- Ask
Ask
Ola galera! A coisa ta feia pro meu lado! rs
Não consigo fazer funcionar a opção de comandos remotos pelo ASK.
Vejam meu .askrc:
[ask]
rc_mymails = [email protected], [email protected], [email protected]
rc_myfullname = fernando
rc_mymailbox = /var/spool/mail/fernando
rc_mailkey = palavrachave
rc_md5_key = 3k8f4hdj40ds
rc_remote_cmd_enable = on
rc_remote_cmd_htmlmail = off
rc_basic_headers = From:,To:,Cc:,Bcc:,Date:,Subject:,Return-Path:,Received:,Message-ID:
rc_max_attach_lines = 0
rc_askdir = /home/fernando/.ask
rc_msgdir = %(rc_askdir)s/queue
rc_tmpdir = %(rc_askdir)s/tmp
# Templates Padrão para Todos
rc_confirm_dirs = /usr/share/ask-2.5.3/templates
rc_whitelist_on_mailkey = true
rc_confirm_langs = ptbr
rc_whitelist = %(rc_askdir)s/whitelist.txt, %(rc_askdir)s/whitelist-local.txt
rc_ignorelist = %(rc_askdir)s/ignorelist.txt, %(rc_askdir)s/ignorelist-local.txt
rc_mta_command = /usr/sbin/sendmail -t < MAILFILE
Então eu envio uma mensagem para mim mesmo, com o titulo por exemplo: "ASK HELP" e no corpo da mensagem eu coloco o rc_mailkey, no caso "palavrachave"
O email chega pra mim como se fosse um email normal!
Vejam o log:
2007/05/07 10:55:13 [18022]: ----- ASK v2.5.3 Started -----
2007/05/07 10:55:13 [18022]: Message from: fernando <[email protected]>
2007/05/07 10:55:13 [18022]: Message to: <[email protected]>
2007/05/07 10:55:13 [18022]: Message Subject: ASK HELP
2007/05/07 10:55:13 [18022]: is_confirmation_return(): Didn't find conf#MD5 tag on subject
2007/05/07 10:55:13 [18022]: is_remote_command(): Verifying the subject...
2007/05/07 10:55:13 [18022]: process_remote_commands(): Found subject="ASK HELP"
2007/05/07 10:55:13 [18022]: process_remote_commands(): Checking only. Returning true
2007/05/07 10:55:13 [18022]: Not matched in the whitelist
2007/05/07 10:55:13 [18022]: Sender is not mailer-daemon
2007/05/07 10:55:13 [18022]: __get_auth_tokens(): No X-ASK-Auth SMTP header found
2007/05/07 10:55:13 [18022]: validate_auth_md5(): Cannot read authorization tokens. Authentication Failed.
2007/05/07 10:55:13 [18022]: Message is not a confirmation return
2007/05/07 10:55:13 [18022]: __add_to_list(): "[email protected]" is listed as one of our emails. It will not be added to the list (/home/fernando/.ask/whitelist.txt)
2007/05/07 10:55:13 [18022]: Found mailkey. Adding to whitelist
2007/05/07 10:55:13 [18022]: Our key was found in the message. Delivering...
2007/05/07 10:55:13 [18022]: deliver_mail(): Delivering mail
2007/05/07 10:55:13 [18022]: generate_auth(): Authentication = 1178546113-1fcf0077bb4bbd027828390b01e21cec
2007/05/07 10:55:13 [18022]: deliver_mail_file: Delivering mail from /home/fernando/.ask/tmp/@18022.0.18022.msg to mailbox -
2007/05/07 10:55:13 [18022]: deliver_mail_file: delivering to stdout
2007/05/07 10:55:13 [18022]: deliver_mail_file: Message delivered to stdout
Que será que pode ser isso heim???
Por favor me ajudem...
Obrigado a todos,
Fernando.
