    gsetebrasil
    estou com o pdc rodando porém não parem as impressoras... pq? tenho outro pdc está igualzinho, a unica diferença q esse é no slack 11 e o outro é no slack 10.2, por que não aparece??? se tá igual... existe outro tipo de conf?
    //################################# PDC BY DOUG CIDADE ########################################
    [global]
    time server = yes
    dns proxy = no
    netbios name = GERACAO
    keep alive = 20
    writeable = yes
    printing = bsd
    logon script = %u.bat
    local master = yes
    workgroup = SAMUQUINHA
    os level = 100
    debug level = 3
    announce as = NT Server
    printcap name = /etc/printcap
    security = user
    add machine script = /usr/sbin/useradd -c Machine -d /var/lib/nobody -s /bin/lib/false %m$
    max log size = 50
    log file = /var/log/samba_log.%u
    printer = epson_stylus_photo
    //logon path = \\%N\profilesNT\%u
    load printers = yes
    winpopup command = csh -c 'xedit %s;rm %s' &
    socket options = IPTOS_LOWDELAY TCP_NODELAY
    logon drive = x:
    domain master = yes
    null passwords = no
    encrypt passwords = yes
    logon home = \\%L\profiles\%u
    passdb backend = smbpasswd
    server string = Samba Cidade El Shadai
    path = /var/spool/lpd
    unix password sync = yes
    logon path = \\%L/profiles/%u
    add user script = useradd -g domainmac -c "SAMUQUINHA" -s /bin/false -d /dev/null %u
    preferred master = no
    domain logons = yes
    [security]
    security = USER
    hosts.allow = 127. 192.168.100
    wins server = 192.168.100.1
    wins support = yes
    [homes]
    comment = usuario
    path = /home/%u
    read only = no
    browseable = yes
    public = no
    writeable = yes
    guest ok = yes
    create mask = 0777
    force create mode = 0770
    profile acls = yes
    browseable = yes
    printable = no
    locking = No
    [printers]
    printer =
    printable = yes
    print command = lpr-cups -P %p -o raw %s -r # using client side printer drivers.
    path = /var/spool/samba
    guest ok = Yes
    create mask = 0700
    comment = All Printers
    [print$]
    path = /var/lib/samba/printers
    write list = @adm, root
    inherit permissions = Yes
    guest ok = Yes
    [netlogon]
    profile acls = yes
    locking = No
    printable = no
    writeable = no
    path = /mnt/hd/config/samba/netlogon
    guest ok = yes
    create mask = 0777
    comment = Compartilhamento de Scripts
    public = no
    [profiles]
    comment = profiles
    path = /mnt/hd/config/profiles
    public = no
    writeable = yes
    guest ok = yes
    create mask = 0777
    profile acls = yes
    browseable = yes
    printable = no
    locking = No
    [admin]
    comment = Diretorio do Administrador
    path = /home/root
    writeable = Yes
    valid users = root, douglas
    guest ok = Yes
    read only = No
    public = yes
  2. Aparece alguma coisa nos logs?
    Ab, Duca.
  1. Dúvida sobre Samba PDC com WINDOWS XP
    Por aprendiz_ce no fórum Servidores de Rede
    Respostas: 13
    Último Post: 04-12-2006, 18:09
  2. Samba PDC com estações Windows XP PRO
    Último Post: 14-02-2006, 15:14
  3. Samba PDC com LDAP - Senhas
    Por ztock no fórum Servidores de Rede
    Último Post: 17-06-2005, 16:44
  4. Samba PDC - Windows XP nao encontra controlador de dominio
    Por JVKurumin no fórum Servidores de Rede
    Respostas: 9
    Último Post: 01-06-2005, 10:28
  5. Samba PDC - Internet Explorer não navega?!
    Por virtualboy no fórum Servidores de Rede
    Respostas: 11
    Último Post: 23-12-2004, 15:02
