    fabio2
    Ola pessoal ,
    alguem pode me ajudar a descobrir o que está acontecendo que nao estou conseguindo gravar cd´s no linux:
    Pesquisei na internet e fiz todos os teste possiveis, vou postar todas as respostas das saidas dos comandos que executei:
    # ls -l /dev/cdrom
    lrwxrwxrwx 1 root root 3 May 8 08:26 /dev/cdrom -> hdc
    elinux:~ # cdrecord -scanbus
    Cdrecord-Clone 2.01 (i686-suse-linux) Copyright (C) 1995-2004 Jörg Schilling
    Note: This version is an unofficial (modified) version
    Note: and therefore may have bugs that are not present in the original.
    Note: Please send bug reports or support requests to Submitting Bug Reports - openSUSE
    Note: The author of cdrecord should not be bothered with problems in this version.
    cdrecord: No such file or directory. Cannot open '/dev/pg*'. Cannot open SCSI driver.
    cdrecord: For possible targets try 'cdrecord -scanbus'.
    cdrecord: For possible transport specifiers try 'cdrecord dev=help'.
    elinux:~ # cdrecord -v speed=8 dev=/dev/hdc /comp.tar.gz
    cdrecord: No write mode specified.
    cdrecord: Asuming -tao mode.
    cdrecord: Future versions of cdrecord may have different drive dependent defaults.
    cdrecord: Continuing in 5 seconds...
    TOC Type: 1 = CD-ROM
    scsidev: '/dev/hdc'
    devname: '/dev/hdc'
    scsibus: -2 target: -2 lun: -2
    Warning: Open by 'devname' is unintentional and not supported.
    Linux sg driver version: 3.5.27
    Using libscg version 'schily-0.8'.
    cdrecord: Warning: using inofficial libscg transport code version (okir@suse.de-scsi-linux-sg.c-1.83-resmgr-patch '@(#)scsi-linux-sg.c 1.83 04/05/20 Copyright 1997 J. Schilling').
    SCSI buffer size: 64512
    atapi: 1
    Device type : Removable CD-ROM
    Version : 0
    Response Format: 1
    Vendor_info : 'MS'
    Identifikation : 'C/DVD-ROM '
    Revision : '3.0 '
    Device seems to be: Generic mmc2 DVD-ROM.
    cdrecord: Cannot load media with this drive!
    cdrecord: Try to load media by hand.
    Current: 0x0000
    Profile: 0x0010
    Profile: 0x0008
    cdrecord: Sorry, no CD/DVD-Recorder or unsupported CD/DVD-Recorder found on this target.
    Obrigado a todos pela atenção
  2. Amigo,
    - Qual distribuição?
    - Qual versão do kernel?
    Para obter a versão do kernel é só digitar no console, como super usuário (root), o comando "uname", exemplo:
    # uname -a
    fabio2
    Opa companheiro,
    SEguinte
    Linux Suse enterprise
    Kernel: 2.6
    Obrigado
  4. Amigo,
    Dá uma olhada nestes artigos:
    http://www.guiafoca.org/guia/inic_in...-cdwritter-ide
    Linux in Brazil ( Gravador de CD )
    Caso não dê certo, por favor, imprima um lista dos módulos carregados com o comando:
    # lsmod > modulos.txt
    Abra o arquivo modulos.txt, copie o conteudo e cole aqui no fórum, para sabermos quais modulos foram carregados.
    fabio2
    Opa amigo,
    Só me tire uma dúvida, em linux com kernel 2.6 não é necessário emular um drive scsi para gravar cd´s ou é necessário??
    A Dúvida é por que os dois link que vc me passou falam sobre a emulação de scsi, e eu não sei aonde foi que eu li alguma coisa a respeito de gravação de cd´s e lá dizia que kernel 2.6 não era necessário
    Agradeço pela sua paciencia e ajuda.
    Um grande abraço
  1. Respostas: 0
    Último Post: 02-04-2007, 10:15
  2. Problemas com K3B - Programa para Gravar CD
    Por Vaza no fórum Servidores de Rede
    Último Post: 19-05-2003, 14:10
  3. QMAIL URGENTE - Problemas ao enviar e-mails
    Por chelio no fórum Servidores de Rede
    Último Post: 21-08-2002, 10:05
  4. QMAIL URGENTE - Problemas ao enviar e-mails
    Último Post: 21-08-2002, 10:00
  5. Problemas ao adicionar o samba ao dominio nt
    Por clmr no fórum Servidores de Rede
    Último Post: 23-04-2002, 10:31
