não funciona?
    Último Post: 18-10-2003, 13:35
  3. Mkpasswd não funciona
    Último Post: 28-11-2002, 10:53
  4. Respostas: 3
    Último Post: 25-11-2002, 18:22
  5. Função Mail() não funciona
    Último Post: 26-09-2002, 16:55
