    dandan26
    Padrão esse firewall é seguro?
    boa tarde galera, gostaria de saber a opniao de voces sobre esse firewall, encontrei na net.
    #!/bin/bash
    echo "Iniciando o Firewall"
    #Ativa Modulos
    /sbin/modprobe iptable_nat
    /sbin/modprobe ip_conntrack
    /sbin/modprobe ip_conntrack_ftp
    /sbin/modprobe ip_nat_ftp
    /sbin/modprobe ipt_LOG
    /sbin/modprobe ipt_REJECT
    /sbin/modprobe ipt_MASQUERADE
    echo "Carga dos Modulos OK"
    #Protecao anti spoofing
    if [ -e /proc/sys/net/ipv4/conf/all/rp_filter ]; then
    for f in /proc/sys/net/ipv4/conf/*/rp_filter; do
    echo 1 > $f
    done
    echo -n "Anti Spoofing..."
    else
    echo
    echo
    echo "Problema ao levantar a protecao anti-spoofing."
    echo "CONTROL-D para sair do script e continuar a inicializacao."
    echo
    #start a single user shell on the console
    /sbin/sulogin #CONSOLE
    fi
    echo -n "Iniciando regras de input..."
    #zera regras
    /sbin/iptables -F
    /sbin/iptables -X
    /sbin/iptables -F -t nat
    /sbin/iptables -X -t nat
    /sbin/iptables -F -t mangle
    /sbin/iptables -X -t mangle
    echo "Flush de Regras OK..."
    #negar porta trinoo
    /sbin/iptables -t filter -A INPUT -p tcp -i eth1 --dport 27444 -j DROP
    /sbin/iptables -t filter -A INPUT -p tcp -i eth1 --dport 31335 -j DROP
    #negar porta trojans
    /sbin/iptables -t filter -A INPUT -p tcp -i eth1 --dport 666 -j DROP
    /sbin/iptables -t filter -A INPUT -p udp -i eth1 --dport 666 -j DROP
    /sbin/iptables -t filter -A INPUT -p tcp -i eth1 --dport 4000 -j DROP
    /sbin/iptables -t filter -A INPUT -p udp -i eth1 --dport 4000 -j DROP
    /sbin/iptables -t filter -A INPUT -p tcp -i eth1 --dport 5190 -j DROP
    /sbin/iptables -t filter -A INPUT -p udp -i eth1 --dport 5190 -j DROP
    #negar ping da morte
    /sbin/iptables -t filter -A FORWARD -i eth1 -p icmp --icmp-type echo-request -m limit --limit 1/s -j ACCEPT
    #negar porta scanners
    /sbin/iptables -t filter -A FORWARD -p tcp --tcp-flags SYN,ACK,FIN,RST SYN - m limit --limit 1/s -j ACCEPT
    #negar pacotes suspeitos ou danificados
    /sbin/iptables -t filter -A FORWARD -m uncliean -j DROP
    #negar ping
    /sbin/iptables -t filter -A FORWARD -i eth1 -p icmp --icmp-type echo-request -j DROP
    #bloquear MSN
    /sbin/iptables -A FORWARD -p tcp --dport 1863 -j REJECT
    /sbin/iptables -A FORWARD -p tcp --dport -d 64.4.13.0/24 -j REJECT
    #bloquear kazaa
    /sbin/iptables -A FORWARD -d 213.112.0/24 -j REJECT
    /sbin/iptables -A FORWARD -p tcp --dport 1214 -j REJECT
    #Proxy transparente
    /sbin/iptables -t nat -A POSTROUTING -o eth1 -j MASQUERADE
    /sbin/iptables -t nat -A PREROUTING -i eth2 -p tcp --dport 80 -j REDIRECT --to-port 3128
    echo "Carga do proxy transparente OK"
    se possivel, se tem algo de errado e o que pode ser melhorado.
    fico no aguardo ae galera.
    valew
    kra firewall é bem particular... esse aí pode estar bom pra vc.... mas pra mim nao...entende... pode esta bom pra mim, mas pra outro nao...
    firewall tem q ser conforme a sua necessidade...oq vc precisa ??
    algumas coisas estao "confusas" .. tipo isso
    #negar ping
    se vc NEGA o icmp.. acabou.. a proxima regra de limitar icmp a 1 reque/s .. nao vai ser necessaria..
    agora se voce INVERTER a ordem .. ai funciona rsrsr
    firewall.. cada caso um caso...
    recomendo usar o APF que eh muito bom !!
    Kra... esperiência própria... RECEITA DE BOLO NÃO PRESTA!
    Eu já quebrei a kra d+ com isso, o certo mesmo é vc aprender e fazer o seu firewall.
    O guia foca é um referencial completo:
    Guia Foca GNU/Linux - Firewall iptables
    Firewall com IPTABLES - by Eriberto
    esses documentos ai do site do eriberto sao excelentes !!
    Cara, seguinte ...
    Firewall como já foi citado, é bem particular, vc tem que entender sua estrutura de rede
    para poder aplicar as regras e segurançao cabivel, seu firewall tem que está relacionado com a topologia de sua rede, pegar scrips prontinhos só retarda o seu aprendisado
    com o que se diz respeito a firewall, mais ... se funcionou bem pra vc ... manda bala ...
    Falow ...
    Padrão firewall
    como o colega de cima falow, firewall cada um tem o seu, se quer um conselho, tente implementar o modulo ipp2p e layer7 no seu firewall ai sim, da pra fazer bloqueios bons mesmo, no caso da suas regras de bloquear msn, kaazaa, pode testar que nao deve estar funcionando....
    valew...
    Aí vai uma dica bacana...
    Já ouviu falar em lápis, papel e borracha?
    Então, tirá um tempo pra você, senta com toda a galera que será afetada por esse firewall e troca uma idéia com eles (se preciso for) para ver o que necessitam acessar.
    Feito isso, senta você com você e começa a bolar o que você precisa para trabalhar e se "entreter" (afinal, ninguém é de ferro). Depois, senta você e o servidor e comece a bolar como que o firewall pode ser pra que todas as necessidades sejam atendidas.
    Após toda essa maratona, corra atrás da documentação necessária e desenvolva o script.
    Tente-o bem. Nada possui 100% de desempenho.
    Depois é só partir pro abraco hehe.
