    Padrão Hi >> New In mikrotik Please help
    Hi Im new user in mikrotik i hope i found the help
    i setup the mikrotik in my pc :
    1 - lan 192.168.150.1/24 to useres to hotspot
    2-lan 2 192.168.168.1/24 to usere Pppoe
    2- wan 192.192.15.10 from router adsl internet
    every thik work good
    idont have any rule in firwall and nat
    i need to add some rule in firwall and nat
    to protect my mikrotik
    and i dont need any ip out of my range to acess router just this range see in mikrotik
    Thanx for every one and im sory about my lang . english
    Jul 2001
    Campinas Area
    Se você é de fato Português pode fazer a pergunta em português pois este fórum é Brasileiro!
    Citação Postado originalmente por leo297 Ver Post
    YES!!!!
    You are gonna have to include a NAT rule for each class of IP. The firewall rules and configurations can be found in this very same website on our Wiki. Please post back if you have any doubts.
    thank you very mach
    please if u can give me thats rule in firwall
    and i have problem when i ping to access point give me this massge
    Reply from 192.168.230.20 destination net unreachable
    how can i fix this problem
    thank you
    go to terminal and type
    setup > and add ip and gataway dafault
    Go to terminal do a login and type setup
    add ip and gateway defautl on the local inteface
    Exclamation
    Just wondering...
    What would happen if I request some help in a English based forum writing in Portuguese?
    Jul 2001
    Campinas Area
    You would get kicked in the teeth.
    my lan ip 192.168.150.1\24
    my wan ip from router 192.168.15.10
    my getway to internet is 192.168.15.1
    the rang ip access point is 192.168.230.40 - 192.168.230.100
    what ip and gateway defautl to add in setup
    Thank you for every one very much
    Padrão help
    please give me the best firwall to add in router its very slow i have just 10 costomer on line but its very slow ,,,, after i restard the server work agine
    halp me plz i need the best congigrt to roujter
    Question Where are you from??
    Where are you from, Leo297???
    Só pra diretoria:
    Perguntei isso porque acho o inglês desse camarada é muito estranho... o Catvbrasil escreve muito melhor que ele. De onde será essa figura?
    _____________________
    Xenófobo??? Eu???
    Jul 2001
    Campinas Area
    I think he is from Russia.
    kkk
    Jul 2001
    Campinas Area
    Anyway Leo, are you looking for a firewall to use within Mikrotik or you seek a better configuration for the built-in one that is software's default?
    Thanks for evry one
    i need the best configeration to mikrotik if u have backup file send to me please
    all i need the best configer and firwall
    really thank you
    can any one give me the rule firewall and anti spam anti haker and protect the router and nat and managle please
    O manual do Mikrotik NÃO está em português, é só dar uma lidinha. Tá tudo lá.
    Jul 2001
    Campinas Area
    Translating: "Mikrotik's manual is NOT in portuguese, just take a look at it. Everything's there."
    Última edição por Fernando; 03-05-2008 às 01:50.
    Citação Postado originalmente por Del*.* Ver Post
    Só pra diretoria:
    Xenófobo??? Eu???
    kkkkkkkkkkkkkkkkkk.......... Meu inglês ainda é nativo do AltaVista (tradução);;;;;;;;;;;; rssssssssssssssssssssss
