    Padrão Mikrotik com erro, desligamento incorreto direto !!! SOCORRO!!!
    Galera seguinte:
    Montei um MK para teste aqui na bancada funcionou 100% durane 5 dias. Peguei uma caixa montei dentro
    da caixa tudo que estava fora e com a devida refrigeracao, ainda sim liguei na bancada.
    E derepente para minha surpresa de tempos em tempos ele dá esta mensagem e derruba todo mundo
    depois associa normalmente. E tem Hora que chega até travar, alguem já passou por isto
    16:53:16 system,error,critical router was rebooted without proper shutdown
    16:53:22 wireless,info 00:4F:69:50:84:[email protected] established connection on 5180, SSID bk_reduto
    16:53:32 wireless,info 00:04:23:99:B8:[email protected]: connected
    16:54:08 wireless,info 00:04:23:99:B8:[email protected]: disconnected, got disassoc: unspecified (1)
    Aconteceu novamente apos 38 Horas de funcionamento
    12:59:07 system,error,critical router was rebooted without proper shutdown
    12:59:13 wireless,info 00:4F:69:50:84:[email protected] established connection on 5180, SSID bk_reduto
    12:59:19 wireless,info 00:04:23:99:B8:[email protected]: connected
    12:59:55 wireless,info 00:04:23:99:B8:[email protected]: disconnected, got disassoc: unspecified (1)
    12:59:57 wireless,info 00:04:23:99:B8:[email protected]: connected
    13:01:14 system,error,critical router was rebooted without proper shutdown
    13:01:20 wireless,info 00:4F:69:50:84:[email protected] established connection on 5180, SSID bk_reduto
    13:01:26 wireless,info 00:04:23:99:B8:[email protected]: connected
    13:01:29 wireless,info 00:04:23:99:B8:[email protected]: disconnected, got disassoc: unspecified (1)
    13:01:29 wireless,info 00:04:23:99:B8:[email protected]: connected
    13:01:31 wireless,info 00:04:23:99:B8:[email protected]: disconnected, got disassoc: unspecified (1)
    13:01:32 wireless,info 00:04:23:99:B8:[email protected]: connected
    13:01:34 wireless,info 00:04:23:99:B8:[email protected]: disconnected, got disassoc: unspecified (1)
    13:01:34 wireless,info 00:04:23:99:B8:[email protected]: connected
    13:01:35 wireless,info 00:04:23:99:B8:[email protected]: disconnected, got disassoc: unspecified (1)
    13:01:41 wireless,info 00:04:23:99:B8:[email protected]: connected
    13:06:29 system,error,critical router was rebooted without proper shutdown
    13:06:36 wireless,info 00:4F:69:50:84:[email protected] established connection on 5180, SSID bk_reduto
    13:06:42 wireless,info 00:04:23:99:B8:[email protected]: connected
    O Estranho que ele volta logo em seguida, neste caso ultimo 6 segundos depois.
    Meu Hardware
    Placa Asus OnBoard -
    Celeron D310
    512 MB RAM
    Flash 2 GB - Sistema e 1,5 GB Proxy
    Fonte 450 Watss
    1 Placa wireless AG 530
    1 Placa Wireless Sansumg SWL2400 (ATHEROS)
    Avatar de marcelomg
    Jan 2006
    São Lourenço do Sul, Brazil
    Kra nunca usei cache em um flash disc, isso pode ser o seu Hardware tive um problema parecido com o seu e era a fonte de alimentação da placa mãe.
    Citação Postado originalmente por eduprog Ver Post
    Galera seguinte:
    Meu Hardware
    Celeron D310
    512 MB RAM
    Fonte 450 Watss
    Vou fazer alguns testes, vou trocar a fonte e vou voltar meu flash 128 MB apenas para o sistema mesmo, o estranho que tem hora que dá esta mensagem e apenas 6 segundos depois associa todo mundo, agora quando começa a dar a mensagem varias vezes seguida, somente reiniciando o equipamento para poder voltar a funcionar perfeitamente. Vou tambem tirar o proxy no flash para efetuar um teste.
    Bom pelo que eu sei
    não é bom fazer cache numa Compact-Flash
    pois elas não tem a capacidade "infinita" de serem "reescritas"
    logo um cache num drive desses faz sua vida util ser bastante
    reduzida.
    _____________________________________________________________________________________________
    Compactflash disks can be written on about 100,000 times before they give out, but these cards are also smart enough to distribute/rotate writing on them so as not to "wear out" particular spots.
    ______________________________________________________________________________________________
    Se pretende fazer cache acho que o melhor é usar um hd convencional mesmo
    Última edição por iceboxrj; 05-03-2007 às 13:41.
    Padrão CONTINUO COM ERRO router was rebooted
    Galera,
    continuo com este erro. Nao sei mais o quie fazer. Já troquei tudo.
    Toda Maquina funcionando fora da caixa ok. Montei na caixa no laboratorio funfa legal, poe na torre emite estas mensagens e trava. Dai somente desligando e religar. Fiz teste de aquecimento e nao acredito ser pois coloquei um termometro interno na caixa e nao passa de 38 graus temperatura ambiente, nao sei mais o que fazer. Alguem tem alguma sugestao por favor. ?
    Qualquer ideia é bem vinda.
    Eduardo.
    Galera,
    Eduardo.
    Como o amigo acima falou, troca a fonte... Verifica também se tem algo configurado na BIOS da placa mãe e no WathsDog do Mikrotik... Posta o resultado,....
