  1. Olá galera, estou precisando configurar 5 portas seriais, eu tenho 1 porta onboard, 2 placas pci netmos
    /dev/ttyS0, UART: 16550A, Port: 0x03f8, IRQ: 4 - onboard
    /dev/ttyS1, UART: 16550A, Port: 0x8000, IRQ: 16 - pci netmos
    /dev/ttyS2, UART: 16550A, Port: 0x8400, IRQ: 16 - pci netmos
    /dev/ttyS3, UART: 16550A, Port: 0x9800, IRQ: 17 - pci netmos
    gerei MAKEDEV /dev/ttyS4
    quando rodo o setserial /dev/ttyS4 port 0x9c00 irq 17 uart 16550A
    ocorre este erro.
    /dev/ttyS4: No such device or address
    Aqui segue as configurações das placas netmos Pci
    0:08.0 Serial controller: NetMos Technology PCI 9835 Multi-I/O Controller (rev 01) (prog-if 02 [16550])
    Subsystem: LSI Logic / Symbios Logic 2S (16C550 UART)
    Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B-
    Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR-
    Interrupt: pin A routed to IRQ 16
    Region 0: I/O ports at ex [size=8]
    Region 1: I/O ports at 8400 [size=8]
    Region 2: I/O ports at 8800 [size=8]
    Region 3: I/O ports at 8c00 [size=8]
    Region 4: I/O ports at 9000 [size=8]
    Region 5: I/O ports at 9400 [size=16]
    00:09.0 Serial controller: NetMos Technology PCI 9835 Multi-I/O Controller (rev 01) (prog-if 02 [16550])
    Interrupt: pin A routed to IRQ 17
    Region 0: I/O ports at 9800 [size=8]
    Region 1: I/O ports at 9c00 [size=8]
    Region 2: I/O ports at a000 [size=8]
    Region 3: I/O ports at a400 [size=8]
    Region 4: I/O ports at a800 [size=8]
    Region 5: I/O ports at ac00 [size=16]
    Se alguem tiver uma luz, agradeço muito.
  2. Galera descobrir o problema, o fedora 5 o kernel vem abilitado para 4 portas seriais, compilei um novo kernel e deu tudo certo.
    Citação Postado originalmente por Jaltemar Ver Post
    ocorre este erro.
  1. setserial
    Último Post: 06-08-2003, 12:37
  2. CL8 - Modem USR 5610 3com 2976 - setserial: address in use
    Por Driwll no fórum Servidores de Rede
    Último Post: 22-01-2003, 09:24
