    Padrão Solucionar bloqueio de site
    Senhores, esse erro de TCP_DENIED/403 não sei porque está bloqueando sendo que é uma aplicação Java que está sendo executada no site.
    Um curso ONLINE.
    1172517544.822 669 10.100.71.131 TCP_MISS/200 214 POST http://151.193.219.39/ll/ll.dll/06348fc0/s? - DIRECT/151.193.219.39 text/plain
    1172517544.822 142604 10.100.71.131 TCP_MISS/200 170915 GET http://151.193.219.39/ll/ll.dll/06348fc0/r? - DIRECT/151.193.219.39 application/octet-stream
    1172517546.306 696 10.100.71.131 TCP_MISS/200 214 GET http://151.193.219.39/ll/ll.dll/06348fc0/Logout - DIRECT/151.193.219.39 text/plain
    1172517653.074 655 10.100.71.131 TCP_MISS/200 1129 GET http://learnlinc.sabre.com/cframe.asp - DIRECT/151.193.219.39 text/html
    1172517655.306 2425 10.100.71.131 TCP_MISS/200 4311 GET http://learnlinc.sabre.com/top.asp - DIRECT/151.193.219.39 text/html
    1172517656.516 3631 10.100.71.131 TCP_MISS/200 582 GET New Page 3 - DIRECT/151.193.219.39 text/html
    1172517662.109 8762 10.100.71.131 TCP_MISS/200 15906 GET http://learnlinc.sabre.com/jslibrary.asp - DIRECT/151.193.219.39 application/x-javascript
    1172517671.451 18564 10.100.71.131 TCP_MISS/200 174744 GET http://learnlinc.sabre.com/chome.asp? - DIRECT/151.193.219.39 text/html
    1172517689.113 586 10.100.71.131 TCP_MISS/200 2402 GET http://learnlinc.sabre.com/cjoin.asp? - DIRECT/151.193.219.39 text/html
    1172517689.923 1050 10.100.71.131 TCP_MISS/200 15906 GET http://learnlinc.sabre.com/jslibrary.asp? - DIRECT/151.193.219.39 application/x-javascript
    1172517707.779 0 10.100.71.131 TCP_DENIED/403 1398 GET http://151.193.219.39/ll/ll.dll/EnumServices - NONE/- text/html
    1172517707.790 0 10.100.71.131 TCP_DENIED/403 1398 GET http://151.193.219.39/ll/ll.dll/EnumServices - NONE/- text/html
    1172517707.796 0 10.100.71.131 TCP_DENIED/403 1398 GET http://151.193.219.39/ll/ll.dll/EnumServices - NONE/- text/html
    Estou procurando o porque de estar bloqueando esse site.
    Citação Postado originalmente por spyderlinux Ver Post
    Um curso ONLINE.
    Cara ... você tá usando regras de bloqueios tipo ...
    acl blockdesites url_regex -i "/etc/squid/bloqueados/block.txt"
    acl blockdesites url_regex -i "/etc/squid/bloqueados/unblock.txt"
    se sim seta esse ip (151.193.219.39) no unblock.txt que deve funcionar, tem alguma frase ou palavra que ele deve estar interpretando como bloqueio ...
    Falow ...
    Criei uma acl para esse site ai e resolvi. De qualquer forma obrigado.
    A dúvida era que colocando o erro no google apresentava algumas informações que o erro era porque poderiam estar fazendo um spam com o proxy mas num era não.
    Liberei o Ip e ja era.
    De qualquer forma, Obrigado
