- Wireless inativo...
Wireless inativo...
Galera eu configurei toda a rede aki...
mas soh q a interface wireless e wds ficam inativas...
tah tudo na msma bridge... as configs da wireless saum as seguintes...
name="Wireless" mtu=1500 mac-address=00:17:9A:AF:E9:C7 arp=enabled
disable-running-check=no interface-type=Atheros AR5213
radio-name="MikroTik" mode=ap-bridge ssid="WireNET" area=""
frequency-mode=superchannel country=brazil antenna-gain=0
frequency=2417 band=2.4ghz-b scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=""
basic-rates-b=1Mbps basic-rates-a/g="" max-station-count=2007
ack-timeout=dynamic tx-power=23 tx-power-mode=card-rates
noise-floor-threshold=127 periodic-calibration=default
periodic-calibration-interval=600 burst-time=disabled dfs-mode=none
antenna-mode=ant-a wds-mode=static wds-default-bridge=Internet
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=pre-2.9.25 hide-ssid=no security-profile=WireNET
disconnect-timeout=6s on-fail-retry-time=100ms preamble-mode=long
compression=yes allow-sharedkey=no
e as do WDS ...
name="wds1" mtu=1500 mac-address=00:17:9A:AF:E9:C7 arp=enabled
disable-running-check=no master-interface=Wireless
wds-address=00:C0:CA:17:A4:66
eu consigo me conectar via modo cliente... mas em modo WDS... essa nao via nem com reza braba...
algumas dicas?!?!
Última edição por nklaveren; 02-02-2007 às 02:58.
