  1. Uso debian 3.1r2, atualiza com upgrade todos os dias... bem é o seguinte minhas politicas de firewall é DROP, e tenho um script que faz o seguinte:
    # Libera acesso pelas demais portas.
    if [ $TRANS = "sim" ] && [ -x $NOPROXY ] && [ -x $NOARP ]; then
    $IPTABLES -A INPUT -p UDP -s $IP -m mac --mac-source $MAC -j udpin_packets
    $IPTABLES -A INPUT -p ICMP -s $IP -m mac --mac-source $MAC -j icmp_packets
    $IPTABLES -A INPUT -p TCP -s $IP -m mac --mac-source $MAC -m ttl --ttl 32 -j tcp_packets_in
    $IPTABLES -A INPUT -p TCP -s $IP -m mac --mac-source $MAC -m ttl --ttl 64 -j tcp_packets_in
    $IPTABLES -A INPUT -p TCP -s $IP -m mac --mac-source $MAC -m ttl --ttl 128 -j tcp_packets_in
    $IPTABLES -A INPUT -p TCP -s $IP -m mac --mac-source $MAC -m ttl --ttl 255 -j tcp_packets_in
    $IPTABLES -A FORWARD -p UDP -s $IP -m mac --mac-source $MAC -m limit --limit $BAND_UP/second -j ACCEPT
    $IPTABLES -A FORWARD -p ICMP -s $IP -m mac --mac-source $MAC -m limit --limit $BAND_UP/second -j icmp_packets
    $IPTABLES -A FORWARD -p TCP -s $IP -m mac --mac-source $MAC -m limit --limit $BAND_UP/second -m ttl --ttl 31 -j allowed
    $IPTABLES -A FORWARD -p TCP -s $IP -m mac --mac-source $MAC -m limit --limit $BAND_UP/second -m ttl --ttl 63 -j allowed
    $IPTABLES -A FORWARD -p TCP -s $IP -m mac --mac-source $MAC -m limit --limit $BAND_UP/second -m ttl --ttl 127 -j allowed
    $IPTABLES -A FORWARD -p TCP -s $IP -m mac --mac-source $MAC -m limit --limit $BAND_UP/second -m ttl --ttl 254 -j allowed
    printf " \033[40;32m [OK] \033[m\n"
    elif [ $TRANS = "sim" ] && [ -x $NOPROXY ] && [ ! -x $NOARP ]; then
    $IPTABLES -A INPUT -p UDP -s $IP -j udpin_packets
    $IPTABLES -A INPUT -p ICMP -s $IP -j icmp_packets
    $IPTABLES -A INPUT -p TCP -s $IP -m ttl --ttl 32 -j tcp_packets_in
    $IPTABLES -A INPUT -p TCP -s $IP -m ttl --ttl 64 -j tcp_packets_in
    $IPTABLES -A INPUT -p TCP -s $IP -m ttl --ttl 128 -j tcp_packets_in
    $IPTABLES -A INPUT -p TCP -s $IP -m ttl --ttl 255 -j tcp_packets_in
    $IPTABLES -A FORWARD -p UDP -s $IP -m limit --limit $BAND_UP/second -j ACCEPT
    $IPTABLES -A FORWARD -p ICMP -s $IP -m limit --limit $BAND_UP/second -j icmp_packets
    $IPTABLES -A FORWARD -p TCP -s $IP -m limit --limit $BAND_UP/second -m ttl --ttl 31 -j allowed
    $IPTABLES -A FORWARD -p TCP -s $IP -m limit --limit $BAND_UP/second -m ttl --ttl 63 -j allowed
    $IPTABLES -A FORWARD -p TCP -s $IP -m limit --limit $BAND_UP/second -m ttl --ttl 127 -j allowed
    $IPTABLES -A FORWARD -p TCP -s $IP -m limit --limit $BAND_UP/second -m ttl --ttl 254 -j allowed
    elif [ $TRANS = "sim" ] && [ ! -x $NOPROXY ]; then
    #$IPTABLES -A PREROUTING -t nat -i eth0 -p TCP -m multiport --dport 3128,80 -j DNAT --to 192.168.30.1:8082
    #$IPTABLES -A PREROUTING -t nat -m mac --mac-souce $MAC -p TCP -m multiport --dport 3128,80 -j DNAT --to 192.168.30.1:8082
    $IPTABLES -A INPUT -p TCP -m mac --mac-source $MAC -j tcp_packets_in
    $IPTABLES -A INPUT -p UDP -m mac --mac-source $MAC -j udpin_packets
    $IPTABLES -A INPUT -p ICMP -m mac --mac-source $MAC -j icmp_packets
    $IPTABLES -A FORWARD -p ICMP -m mac --mac-source $MAC -j icmp_packets
    $IPTABLES -A FORWARD -p TCP -m mac --mac-source $MAC -j allowed
    $IPTABLES -A FORWARD -p UDP -m mac --mac-source $MAC -j ACCEPT
    else
    echo " *** total acesso NEGADO !!! ***"
    fi
    mas se eu trocar o ip e o mac ja estiver liberado navega normal, posso usar qualquer ip que navego dentro da minha rede claro...
    Tenho que carregar quais módulos pra que isso funcione 100%??
    Desde ja agradeço....
  2. Kra eu faço assim:
    #Aceita requisicoes vindas da eth0 desde que tenham o IP e MAC OK
    iptables -A FORWARD -i eth0 -s 172.16.3.1 -m mac --mac-soruce 00:02:3F:CF:25:5B -o eth1 -d 0/0 -j ACCEPT
    #Volta dos pacotes
    iptables -A FORWARD -o eth0 -m state --state STABLISHED,RELATED -j ACCEPT
    #Nega tudo
    iptables -A FORWARD -i eth0 -j DROP
    #Mascara
    iptables -t nat -A POSTROUTING -s 172.16.0.0/16 -o eth1 -j MASQUERADE
    Aki ta funfano legal
  3. quais módulos tenho que ativar pra que isso funcione? assim tambem não funcionou...
  4. ola pessoal nem mais uma idéia??
  5. Kra muito estranho pq aki funciona perfeito, qual o erro q da?
  1. Change IP com problemas?
    Por AndersonFox no fórum Redes
    Último Post: 10-04-2013, 17:37
  2. amarrar ip com mac (ARP) ??
    Por ddllss no fórum Redes
    Respostas: 7
    Último Post: 13-11-2008, 14:29
  3. Migração de ip com mac para ppoe ou hospot
    Por brunophsp no fórum Redes
    Último Post: 05-12-2007, 09:42
  4. Firewall MAC X IP com iptables o que pode ser melhorado
    Por cleciorodrigo no fórum Servidores de Rede
    Último Post: 09-01-2006, 01:04
  5. Duvida com Firewall Mac/Ip
    Por ifc0nfig no fórum Servidores de Rede
    Respostas: 16
    Último Post: 29-08-2005, 20:20
