    Padrão see this problem with mac address
    hi
    im used mikrotik os and connection hotspot , i want to use mac address to login
    but i see in host mac address not for the pc i see the mac for access point
    like this
    mk----access point 1----------access point 2 ----- pc (computer)
    in mikrotik i see the mac address of access point 1 not mac adress of pc
    my mikrotik hotspot ip 10.90.40.1
    access point 1 ip 192.168.40.6
    access point 2 ip 192.168.40.7
    pc( computer) ip 192.106.121.20
    any idea for this problem
    Citação Postado originalmente por leo297 Ver Post
    hi
    like this
    thats because almost every access point in client mode doesnt send the client( pc) mac address over wireless, only his mac address , like routers proxy arp..
    what u should to to fix it is to set both radios in wds mode so that way they can send the PC mac address to the otherside instead of the ap2 mac.
    i hope thats help
    Última edição por gustkiller; 08-04-2007 às 19:11. Razão: just fix
    Padrão thank you
    but i cant use WDS with my access point bz my access point not spourt wds
    my access point model ( alvarion DS11 ) dont work with wds
    if i disebled arp did it work
    Thaaank you very much i do the access point in mode point to point and i see the mac address of pc ( computer) but the problem i cant ping to access point but i can pint to computer
    like this
    access point in mode Ap (ip:192.168.230.5) ---- access point in mode point to point (ip 192.168.230.8) --- computer ( ip 192.168.230.15)
    i can ping to computer but i cant ping to access point
