    Calvinko
    Padrão Cyclades PR1000 + IP Telefonica
    Na verdade já vi vários tópicos a respeito, mas mesmo assim não consigo nem pingar o switch frame-relay da telefonica a partir do meu roteador. Segue a minha configuração, se alguém puder me dizer onde errei, agradeço.
    ________________________________________________________________
    Encapsulation Frame Relay
    IP protocol active
    Interface Numbered
    Primary IP address 201.xxx.yyy.zz2 (IP_WAN_LOCAL)
    Subnet mask 255.255.255.252
    IP MTU 1500
    IP Fragmentation bit DF - accept
    NAT - Address Scope Global
    ICMP Port inactive
    Incoming Filter List None
    Detailed Incoming IP Accounting Process inactive
    Outgoing Filter List None
    Detailed Outgoing IP Accounting Process inactive
    Routing of Broadcast Messages inactive
    Interface Transparent Bridge Inactive
    Sync mode
    External Clock Source
    Don't invert clock phase for transmission
    Interface V.35
    Bandwidth 0
    IP Traffic Control List None
    Encapsulation Type RFC1490 - IETF
    SNAP IP inactive
    LMI type Q933a
    Alternative DLCI routing disabled for this link
    T391 in seconds 10
    N391 6
    N392 3
    N393 4
    FRF-12 - without fragmentation
    Number of DLCI's 1
    Frame Relay MAP
    # DLCI Remote IP addr Local IP addr CIR Pred Ctrl
    01 111 201.xxx.yyy.zz1 100 Dis None
    (IP_WAN_REMOTO)
    DLCI Traffic Control inactive
    SNMP interface :
    Interface UP/Down TRAP Disable
    _________________________________________________________________________
    IP Static Routes
    Destination Subnet Mask Gateway/Interf Metric/Bkp/RIP OSPF/ExType
    Default Gateway 201.xxx.yyy.zz1 1 no no no
    (IP_WAN_REMOTO)
    Seu circuito tá Up ??? pelo que diz o arquivo não está ...
    (IP_WAN_REMOTO)
    Falow ...
    Calvinko
    Padrão frame relay
    Como ativo o circuito ? Veja as estatícas do SWAN. Consta como link up...
    Frame Relay link
    TX frames 9007
    TX bytes 117346
    TX frames discarded 0
    RX frames 0
    RX bytes 0
    RX frames discarded 0
    Unknown DLCIs 0
    Illegal DLCIs 0
    Frames RX greater than maximum size 0
    predictor compressed sent 0
    predictor decompressed received 0
    predictor Txed reset reqs 0
    predictor Rxed reset reqs 0
    predictor Txed reset acks 0
    predictor Rxed reset acks 0
    predictor discards 0
    Frame Relay LMI
    LIV status Enquiries 7501
    FULL status enquiries 1501
    LIV status responses 7501
    FULL status responses 1501
    Async status responses 0
    Sequence number errors 1
    Illegal report types received 0
    Missed status response messages 0
    LINK ups 1
    LINK downs 0
    Out of memory sends 0
    Time when last enquiry message sent 90021
    Monitored events 3
    Polling cycles 3
    Error events 0
    Fragmentation Statistics
    DLCI In-Frag Out-Frag In-UnFrag Out-UnFrag In-Assemb In-Dropped
    111 0 0 0 5 0 0
    Obrigado
    Calvinko
    Obrigado pessoal. Já resolvi o problema.
    Aliás não resolvi, o problema era da telefônica.
