    Padrão ask about webproxy
    hi all
    i have mikrotik and im use webproxy-test for cache , all user limited speed to 1024kb >
    i need user access to webproxy without limit speed ,,, and to access internet limited speed
    can mikrotik do that >> if its okay can give me the code or rule
    thank you for help
    did mk have this option ,,,, i dont found it on english forum im sory
    if you found.. post here the solution.. pleeeeease..
    cliente >>>> free bandwidth >>>> MK >>>> limited Bandwidth >>> INTERNET.
    I need this solution too.
    Regard´s
    Alam Dias
    Padrão what is good
    whats is good to use webproxy or webproxy-test
    if i found the solution i well write it here
    Citação Postado originalmente por leo297 Ver Post
    The webproxy is a tested package and run 100% fine.
    The webproxy-test, i´m using here, only for tests, and this have a litle bugs yet.
    I´ve my doubts about use the webproxy-test in my official server.
    Regards
