  1. pessoal eu ja nao alguento mais, ja fiz de tudo no meu servidor de email e o spamcop ainda continua me listado e informa a seguinte coisa:
    Causes of listing
    * System has sent mail to SpamCop spam traps in the past week (spam traps are secret, no reports or evidence are provided by SpamCop)
    * SpamCop users have reported system as a source of spam less than 10 times in the past week
    veja a minha configuracao:
    header_checks = pcre:/etc/postfix/header_checks
    body_checks = pcre:/etc/postfix/body_checks
    mime_header_checks = $header_checks
    nested_header_checks = $header_checks
    strict_rfc821_envelopes = yes
    smtpd_helo_required = yes
    disable_vrfy_command = yes
    header_size_limit=102400
    smtp_destination_concurrency_limit=5
    default_destination_concurrency_limit=5
    local_destination_concurrency_limit = 2
    default_destination_recipient_limit=20
    fast_flush_refresh_time = 12h
    smtpd_recipient_restrictions = reject_sender_login_mismatch,
    permit_sasl_authenticated,
    check_recipient_access pcre:/etc/postfix/sender_proibidos,
    reject_non_fqdn_hostname,
    reject_unauth_pipelining,
    reject_unauth_destination,
    check_recipient_access hash:/etc/postfix/whitelist,
    reject_rbl_client dnsbl.njabl.org,
    reject_rbl_client dynablock.njabl.org,
    reject_rbl_client xbl.spamhaus.org,
    reject_rbl_client cbl.abuseat.org,
    reject_rbl_client dul.dnsbl.sorbs.net,
    reject_rbl_client list.dsbl.org,
    reject_rbl_client rbl.brasilrbl.com.br ,
    reject_rbl_client rhsbl.brasilrbl.com.br,
    reject_rbl_client opm.blitzed.org,
    reject_rbl_client sbl.spamhaus.org,
    reject
    smtpd_sender_restrictions = reject_sender_login_mismatch,
    reject_non_fqdn_sender,
    reject_unknown_sender_domain,
    reject_non_fqdn_recipient,
    reject_rbl_client rbl.brasilrbl.com.br,
    reject_rbl_client rhsbl.brasilrbl.com.br ,
    smtpd_client_restrictions = reject_sender_login_mismatch,
    check_client_access pcre:/etc/postfix/ip_access,
    reject_unknown_hostname,
    smtpd_helo_restrictions = permit_sasl_authenticated, reject_invalid_hostname
    smtpd_data_restrictions = permit_sasl_authenticated, reject_unauth_pipelining
    smtpd_etrn_restrictions = permit_sasl_authenticated, reject
    -> Em /etc/postfix/sender_proibidos tem o seguinte:
    /.*_.*_.*_.*@.*/ REJECT Endereco de e-mail invalido (SD1)
    /.*[0-9][0-9][0-9].*@.*/ REJECT Endereco de e-mail invalido (SD2)
    /.*@[0-9][0-9][0-9]\.com$/ REJECT Endereco de e-mail invalido (SD3)
    /.*@eventos\.blog\.br$/ REJECT Endereco de e-mail invalido (SD4)
    /.*@trusontechnologies\.com$/ REJECT Endereco de e-mail invalido (SD5)
    /.*@safforddodge\.com$/ REJECT Endereco de e-mail invalido (SD6)
    /.*@abcoggins\.com$/ REJECT Endereco de e-mail invalido (SD7)
    /.*[0-9][0-9][0-9].*@meudominiot\.com\.br$/ REJECT Endereco de e-mail invalido DPC!!! (SD8)
    /.*_.*_.*_.*@meudominio\.com\.br$/ REJECT Endereco de e-mail invalido DPC!!! (SD9)
    /.*@meudominio\.com\.br$/ OK (SD10)
    /.*@.*/ REJECT Dominio bloqueado!!! (SD11)
    essa ultima linha, barra tudo que nos for do meu dominio.
    -> Em /etc/postfix/ip_access tem o seguinte:
    /^200\.201\.198\..*$/ REJECT Subrede IP nao permitida!(IP6)
    /^213\.227\.73\..*$/ REJECT Subrede IP nao permitida!(IP7)
    /.*localhost.*/ REJECT Hostname nao permitido!(IP8)
    /.*\.dsl\..*/ REJECT DSLs nao permitidas!(IP9)
    /.*\.adsl\..*/ REJECT DSLs nao permitidas!(IP10)
    /.*telesp.net\..*/ REJECT DSLs nao permitidas!(IP11)
    /.*brasiltelecom.net\..*/ REJECT DSLs nao permitidas!(IP12)
    /.*telebrasilia.net\..*/ REJECT DSLs nao permitidas!(IP13)
    /.*telesp.net\..*/ REJECT DSLs nao permitidas!(IP14)
    /.*ajato.com\..*/ REJECT DSLs nao permitidas!(IP15)
    /.*speedy.com\..*/ REJECT DSLs nao permitidas!(IP16)
    /.*virtua\..*/ REJECT DSLs nao permitidas!(IP17)
    /.*veloxzone\..*/ REJECT DSLs nao permitidas!(IP18)
    /^124\..*$/ REJECT Subrede IP nao permitida!(IP19)
    /^200\.184\.163\..*$/ REJECT Subrede IP nao permitida!(IP20)
    /^59\..*$/ REJECT Subrede IP nao permitida!(IP21)
    /^127\..*/ REJECT Subrede IP nao permitida!
    /^1\..*/ REJECT Subrede IP nao permitida!
    /^2\..*/ REJECT Subrede IP nao permitida!
    /^3\..*/ REJECT Subrede IP nao permitida!
    /^4\..*/ REJECT Subrede IP nao permitida!
    /^5\..*/ REJECT Subrede IP nao permitida!
    /^6\..*/ REJECT Subrede IP nao permitida!
    /^7\..*/ REJECT Subrede IP nao permitida!
    /^8\..*/ REJECT Subrede IP nao permitida!
    /^9\..*/ REJECT Subrede IP nao permitida!
    /^10\..*/ REJECT Subrede IP nao permitida!
    /^254\..*/ REJECT Subrede IP nao permitida!
    tem da rede /^1\..*/ ate a rede /^254\..*/ exeto as redes 200. e 201. que to fazendo filtro na mao.
    -> Em /etc/postfix/whitelist tem a lista dos meus dominio
    dominio1.com.br OK
    dominio2.com.br OK
    GENTE O MEU SERVIDOR TA BARRANDO TUDO...TUDO, EXETO O QUE EU PRECISO QUE NAO BARRE, E MESMO ASSIM ESTA CAINDO NO SPAMCOP POR CAUSA DAQUELE SPAMTRAP. por favor como posso melhorar essas regras, como posso acabar com esse spamtraps.
    muito obrigado...
  2. Não sei como resolver seu probs ainda , mas olha essa dica:
    How to Use Domain-Based Blacklist Zones
    Ab, Duca.
  3. Já verificou o DNS reversso ... ???
    se não vc vai ser sempre listado ...
    Falow ...
  4. Citação Postado originalmente por rootmaster Ver Post
    Falow ...
    em relacao ao dns reverso, esta ok.
  5. cara se vc testou o reversso e está ok ...
    veja se o relay tá autenticado, só permita que seja enviada messagem acom autenticação ...
    vc pode testar seu reversso aqui :
    Terra - Postmaster
    e para testar seu DNS teste aqui:
    DNS Report: The free, thorough report on the DNS for your domain
    Ai vc vai ter uma ideia de como está seu domínio ...
    Falow ...
  1. Respostas: 0
    Último Post: 15-05-2008, 22:13
  2. Socorro! Alguem me ajude! kkk!
    Por evandrodesdeinter no fórum Servidores de Rede
    Respostas: 5
    Último Post: 02-05-2008, 10:23
  3. SQUID X OUTLOOK alguem me ajude
    Por wladi no fórum Servidores de Rede
    Respostas: 56
    Último Post: 01-12-2004, 20:47
  4. Kernel, faltando!, alguem me ajude?
    Por ricardinhomattar no fórum Servidores de Rede
    Respostas: 7
    Último Post: 21-06-2003, 22:20
  5. Script com erro Por favor alguem me ajude
    Por edilson no fórum Linguagens de Programação
    Último Post: 12-01-2003, 23:09
